Pagina 1 di 4 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 40
[ROM]- [MIUI v5-3.11.8] - iHackers v1.4
    Senior Droid L'avatar di Kira.93
    Ringraziato 82 volte in 73 Posts
    Ecco a voi la miglior ROM su base MIUI per il Galaxy S3.
    La MIUI non credo abbia bisogno di presentazioni, dico soltanto che è una ROM che si ispira ad iOS per alcuni aspetti grafici. Quindi se preferite lo stile Holo di Android, questa ROM non fa per voi. (Video al 2° Post)
    Changelog MIUI
    Link XDA
    Features by iHackers
    Release:
    • Based on Stock JB 4.1.1 and Includes All the Features from Stock Based ROMS.
    • Patchrom Adaptation and OTA Updates are Now Enabled.
    • This is The Best and The Most Stable Release Until Now.
    • Several Addons and Applications Included.
    Installer:
    • Aroma Based Installer
    • Includes Multiple Kernels to Choose From.
    • Undervolting Options Added (Refer to Notes)
    • Bloatware Removal Options Added (Refer to Notes)
    • Google Glass Apps (Transparent) Included and All Updated To Latest Versions.
    • Several CPU Control Apps Added as Options in Aroma Installer, CPU Control FCs Resolved too.
    • More Apps Added Which are Optional To Install in Aroma Version. All of them are updated to the Latest Versions.
    • Per App Details (What the App Does, Should It be removed, Will removal of the App be helpful or problematic) Added in Bloatware Removal Script.
    • Wheather Issues are sloved and Stock chinese Weather App replaced with WeathreBZ.
    • Some More File Managers Added as options in Aroma Installer, All of them have been updated to the latest versions with respective patches and addons.
    • A Few More Camera Apps Added, All the Camera Apps are optimized to work on MIUI v5. You will notice better quality and smoother experience while using the included camera apps.
    • A few Music Players added as options in Aroma Installer for being used with ACID, Viper4Android, Dolby or S-Force Sound Mods. All of them have been optimized for use on MIUI v5.
    • Sevral Launchers added and Optimized for Use on MIUI v5. Iconset and Themes for alternate Launchers have been added too. All the included Launchers are Fast, Stable, Lagfree, Super Smooth and Full of Features.
    • Iconset have been replaced with a beautiful collection of 3500+ Icons, That means you will now have MIUI Style Icons for almost all the apps you install, If you feel that there are still some apps left out whose icons are not included let me know I will include them in the next release.
    • Wallpaperset for both Lockscreen and Desktop replaced with an amazing Collection of 100+ Wallpapers. If you guys have some other wallpapers which you think should be included in the ROM, give them to me and I will include them in the next Release.
    • Several other UI Improvements, which you will know once you use the ROM, Also The Default Wallpaper for both Desktop and Lockscreen have been changed.
    Fixes:
    • All Lag Almost Totally Gone. Smoothness, Stability, I/O, Fluidity, Responsiveness have increased all together to a considerable extent.
    • Finally 1080p Video Works Perfectly and Without Any Lag Whatsoever.
    • FXP FM Radio has been already Included and Works Perfectly Fine.
    • Brightness Problem Fixed. If you still face a Problems Refer to Notes.
    • CPU Overclocking More stable and Less Battery Draining Now, Refer to Notes for More Details.
    • Optimized the ROM for better support, Faster and Smoother Interface and Lesser Incompatibility Issues.
    • Fixed the Issue of Small Contact Picture display during calling even if a HighRes Picture is attached to the Contact.
    • Mysterious Contact and Phone FCs Completely Resolved, Contact and Call Log Scrolling Completely Lagfree and Super Smooth too.
    • Proximity Sensor Delay and Several Other Bugs Related to Proximity Sensor Almost Completely Gone If you still face problems refer to notes.
    • Camera Now Supports Reading QR Codes and White Balance, Blue Tint and ISO Issues Completely Resolved too.
    • Video Recording more stable, Smoother and With Higher FPS. Audio Recording More Cleaner and NoiseFree. Auto-Focus Issues during Video Recording Resolved too.
    • Speaker Volume Issues Solved, You Should Use the Sound Mods to adjust it better, ACID and ViPER4Android are Included in the ROM, its your preference if you want to install one or both, they can both work good together too, Let me know if you aren't able to configure them properly.
    • Elasticity and Transitions on Launcher are Smoother and Better Now.
    • In Call Volume Issue Solved.
    • Glitching, Itching and Flickering Issues Resolved.
    • Removed Almost All Bloatware.
    • Streamlined Redundant Components.
    • Optimized WiFi Speed and GPS Positioning.
    • UI and Refresh Rate Improvements.
    • Fixed Song Play Failure When Screen is Off.
    • Optimized Memory Usage and Memory Management.
    • Fixed FCs Issues on Several Apps.
    • Improved Browser Responsiveness and FC Issues.
    • Increased 3G and 2G Speed.
    • Fixed Network Unavailability Problem.
    • All Third Party Apps Removed for Minimal Version
    • All Bloatware Removed for Both Stripped and Minimal Version
    • Fixed Zero Brightness Problem Completely
    • Battery Consumption and Heating Problems Solved
    • Lockscreen UI, Wallpaper and Theme Changed
    • Night Blindness Issues Solved
    • All Apps Updated to Latest Versions.
    Graphics:
    • Added Pure™Graphics HD + Rendering Version (Credits to Jeeko).
    • Enabled GPU Rendernig.
    • Enable Dithering but did not Affect Consumption.
    • Enabled Use of the GPU for the Touch Capacitation and Management.
    • Improved Video HW Rendering.
    • Increased Benchmarking Scores on the AnTuTu Graphic Rankings.
    • Improved Pixel Density, DPI and Brightness.
    • Eliminated Lag System with the Video Entropy Generator.
    • Liquified the UI.
    Audio:
    • Added PureAudio™ Engine v1.0 (Credits to Jeeko).
    • Clearer Sound.
    • No More Track Noises.
    • Beats™ Audio by Dr.Dre Now Included by Default.
    • Now, The ROM is also compatible with the Headphones that don't support Audio Render at 60KHz.
    • Wherever possible, arranged for the Conversion of the Songs (in background) below 256 kbps to 320kbps.
    • During Playback of Songs / Sounds make a Soft Frequency Scaling to Reduce Noise and Highlight the Track.
    • The ROM now offers More Powerful and Closed Bass.
    • Efficient even with Sony's/Samsung's Generic Headphones.
    • Improved the In-Call Audio Hearing and Transmission a lot.
    • Enhanced the Speakers' Audio and Compression for Playing Music without Headphones in High Quality.
    Performance:
    • Added PurePerformances™X Mod (Credits to Jeeko)
    • Radically Improved RAM Management for MIUI (Lags... Adios!).
    • Graphics Improved: Pure Graphic™HD, Pure Dithering Plus™ and... AOSPA 3.60 System Tweaks.
    • Multimedia Scan Time Drastically Reduced.
    • Network Improvements, 3G Experience Even in 2G Modality.
    • All SQlite Database Optimized.
    • Enabled Hardware Features Turned Off by Default for a Better Experience and Stability.
    • Greatly Increased the AnTuTu Scores: Try it to believe it!!
    • ReduceD the Startup Time Per Reboot.
    • Now You can Play Ported Games Without Lags.
    • The Device now itself Cleans the System Every 24 Hours, The Cache Every Week and The Dalvik Every Month (Cronos Easter Egg).
    • Automatically Zipalign on Each Boot (Sensitive to The User).
    Battery:
    • Drastically Decreased the Battery Drain.
    • Check the Activities that Consume Too Much Battery and Stops Them with PureWakelocks™.
    • When the Phone is Charging Reduces System Services for Faster Charging.
    • The Battery is Calibrated on Every Boot.
    • Disabled System Animations When the Battery is Nearly Exhausted.
    • Improvements in build.prop as Regards The Part of Consumption.
    • Enabled a Non-Aggressive Dithering to save CPU.
    • When You Lock the Device, The Engine makes sure that the GPU is turned off.
    • Enabled Deep Sleep.
    Tweaks:
    • Audio Drivers and Libraries all Updated to Latest Versions with more tweaks for Better and Cleaner Sound.
    • Optimized Music Player Libraries and Increased Volume and Effects. Music Player and MusicFX FCs Completely Resolved.
    • ACID Sound Mod, Viper4Android, S-Force Audio All Updated to Latest Versions with some new tweaks and Modifications. Dolby Digital Sound Added as Default.
    • Camera Tweaked for Better Focus and Quality, Its Comparively Better Now.
    • Parts of Bravia Engine.
    • Parts of CrossBreeder (credits to dev).
    • Parts of Adrenaline Engine (credits to dev).
    • PureGraphics HD.
    • V6 supercharger.
    • Enabled Video Entropy Generation (Like Seeder).
    • Slightly Improved the Scaling of the Frequencies.
    • Lightend the Load on the CPU Switching the Workload to GPU Rendering.
    • Enabled the Swap Partition in Android (Experimental).
    • Added Several INIT.D Tweaks and Scripts
    • Default CPU Frequency and Governer Changed
    • Disabled Normalized Sleeper to Fix Wakelocks
    • Capacative Backlight Issues Fixed
    • Flickering Issues Finally Fixed
    • Battery Scripts and Tweaks (Sleepers)
    • Minifree Handler Tweak
    • Internet Speed Tweaks
    • VM Management Tweaks
    • Kernel Tweaks
    • SysCTL Tweak
    • EXT4 Tweaks
    • IO Tweaks
    • Lot More That I Do Not Remember++
    Codice PHP:
    Contributors
    iHackers
    Sumedha Kapoor
    ROM OS Version
    4.1.x Jelly Bean
    ROM Kernel
    Linux 3.0.x
    Version Information
    Status
    Testing
    Current Beta Version
    v1.4
    Beta Release Date
    2013-11-8
    Created 2013
    -10-16
    Last Updated 2013
    -11-
    Ultima modifica di Kira.93; 11-11-13 alle 23:02
  2. Il seguente Utente ha ringraziato Kira.93 per il post:
    lorenzosicilia (12-11-13)
    MIUI v3.11.8 Changelog:
    [System]
    Optimization – Problems with low-end sound in speakers and headphones (11-8)
    Optimization – Increased receiver volume for Weixin messaging app (11-8)
    Fix – After device had been flashed, there was no start-up sound upon reboot (11-8)
    Fix – Rare crackling in sound output (11-8)
    [Phone]
    Fix – Buttons for the dialpad might be displayed in the wrong location (11-5)
    Fix – PIN status was incorrect after hot-swapping SIM cards (11-8)
    Fix – After hot-swapping SIM cards, users sometimes experienced issues getting mobile service (11-8)
    Fix – When using special SIM cards, phone would display that it was getting mobile service but that no SIM card was inserted (11-8)
    [Messaging]
    Fix – Notification messages (Bank, topups, etc.) can be marked as read automatically (11-5)
    [Lock Screen, Status Bar, Notifications]
    Fix – Problem with wallpaper memory overflow (11-7)
    [Home Screen]
    Optimization – Optimized display for smaller high-resolution icons (11-5)
    [Themes]
    New – “Collections” and “Classics” added at the bottom of the Featured page (11-7)
    [Camera]
    Optimization – Gamma curve optimization (11-8)
    Optimization – Improved camera focus speed (11-8)
    Fix – Optimized maximum digital zoom to 4X (11-8)
    Fix – Fixed some issues with ANR in low-light settings (11-8)
    [Gallery]
    Fix – When using the fisheye lens, duplicate pixels would appear in various areas of the photo (11-5)
    [Music]
    New – When user connects headphones, a reminder for the user to configure headphone settings will appear in the Notification shade (11-6)
    Removed – In System Settings > Sound > Call Ringtone and Vibrate, the Music effects option was removed (11-5)
    [video]
    New – Videos can now be searched by actor (11-7)
    Fix – Sometimes app would flash quit when user went back to episode view (11-7)
    [Contacts]
    Fix – When importing contacts to SIM card, screen would go dark (11-5)
    [Music]
    Removed – In System Settings > Sound > Call Ringtone & Vibrate, the Music effects option was removed (11-5)
    L'installazione è la solita:
    • Scaticate il file zip e lo inserite sulla SDcard;
    • Riavviare in Recovery;
    • Install Zip From SDCard > Choose Zip From SDCard > Install
    • Riavviare dopo il completamento dell'installazione.
    Download e lingua Italiana
    Se volete avere anche la lingua italiana, dopo aver flashato la rom, invece di riavviare subito, installate anche il Multilang Pack, che si trova in QUI, insieme al download per la ROM.
    Kernel Boeffla Batteria:
    • Governor: zzmoove
    • Governor profilo: zzmoove battery
    • Internal sd: row
    • External sd: bfq
    • Idle mode:aftr+lpa
    • Undervolt CPU: light
    • NO Undervolt GPU
    • System tweaks: mattiadj tweaks
    • zRam 4 core con 500mb
    • Swap 80
    Video Dimostrativo:
    Ultima modifica di Kira.93; 12-11-13 alle 10:51
  5. #3
    Androidiano L'avatar di lorenzosicilia
    Palermo
    Galaxy s 1, galaxy s 3 ecc
    Ringraziato 120 volte in 101 Posts
    Ottimo lavoro Kira, finalmente eccola su androidiani! Detto fatto..
    Io sto avendo qualche problema nell'installazione della miui ihachers come rom secondaria..
    Come rom primaria utilizzo la rom imperium..
  6. #4
    Io avevo anche la imperium, con cui mi sono trovato benissimo, ma la voglia di cambiare mi ha portato qui.
    Non faccio il dualboot perche il mio s3 è ostile al kernel syhai( o come si scrive), sto usando questa ROM con il boeffla, e va che è una meraviglia. Sicuramente da provare, io credo comunque di tenerla ancora per un bel po, aspettando kitkat con la cyano o la 4.3 di Samsung esente di bug.
    Nexus S --> Samsung GS3 --> LG G2 --> LG G4 --> Honor 8
  7. #5
    Senior Droid L'avatar di Prizio79
    Jun 2010
    LG G2 16Gb
    Buongiorno, volevo provare questa rom, stò scaricando i file da XDA ma ce ne sono diversi oltre alla ROM e Multilanguage tipo Cancell app Addon etc a cosa servono?
    Seguite il mio podcast: http://www.geekreflections.it
  8. #6
    Nov 2013
    Ragazzi vorrei sapere come reagisce la rom per quanto riguarda l'autonomia, ovviamente potete postare qualche settaggio, se avete kernel stock o meno. Grazie
    Using Tapatalk
  9. #7
    Quote Originariamente inviato da Prizio79 Visualizza il messaggio
    Non preoccuparti di quegli altri file, per l'installazione servono solo quelli in tuo possesso
    Quote Originariamente inviato da Developer96 Visualizza il messaggio
    Allora ho la ROM da qualche giorno e sono davvero soddisfatto per la durata della batteria. All'inizio pensavo che essendo una miui i consumi sarebbero diminuiti, invece sono in linea con la samsung, se non migliori.
    Ecco i miei settaggi col kernel boeffla:
    Governor:zzmoove
    Internal sd:row external: bfq
    Idle mode:aftr+lpa
    Undervolt:light
    Swap 80
  10. #8
    Jun 2010
    LG G2 16Gb
    Vedo che è "etichettata" come beta...bug eclatanti?
  11. #9
    Si, è etichettata come beta, ma non ha alcun tipo di bug grosso, e devo dire che di lag ne ho visti davvero pochi.
    E' davvero molto performante
  12. #10
    Nov 2013
    Ho letto che come estetica somiglia molto ad iOS! È vero?
    Using Tapatalk
