Pagina 1 di 2 12 ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 11
[ROM] Maverick S6 v4 |Marshmallow S6 porting|
    Jul 2014
    [ROM] Maverick S6 v4.5 |Marshmallow S6 porting|
    Comunico che molto probabilmente lo sviluppatore ha abbandonato il progetto...
    Flashando Questa rom, la garanzia decade.
    NON SONO RESPONSABILE PER QUALSIASI COSA CHE succede al vostro dispositivo!
    Supporta G900F/M/I/L/K/T/S/W8
    Caratteristiche:
    G925FOXA3COI9 firmware
    Build Prop Tweaks
    OTA UPDATES
    LSPEED
    5 modi per riavviarre
    rimosso pericolo alto volume
    rimossa suoneria crescente
    Gestione RAM
    FSTRIM AND SQLITE
    BUILT IN DEBLOATER
    106 Csc
    App Ops 6.0
    Enabled CALL & MSG BLOCKING
    Long Press Back to Kill App(accessibility settings activate)
    Camera Mod
    Video Recording in Power menu
    Screenshot in Power menu
    TOUCHWIZ N5 marshmallow themed
    Dual layer smart manager
    Updated apps to Marshmellow beta apps
    Color Fade Memory Leak 5.0.x fixed
    Read/write to external sd feature
    Dev options in Settings
    Custom Lockscreen Clock Fonts with choose of stock clock zip
    Sound menu on power menu
    MAVERICK APP FEATURES
    Statusbar Clock Options
    Clock Position Right/Center/Left
    Clock Color set any color/alpha
    Clock AM/PM Small/Regular
    Clock Weekday Small/Regular
    Statusbar Background
    OZOP PICS
    Battery Icon Settings
    Toggle between Stock/3Minit battery
    Display Percentage
    3Minit Battery Mod (only on 3Minit systemui)
    Battery Bar: Show/Hide, Animation, style, Thickness, Color
    Statusbar Icon Colors
    WiFi Icon Color Set any color/alpha
    Signal Icon Color Set any color/alpha
    Data Icon Color Set any color/alpha
    Notification Icons Color Set any color/alpha need to restart SystemUI after Changes
    Notification Panel
    Toggle buttons background
    Brightness Slider toggle
    Memory cleaner toggle with color option
    RAM TOGGLE
    MISC
    Bare-bones debloat scripts built into maverick rom just click to debloat
    Volume Warning toggle
    Notification Text Color
    Back to kill
    Mokee Listview Animations
    LOCKSCREEN
    Ambient Display & Ambient Display timeout Toggle
    Heads up toggle
    Device Info toggle
    Lock screen UI toggles
    Lock screen Rotation toggle
    Amount of notifications on lock screen toggle
    Quick Unlock (Pin lock and password)
    OZOP PICS
    Display Percentage
    Notification Panel
    RAM TOGGLE
    MISC
    Back to kill
    LOCKSCREEN
    Heads up toggle
    Device Info toggle
    OZOP PICS
    Display Percentage
    Notification Panel
    RAM TOGGLE
    MISC
    Back to kill
    LOCKSCREEN
    Heads up toggle
    Device Info toggle
    Installazione:
    KNOX VERRA ALTERATO A 0X1
    necessità di una custom recovery(philz touch consigliata) anche cwm va bene
    IMPORTANTE: wipe system , dalvik e cache (su philz touch scegliere"clean to install a new rom")
    1)Scaricare il link in fondo MEGA sulla vostra sched sd
    2)entrare in recovery(volume su + tasto accensione+ tasto home)
    3)Scegliere "install zip" e cercare nei file "maverick v4 s6 port
    4)L'installazione impiega 2 minuti circa
    5) il riavvio circa 5 minuti
    Download: https://mega.nz/#!tENDVT4a!qzNF4z7_3...RJB2uEiR8aezQ8
    Alcune informazioni sono in inglese ma io sono italiano.
    QUALSIASI INFORMAZIONE CONTATTATE
    link:http://forum.xda-developers.com/gala...es-30-t3266117
    Ultima modifica di asdfghjklml; 06-03-16 alle 12:03 - Motivo: inserito spoiler
  2. I seguenti 2 Utenti hanno ringraziato asdfghjklml per il post:
    clarkkk (09-01-16),lucadalba (09-01-16)
    kmd
    kmd non è in linea
    OnePlus 9Pro, OnePlus 11
    Aggiunta in Caffè Point Galaxy S5...
    edit:
    @asdfghjklml
    manca il link alla discussione ufficiale, la fonte della Rom... integralo nel primo post.
    Ciao
    Ultima modifica di kmd; 11-01-16 alle 18:34
  5. I seguenti 2 Utenti hanno ringraziato kmd per il post:
    ettore88 (11-01-16),lucadalba (10-01-16)
  6. #3
    samsung galaxy s5 g900f
    Ringraziato 5 volte in 2 Posts
    ciao
    ma la rom è 5.1.1 oppure 6.0??
  7. #4
    Senior Droid L'avatar di lucadalba
    Nov 2015
    Puglia
    Samsung Galaxy S5 SM-G900F
    Ringraziato 829 volte in 468 Posts
    Quote Originariamente inviato da marchitelli30031994 Visualizza il messaggio
    ciao
    Dall'ultimo screenshot del post #1 si dedurrebbe 5.1.1
    Smartphone: Samsung GALAXY S5 SM-G900F
    ROM: DeoXPer Pure 1.5
    https://uploads.tapatalk-cdn.com/20160417/e990eaa23b00a71c7c39f2b444571df0.jpg
  8. #5
    Quote Originariamente inviato da lucadalba Visualizza il messaggio
    chiedevo perchè il titolo dice marshmallow s6 porting
  9. Il seguente Utente ha ringraziato marchitelli30031994 per il post:
    lucadalba (22-01-16)
  10. #6
    Nov 2015
    Puglia
    Il titolo potrebbe portare in confusione, comunque dovrebbe essere un porting dell'S6 edge IN STILE ANDROID MARSHMALLOW (con versione Android 5.1.1 Lollipop).
    Aspettiamo che sia @asdfghjklml a comfermarlo
  11. #7
    L'ho provata di recente. E' la rom dell'S6 in versione 5.1.1 lollipop portata su S5. Di Marshmallow non ha nulla a parer mio.
    Rom buona tutto sommato... forse con troppo bloat, non so se è stato un mio errore ma ogni volta che cercavo di togliere del bloat rimuovendo col root i servizi samsung (che su altre rom tolgo senza problemi) mi tira su un errore utente e il cellulare diventa inutilizzabile... e tocca riflashare... In pratica è una roma da installare e tenere così com'è!
    A parer mio è fatta bene... pesante nella media, ma fluida e senza intoppi... e poi col supporto ai temi che non fa mai male!
    Consigliata!
  12. #8
    Androidiano L'avatar di Furmine
    Galaxy S5 G900F
    Ringraziato 182 volte in 108 Posts
    Buongiorno a tutti ragazzuoli... ho montato ieri questa Rom... Devo dire che a primo impatto mi è sembrata molto valida in alternativa alle stock... ha una marcia in più... ora non so se dipende dal mio telefono o da qualche errore che commetto io... ma questa Rom ha molte personalizzazioni che però a me ne funzionano poco più della metà... esempio...: la sezione edge... ho settato la possibilità di avere sulla parte "curva" (che poi non lo è) informazioni tipo chiamate perse, contapassi, finanza, ecc ecc. ma nonostante sia tutto attivato quando spengo lo schermo e scorri il dito velocemente, come mostra l'esempio nella sezione, semplicemente non accade nulla... poi ho impostato l'orologio nel lasso ti tempo notturno e non appare anzi in quel periodo se blocchi e sblocchi il display non si riaccende più... si sentono i rumori di utilizzo ma con display completamente nero... mentre i colori relativi ai contatti impostati nel people edge funzionano bene ma il telefono deve essere capovolto e a questo punto non serve a niente perché è piatto e se capovolto non si vede più niente... Poi non ben capito cos'è il maverik backbone debloat... C'è scritto "run in order for best debloat" ma anche se ne premi uno a caso il telefono si riavvia ma non c'è niente di diverso da prima o quantomeno non riesco a vederlo io... nel lock screen mods non tutte le funzioni si attivano e quelle che funzionano a volte non compaiono tipo il meteo e s health... poi premendo il toggle "air gesture" appare un avviso che non può funzionare se almeno una funzione non è attiva... ecco... io ho sbirciato in tutti i meandri del telefono non c'è una voce di menù riguardante l'air gesture, quantomeno non la trovo io... nemmeno tenendo premuto il toggle, che generalmente va nel menù relativo alla funzione... quando modifichi l'aspetto della barra dei toggle e poi successivamente la usi quindi scorri destra sinistra per vedere gli altri pulsanti succede che lo sfondo della barra della luminosità scompare e riappare... e se premi il flag della luminosità automatica e poi fai risalire la barra dei toggle rimane un pezzo di barra aperto e il flag non è più flaggabile cioè fa quello che deve fare ma non appare il flag all'interno del checkbox... e per ripristinare bisogna rientrare nel maverik mods e riavviare la "UI"... mi chiedevo se qualcuno l'avesse smanettata a dovere e avesse riscontrato le stesse cose e se ha trovato una soluzione se magari può discuterne qui per cercare di capire.... in ogni caso levando questi bug (definiamoli così) che sono puramente estetici nella maggior parte dei casi è una rom molto fluida e stabile... ho avuto solo un problemino con l'installazione di xposed... dopo l'installazione (la prima volta) mi è andato in bootloop... credevo fosse normale perché dopo anni di flash e mods ho imparato a non andare nel panico invece dopo 45 minuti ho capito che c'era qualcosa che non andava e ho dovuto riflashare la rom con i dovuti wipe... poi ho riprovato ed è andato tutto a buon fine... quindi "xposedintaller_3.0_alpha4.apk" e "xposed-v80.0-sdk22-arm-custom-build-by-wanam-20160211.zip" è l'accoppiata perfetta e tutto funziona per quanto riguarda il framework... attendo notizie e commenti in merito ...ciao a tutti e buon flash
    Ho iniziato una terapia di gruppo per dipendenza da flash... che droga...!!!!
    Dispositivo: Galaxy S5 SM-G900F
    Modem: G900FXXU1ANG2
  13. #9
    Jul 2014
    -Alcuni miglioramenti.
    la rom è android 5.1.1 con tema MM.
    Scusate se sono stato assente, ma ho avuto problemi.
  14. I seguenti 2 Utenti hanno ringraziato asdfghjklml per il post:
    Furmine (01-03-16),lucadalba (29-02-16)
  15. #10
    Galaxy S5 G900F
    Quote Originariamente inviato da asdfghjklml Visualizza il messaggio
    Ciao asdfghjklml... In merito all'air gesture sai dirmi come fare per settarlo... Perché come da post non trovo una voce di menú che lo gestisca... Però c'è il toggle che se premuto dice che va prima attivato... Poi per le info nello schermo curvo... Sai darmi qualche nozione in merito... Ciao grande... E grazie per tutto...
    Inviato dal mio SM-G903F usando Androidiani App
