Utente del giorno: kroko con ben 1 Thanks ricevuti nelle ultime 24 ore
Pagina 1 di 18 12311 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 180
[ROM][5.0.1][LOLLIPOP][i9300]Resurrection Remix 5.2.1[CM12-BASED]
    Htc Desire HD Galaxy S, S2, S3
    Ringraziato 39 volte in 33 Posts
    Volevo presentarvi una nuova rom con base lollipop, la Resurrection Remix 5.2.1.... Prime impressioni: fluida per essere una beta, molto valida come rom.
    Resurrection Remix the ROM has been based on AOKP, CM, PA , Omni and original Remix ROM builds, this creates an awesome combination of performance, customization, power and the most new features, brought directly to your Device
    Many things that in previous versions were tweaked with mods, are now included by default in the ROM so, please enjoy!
    Resurrection Remix
    supporting many devices
    Special thanks to the AOKP team ParanoidAndroid team, the CM team,OMNI team and of course to all the supporters
    Included Main Features
    Statusbar clock customization + second + fonts
    -Network traffic monitor
    -Toast animations
    -Add changelog
    -Listview animations
    -LCD Density
    -Add Weather display to status bar header
    -Quick unlock
    -Overall Speed up system
    -Brand new music and audio fx app from cyanogen
    -Included all cm 12 features
    -And many more slim omni and orginal RR improvements and system ui changes running in this alpha build. So enjoy
    AND MORE...
    BUGS:
    -Essendo basata sulla cm12 ha i suoi stessi bug-
    NEL TERZO POST CI SONO I LINK CON I FIX E KERNEL COMPATIBILI
    -INSTALLAZIONE-
    1- Scaricare la ROM e le gapps
    2- riavviare in recovery
    3- backup (opzionale ma consigliato)
    4- full wipe (data, cache, dalvik, system, preload)
    5- selezionare lo zip della ROM da installare
    6- installare gapps
    7- reboot (potrebbe impiegare diversi minuti)
    SE VA IN BOOTLOOP:
    Flashare rom stock 4.3 via odin e poi rifleshare rom Resurrection Remix.
    Oppure
    1. Installare la Cm11 con full wipe e nel frattempo scaricare la Cm 12 da Qui
    2. Riavviare
    3. Tornare in recovery e intallare la Cm12 senza nessun wipe
    4. Flashare le gapps
    5. Flashare ril(data temporary fix) zip
    6. Riavviare
    7. Appena si avvia la rom tornate in recovery e flashate la Resurrection ROM senza wipe
    8. Flashate le gapps
    9. Flashate ril (data temporary fix) zip
    10. Riavviare e il gioco è fatto
    DOWNLOAD:
    ROM
    GAPPS
    CHANGELOG
    FONTE: XDA
    Ultima modifica di andreamk; 08-01-15 alle 21:11
  2. I seguenti 2 Utenti hanno ringraziato andreamk per il post:
    ke97 (13-01-15),tizio9833 (23-12-14)
    Ultima modifica di andreamk; 14-12-14 alle 13:32
  5. I seguenti 2 Utenti hanno ringraziato andreamk per il post:
    ke97 (13-01-15),tech91 (17-12-14)
  6. #3
    Ecco alcuni Fix:
    - Se avete problemi nella visualizzazione dei nei nomi nei contatti: Qui-
    - Se la rete dati non funziona: Scaricare e fleshare da recovery il file, ecco il link-
    -Se la fotocamera non funziona: Scaricate da questo link e fleshate da recovery-
    - Fix bug grafici nei video: Andare in Impostazioni cliccare su Opzioni Sviluppatore e deselezionare la voce "Usa NuPlayer" (Non sempre funziona)-
    - Se il lettore video non funziona provate a scaricarne uno alternativo dal play store-
    Kernel compatibili:
    - ArchiKernel dalla versione AOSP-1.6.2 R4P0 in su. Link Qui-
    - Kernel Arter97 dalla versione 4.0 in su. Link Qui-
    Ultima modifica di andreamk; 08-01-15 alle 21:14
  7. I seguenti 2 Utenti hanno ringraziato andreamk per il post:
    galaxy77 (20-08-15),ke97 (13-01-15)
  8. #4
    Samsung Galaxy s3
    è stato superato il numero massimo di download
  9. #5
    Quote Originariamente inviato da tizio9833 Visualizza il messaggio
    Ciao, non riesci a scaricarla?
  10. #6
    Samsung Galaxy s3
    No, mi dice che per oggi è stato superato il numero massimo. Potresti usare un altro host?
  11. #7
    Cè solo quello su xda, a me invece la fa scaricare senza problemi
  12. #8
    Samsung Galaxy s3
    Io ho provato con pc diversi e utenti google diversi ma niente. Gentilmente potresti scaricarla e ricaricarla su un altro host, please
  13. #9
    Ho aggiunto un altro host per il download, fammi sapere.
  14. Il seguente Utente ha ringraziato andreamk per il post:
  15. #10
    Samsung Galaxy s3
    Grazie, ora la installo
