[ROM][4.4.2][NG4] efeXTREME KitKat-ROM [OTA][GT-I9300]
    Androidiano L'avatar di CosimoC
    Monopoli (BA)
    Samsung Galaxy S3 GT-I9300
    Ringraziato 19 volte in 11 Posts
    efeXTREME KitKat ROM based on QS-i9300-KK
    Thread XDA quì
    CHANGELIST BETA 1
    Based on KitKat N7100 port.
    Base ROM: QS-i9300-KK.
    Rooted.
    BusyBox.
    Support init.d.
    Support /data/ directory.
    SuperSU v2.01.
    Lastest zipaling.
    Build.prop tweaks.
    Integrated Boeffla kernel 6.0 stable.
    Boeffla Config app.
    Xposed Framework.
    Added S5 apps and full interface.
    And many many more...
    CHANGELIST BETA 2
    Based on QS-i9300-KK v2.5 (N7100XXUFNG4 port).
    Updated SU to v2.02.
    Updated Busybox.
    Updated Xposed Framework.
    Updated to S5 Mini apps.
    Updated SystemUI.
    Updated Framework.
    Lastest smali/baksmali.
    Lastest zipaling.
    Removed Boeffla kernel.
    Removed Boeffla Config app.
    Removed SFinder & Quick Connect.
    Removed Flipboard.
    Removed useless background processes.
    Fixed Screen Mirroring & Wi-Fi Direct.
    Fixed SmartScroll.
    Fixed OTA Updater missmatch ID.
    Fixed FC at changing lockscreen wallpaper from Settings.
    Added QS-i9300-KK stock kernel.
    Added UPSM Manager.
    Some visual changes here and there.
    And many more...
    FEATURES
    S5 User Interface.
    S5 SystemUI.
    S5 Settings.
    S5 Task Manager.
    S5 Launcher with My Magazine.
    S5 Accuweather Widget.
    S5 Lockscreen.
    S5 Keyguard.
    S5 CallUI.
    S5 Contacts.
    S5 Messages.
    S5 Keyboard with colored emojis.
    S5 Browser.
    S5 My Files.
    S5 Calculator.
    S5 Music.
    S5 Video Player.
    S5 Gallery.
    S5 Planner.
    S5 SVoice.
    S5 Email.
    S5 Memo.
    S5 Voice Recorder.
    S5 Radio.
    S5 SFinder.
    S5 Quick Connect.
    S5 Toolbox.
    S5 Power Saving Mode.
    S5 Ultra Power Saving Mode.
    S5 Multiwindow.
    Smart Stay.
    Smart Pause.
    Smart Scroll.
    OTA Updates.
    SCREENSHOTS
    DOWNLOADS
    efeXTREME KitKat-ROM beta 2
    Full wipe raccomandato per una installazione pulita.
    Versioni precedenti
    Kernel alternativi
    Boeffla Kernel Beta
    PSN AGNi Stock v4.5
    ArchiKernel v1.4
    BUG NOTI
    -Se imposti una suoneria personalizzata per un contatto tramite l'app Contatti ci sarà un FC. Puoi impostarla tramite l'app Musica o Archivio.
    -Uso con una mano.
    -Potrai vedere qualche glitch grafico, raramente.
    -Se metti a caricare il telefono da spento, si avvierà automaticamente.
    TWEAKS
    -Controlla che il risparmio energetico non sia attivo quando non serve.
    -Vai in impostazioni > altro > Opzioni sviluppatore e cerca "Animazione di ridimensionamento finestra", "Ridimensionamento animazione finestra" e "Ridimensionamento durata Animator". Imposta queste tre opzioni a 0.5x.
    -Vai in impostazioni > altro > Opzioni sviluppatore > limite processi in background e impostalo ad almeno 2 processi.
    -Se stai usando il Boeffla kernel con un profilo di risparmio energetico ci sarà qualche lag a volte.
    -Quando la RAM è troppo piena, svuotala dall'apposito menù.
    -Se stai usando il Boeffla kernel apri l'app Boeffla Config e vai su Miscellaneous tab > Sovrascrittura Swappiness, attivatela e impostatela a 60 o 80.
    -Usa Greenify.
    Ultima modifica di CosimoC; 27-09-14 alle 10:05
    Galaxy S3 GT-I9300
    skippioROM v13
    TWRP 2.8.6.1
    Kernel Stock
    Modem XXUGNA8
  2. I seguenti 3 Utenti hanno ringraziato CosimoC per il post:
    Andramyx155 (16-09-14),androzzi (15-09-14),download01 (15-10-14)
    Monopoli (BA)
    Riservato.
    Galaxy S3 GT-I9300
    skippioROM v13
    TWRP 2.8.6.1
    Kernel Stock
    Modem XXUGNA8
  5. #3
    Senior Droid L'avatar di androzzi
    Da qualche parte...
    Xiaomi Mi5
    Ringraziato 132 volte in 97 Posts
    Io l'ho provata tempo fa e devo dire che girava molto bene. Ora sono ritornato a 4.3 perchè sui port della 4.4.2 i giochi girano male. Comunque complimenti per il thread, è strutturato benissimo!
    SE TI SONO STATO D'AIUTO, CLICCA IL TASTO "THANKS"!!!
    Xiaomi Mi5 4GB/128GB Black Ceramic Edition
  6. Il seguente Utente ha ringraziato androzzi per il post:
    CosimoC (15-09-14)
  7. #4
    Senior Droid L'avatar di Gianluca499
    Nov 2013
    Molise
    LG G3, Redmi Note 3 Pro
    Ringraziato 71 volte in 43 Posts
    Come si comporta con il passare del tempo?
    Redmi Note 3 Pro
    MM MIUI 8 7.4.25
    Android 6.0.1
  8. #5
    Monopoli (BA)
    Quote Originariamente inviato da Gianluca499 Visualizza il messaggio
    Abbastanza bene considerando anche che è un port
    Galaxy S3 GT-I9300
    skippioROM v13
    TWRP 2.8.6.1
    Kernel Stock
    Modem XXUGNA8
  9. #6
    Androidiano L'avatar di Davidetrk
    Impostazioni telefono cioè quello chiamate
  10. Il seguente Utente ha ringraziato Davidetrk per il post:
    dmg71 (23-09-14)
