[KERNEL][ARC/S] LuPuS-JBv12 [JB 4.1 & 4.2]
[ARC/S][KERNEL] LuPuS-JBv12 [JB 4.1 & 4.2][LINARO 4.7.3][UPDATED 06-06-13]
Ottimo kerne, secondo me ilmigliore, per rombasate su Jelly Bean, disponibile nelle versioni 480p e 720p. Per esperienza posso affermare che, almeno fino alla v11, il wifi sulle jb 4.2.2 (nelle ultime release) non funziona.
Changelog:
v12
- Added option to enable Quick Key Reset (enable / disable via LuPuS Menu)
- Tuned Governors
* superbad
* lionheart
* virtuous
* darkside
* conservative
* smartassH3
- Really use google snappy zRam (improves zRam)
- Removed persistent RAM
- Added zCache
- Removed some more kernel debugging
- uninterruptible sleep
- Update SIO & CFQ
- Added Ultra-KSM
- Removed optimized AES & SHA1 routines
- Updated TWRP to 2.4.4
*Fixed Mount USB Storage in TWRP
- Updated CWM to latest Official CWM source
*Removed reboot options
*Re-added power off and reboot system now to main menu
- Improved wifi-loading scripts
- Clean up of lupus menu
- Fixed root issue on some devices
- Reworked kernel logs (can be found in /data/local/tmp)
- Boot.d - If phone is taking a long time to start move suspicious init.d scripts to /system/etc/boot.d
They will be run in background and won't affect boot time.
Questo kernel ha i moduli wifi integrati. Per l'installazione, leggere la guida.
