Racing bean più bootloop
    Ragazzi mettendo la racing bean con firmware 587 c'è stato un errore durante l'installazione della zip dalla recovery cioè ha riportato un errore e pare non si sia installata , il risultato e che il cellulare rimane bloccato alla scritta, Sony , innanzitutto non ho ancora capito cos'è il boot e come si ripristina dal boot.
    14/055/2013 18:55:19 - INFO - <- This level is successfully initialized
    14/055/2013 18:55:19 - INFO - Flashtool Version 0.9.10.1 built on 2013-01-09 19:49:47
    14/055/2013 18:55:19 - INFO - You can drag and drop ftf files here to start flashing them
    14/055/2013 18:55:24 - INFO - Device disconnected
    14/055/2013 18:55:56 - INFO - Device connected in fastboot mode
    14/056/2013 18:56:01 - INFO - Launching Fastboot Toolbox 1.0 by DooMLoRD
    14/056/2013 18:56:01 - INFO - Device Status: FASTBOOT mode
    14/058/2013 18:58:56 - ERROR - no system (system.img or system.sin) selected!
    14/010/2013 19:10:20 - INFO - Launching Fastboot Toolbox 1.0 by DooMLoRD
    14/010/2013 19:10:20 - INFO - Device Status: FASTBOOT mode
    14/011/2013 19:11:33 - ERROR - no kernel (boot.img or kernel.sin) selected!
    14/011/2013 19:11:56 - INFO - Selected system (system.img or system.sin): C:\Flashtool\ShellFolder: 0x11\donwload
    14/011/2013 19:11:56 - INFO - Flashing selected system
    14/011/2013 19:11:56 - INFO - Please check the log before rebooting into system
    14/014/2013 19:14:20 - ERROR - no system (system.img or system.sin) selected!
    14/016/2013 19:16:02 - INFO - Selected kernel (boot.img or kernel.sin): C:\Users\Deu\Downloads\Arc Fusion v5.3\anzu.img
    14/016/2013 19:16:02 - INFO - Flashing selected kernel
    14/016/2013 19:16:04 - INFO - sending 'boot' (5760 KB)...
    14/016/2013 19:16:04 - INFO - (bootloader) USB download speed was 9187kB/s
    14/016/2013 19:16:04 - INFO - OKAY [ 0.649s]
    14/016/2013 19:16:04 - INFO - writing 'boot'...
    14/016/2013 19:16:04 - INFO - (bootloader) Download buffer format: boot IMG
    14/016/2013 19:16:04 - INFO - (bootloader) Flash of partition 'boot' requested
    14/016/2013 19:16:04 - INFO - (bootloader) S1 partID 0x00000003, block 0x00000280-0x000002e3
    14/016/2013 19:16:04 - INFO - (bootloader) Erase operation complete, 0 bad blocks encountered
    14/016/2013 19:16:04 - INFO - (bootloader) Flashing...
    14/016/2013 19:16:04 - INFO - (bootloader) Flash operation complete
    14/016/2013 19:16:04 - INFO - OKAY [ 1.613s]
    14/016/2013 19:16:04 - INFO - finished. total time: 2.263s
    14/016/2013 19:16:04 - INFO - FASTBOOT Output:
    OKAY [ 0.649s]
    writing 'boot'...
    OKAY [ 1.613s]
    14/016/2013 19:16:04 - INFO - Please check the log before rebooting into system
    14/016/2013 19:16:39 - INFO - Finished Fastboot Toolbox
    14/016/2013 19:16:46 - INFO - Finished Fastboot Toolbox
    Questo è il resoconto ho messo il kernel dal fastboot kernel fusion sperando che il telefono parta
