Utente del mese: megthebest con ben 44 Thanks ricevuti nell'ultimo mese
Pagina 1 di 6 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 51
[ROM] [4.2.2] [TW] Pimpdroid 2.2 20140202 {Support for WiFi, 3G, and LTE models!}
    SGS,SGS2,SGSTab
    [ROM] [4.4.2] [TW] Pimpdroid 3.0 beta 20141021 {WiFi, 3G, and LTE!}
    ***Finalmente anche per il P52000 esiste una rom custom!***
    Credits a Restl3ss - Link su XDA
    Change-log della versione beta 4.4.2:
    3.0-4 beta 20141021
    -Kitkat support for P5220!
    -added Wanam xposed (was supposed to be there before, my bad)
    -added kitkat extSd read/write fix (big thanks to @blackcanopy)
    *Terminal:
    -Added GNU Nano 2.2.6 (invoke with nano command like on desktop)
    -Added BASH (invoke by typing bash in terminal. Much better shell than sh)
    -Added OpenSSH (invoke with ssh command in terminal)
    -Added curl
    -Added strace
    -Added mosh
    -Better OpenSSL implementation
    -Added update-alternatives command
    -*Added OPKG package manager! (it’s like apt on linux)*
    To use: Open terminal, get root, and type
    $ PATH=/data/local/bin:$PATH
    then type
    $ opkg update
    You can now install some packages! to see what’s available, type
    $ opkg list
    and to install a package, type
    $ opkg install packagename
    Note that you’ll have to set your path to /data/local/bin every time you start terminal to use anything you’ve installed via opkg.
    La 4.4.2 v3 beta4 sembra buggata, provate la beta3!
    Vecchie versioni
    Changelog della versione 2.2 stabile (la 2.5 a me dava problemi):
    Features:
    -Busybox pre-installed
    - debloated
    -deodexed
    - google experience launcher
    -some kitkat stock apps
    -android black market installed
    -apollo music player
    -rooted (obviously)
    -some systemUI theming
    -some wifi speed tweaks
    -stability tweaks
    -system wide speed tweaks
    -tweaked up system sounds, much less of an ear-sore
    -AOSP-esque notification sounds
    -xposed + wanam, lockwidget, and loser modules
    -pretty well no S-crap left on, if there's anything I've missed let me know so I can kill it.
    -Pie controls
    -Sony Bravia engine
    -USB charging
    -smooth scrolling
    -android tweaker 2 preinstalled
    >*the following features are toggled in the wanam xposed module*
    -adjustable notification typeface
    -status bar clock adjustable clock size, AM/PM style, and position
    -status bar date on/off
    -circleMOD battery
    - adjustable system notifications
    -adjustable quick tiles settings
    -enable lockscreen rotation
    -hide battery full notification
    -adjustable system sounds
    -much heavier systemUI theming
    -4 way reboot menu
    -disable / enable tethering provisions
    -adjustable status bar color
    >*the following features are enabled though the loser xposed module*
    -volume button music controls
    -double tap home button for google voice search
    >*the following feature is enabled within xposed (by ticking the relevant module)*
    -lockscreen widgets with secure lockscreen
    >other modules
    -kitkat toast notifications
    -multi-window support
    -customizable progress bars
    2.2 20140216
    -removed about 50 MB of missed bloatware
    -a little more theming
    2.2 20140214
    -multiwindow now working for all 3 builds! (xposed)
    -removed a couple of unnecessary things
    -UIprint in 3g and lte versions during flash no longer says P5210
    2.2 20140202
    *Do NOT dirty flash this build, you WILL have major problems with superuser if you do*
    -New superuser binary for all 3 builds
    -more theming for all 3 builds
    -added init.d scripts to all 3 builds
    2.2 20140131
    -Major reworking to get multiwindow working. Xposed framework MUST be installed for this to work properly
    -fully deodexed the 3g and LTE builds (wifi was always fully deodexed, other two were partially)
    -a tad more systemUI theming
    -added customizable progress bars (xposed)
    Installata, la sto testando personalmente; Purtroppo nemmeno qui gira flashplayer..
    Ho letto e provato di ogni e alla samsung son proprio falsi. Non dipende dalla versione di android, dato che sul mio s4 e tab 3 7.0 funziona.. idem sul tab 2 10.1 che montano tutte 4.2.2.. ci deve essere un qualche blocco sul dispositivo, forse dimensione schermo non ne ho idea.
    Per il resto batteria al primo giro sembra buona, e sembra funzionare tutto quello che ho testato.. tengo in valutazione!
    Chooo
    Ultima modifica di NinjaGundam; 05-11-14 alle 15:02 - Motivo: Nuova release
  2. Il seguente Utente ha ringraziato NinjaGundam per il post:
    Ingrid (13-02-14)
    Androidiano VIP L'avatar di gladiatore69
    bologna
    Galaxy S5 Galaxy S4mini Tab3
    Ringraziato 40 volte in 36 Posts
    qualcosa per il 5210 solo modello wifi c'è??
  5. #3
    SGS,SGS2,SGSTab
    Quote Originariamente inviato da gladiatore69 Visualizza il messaggio
    Segui il post che ho messo e prendi dal primo thread la versione " P5210(WiFi) 20140202 build: 2.2-2 "
    Ha fatto la rom per la versione wifi, 3g e lte.
    Stiamo anche cercando di far andare flashplayer ^_^;
    Chooo
  6. Il seguente Utente ha ringraziato NinjaGundam per il post:
    Ingrid (13-02-14)
  7. #4
    bologna
    Ok grazie la provo appena ho un po di tempo
  8. #5
    Samsung Galaxy S3
    Buonasera..
    Qualcuno usa questa rom su p5200?Potete dirmi come gira?qualche difetto? il 3g funziona bene?
    Grazie in anticipo...
  9. #6
    Jan 2014
    la sto scaricando. Qualcuno l'ha provata?
  10. #7
    bologna
    Provata sul 5210 solo wifi...direi ottima.
  11. #8
    SGS,SGS2,SGSTab
    A me sul modello 3g gira bene.
    E' uscita la versione 2.2 v4 dove funziona il multiwindows dicono, io non lo uso quindi non vi posso dire.
    NEWS : Sulla versione 2.2v1 son riuscito a fare andare flash, provo ad aggiornare alla v4, se va ancora metto una guida e\o sento per includere l'eventuale tutto nella prossima release di questa rom
    Chooo
    Ultima modifica di NinjaGundam; 18-02-14 alle 17:08
  12. Il seguente Utente ha ringraziato NinjaGundam per il post:
    gabriz81 (17-07-14)
  13. #9
    Androidiano L'avatar di Marcosax
    Conoscete un modo per installare il tema stock su questa rom?
    Ringraziato 96 volte in 79 Posts
    Il fatto che non sia nativo il multiwindows su un 10.1 fa capire quanto Samsung lucra in modo vergognoso.
    Se non erro il 7pollici lo ha.
    Sembra che si divertono a mettere caratteristiche in uno e toglierlo all altro e viceversa.
    Vergognosi...spero che noi utenti finali ne prendiamo atto e li mandiamo a quel paese.
    LG si sta attrezzando..speriamo
