La Resurrection Remix è una ROM basata su CM, Slim, Omni e sulle build Remix originali.
Funzioni:
Based On Latest Google Android 7.1.2 release
RR Customizations:-
-Enable/Disable Navbar
-Navbar Button Customization smartbar
-Navbar Pulse
-Navbar Fling
-Double Tap To sleep navbar
-Statusbar
-Brightness Slider
-Enable/Disable Show Notification Count
-SuperUser Indicator Switch
-Double Tap To sleep Statusbar
-Carrier Label
-Carrier Label Switch
-Carrier label Color
-Carrier Label Size
-Clock Customizations
-Time & date
-Day & date Toogle
-Center/Right/Left Clock Choice
-Date Format
-Clock Font Styles
-Battery
-Battery Bar customization
-Battery Icon Customization(circle/landscape/Potrait and more)
-Battery % Text
-Network Traffic Indicator
-Network Traffic Arrows Switch
-Incoming/OutGoing Traffic
-Network traffic Color
-Statusbar RR Logo
-RR logo Color
-Position
-Custom Logos
-Logo Color
-Position
-Style
-StatusBar Weather
-Weather Color
-Weather Position(left/right)
-Weather Font Style
-Weather Size
-StatusBar Ticker
-Ticker Text color
-Ticker Icon Color
-App Circle Bar
-Choose apps in AppSidebar
-Trigger Width
-Trigger Hieght
-Trigger Position
-App Sidebar
-Choose apps in App circle
-Trigger Width
-Trigger Hieght
-Trigger Position
-Pie
-Pie Trigger(left ,Right ,Bottom)
-Pie Targets
-Pie Colors
-More Pie Features
-Recents Panel
-Clear All button Switch
-Clear All Tasks Switch
-Clear All Button Location(Top right,Top Left,Top Center,Bottom Left,Bottom Right,Bottom Center)
-Full Screen Recents
-Recents Styles
-OmniSwitch
-Advanced Reboot Menu
-Power Menu Customizations
-Power Off
-Reboot(Recovery, Bootloader, Hot Reboot)
-ScreenShot
-Power Menu End Calls Switch
-Restart SystemUI
-Airplane Mode
-ScreenRecord
-On the Go Mode
-Sound Panel
-Home Button(For devices with HW keys Only)
-Home Button answer call
-Long Press Actions
-Double Tap Actions
-Volume Buttons
-Wake Up Device
-Playback Control
-Ringtone Volume Control
-Keyboard Cursor Control
-Swap Buttons on Landscape mode
-Volume Key Answer
-Miscellaneous
-Selinux Switch (Switch Between Permissive and Enforcing Selinux if Device has Selinux Enabled)
-cLock Shortcut
-Disable Battery Saver Warning Color
-OTA U
-Cammera Shutter Sound Enable/Disable
-SystemUI Tuner
-Enabled By default
-Removed Demo mode and Tweaked SystemUI Tuner As compared To AOSP
-StatusBar Icons Cuzomizations
-Quick Settings Customizations
-Other Features
-Perfomance Profiles
-LCD Density
-Expanded Desktop Mode
-Heads Up Switch and customizations
-Live Display
-Configurable 0,90,180,270 Degree Rotation
-Lock Screen Autorotate Switch
-Native Tap to Wake From Marshmallow
-Double Tap Power Button To enable Camera gesture
-Prevent Accidental Wakeup
-Wake Phone on Charging Plug
-Battery Light Customizations
-Notification Light Customizations
-Font Size
-CM privacy guard
-Performance Tweaks(Kernel Aduitor Inbuilt)
-CM root inbuilt
-RR OTA (will come later)
-A Whole new RR Configurations
-OverAll Smoothness Improvements
-Optimizations to Improve Battery
-Includes All Android Nougat Features
-Includes ALL CM14.1 Features
-AND MUCH MUCH MORE
Google Apps (ARM64, Android 7.1.2; la variante è a scelta, io consiglio quella Nano, in modo che poi si possa scegliere se installare o meno il resto delle app)
È una bella rom anche se io in tema Lineage OS preferisco AICP e crDroid, meno personalizzabili ma con un kernel più parco nei consumi e ugualmente fluido.
06-02-17, 21:17
Fortinho
Originariamente inviato da Wawalord
Non poteva certo mancare la RR!
Come va, l'hai provata?
Ancora non l'ho provata ma credo di farlo appena posso, so che non ha bug significativi :)
Ho questa ResurrectionRemix da 3/4 giorni, ne sono contento :)
02-03-17, 03:06
marcovox
Come vanno fotocamera e batteria?
02-03-17, 10:17
BlackJack89
Originariamente inviato da marcovox
Batteria bene, meglio della miui a mio parere, arrivi fino a sera, ma con più batteria ;)
Fotocamera in linea con le altre LOS based
02-03-17, 10:42
marcovox
Originariamente inviato da BlackJack89
quindi mi stai dicendo che la fotocamera è peggiore di quella della miui?
Comunque c'è un ragazzo che dice che la RR ha una autonomia scarsa a fronte della aicp.
02-03-17, 13:33
Fortinho
Confermo quanto detto, fotocamera leggermente peggiore rispetto a quella della MIUI (è fisiologico).
Autonomia leggermente migliore rispetto alla MIUI, ma per quanto riguarda questo aspetto penso che sia anche dovuto alle build di febbraio non proprio fortunate lato batteria. Da quel che so le cose sono migliorate.
Ciao A tutti,
Ieri ho provato ad installare la RR dato che con la miui ero ormai ridotto a 2 ore di schermo
Partendo dalla miui sono riuscito a flashare la rom senza flashare anche il firmware (me lo sono perso nella lista di cose da fare). Può aver generato problemi? Ad esempio non riuscivo a proseguire nell'installazione a causa dell'errore 7 restituito dalla twrp
Ho rimesso la miui dopo 5 minuti perché il tasto home capacitivo non sembrava implementato, così come la lettura dell'impronta.
Ho perso qualcosa o è normale con questa rom?
10-09-17, 16:37
Fortinho
Originariamente inviato da snoze88
Ciao A tutti,
Ciao.
Il flash del firmware potrebbe non aver causato problemi dato che provenivi dalla MIUI, e quindi avevi già un firmware aggiornato, però flasharlo è consigliabile.
Per quanto riguarda il lettore di impronte, il comportamento che descrivi non è quello normale: il tasto home funziona sia per appunto andare alla home e sia per effettuare lo sblocco con l'impronta semplicemente sfiorandolo. Avresti dovuto dare un'occhiata nelle (numerose) opzioni della ROM.
10-09-17, 16:43
snoze88
Perfetto, grazie mille
Mi sembrava strano, sono stato decisamente frettoloso a rimettere la miui
Dopo un test della miui ripulita proverò allora a rimettere la RR sperando di riuscire ad arrivare a sera con la batteria ;) (sulla rom migliore sono aperto a suggerimenti, scriverò nell'apposito 3D)
12-09-17, 17:13
Fenomeno82
Sono curioso anch'io..tienimi aggiornato che la RR l'avevo già su sul S2 e mi trovavo bene:)
21-10-17, 12:43
snoze88
Dopo 2 settimane di utilizzo posso dirmi soddisfatto della rom
L'ho abbinata a nova launcher, dato che il pixel launcher non prevede le gestures per la discesa del menù di notifica da metà schermo
Buona la personalizzazione, anche se non ci ho messo troppo mano; molto utile la possibilità di passare in 2g a schermo spento, aiuta abbastanza i consumi
Sono ancora lontano dai consumi mostruosi che ho visto xda; con Greenify sono arrivato a circa 3 ore/ 3:10 di schermo, ancora poco per me
Dovrò tesare alcuni kernel, perché quello stock non sembra supportare l'undervoltage
Nel mentre ho visto che é uscita la release final, proverò a flasharla il prossimo weekend
Aspettando per fine anno le nuove release con oreo
Inizialmente ho avuto alcuni bug, come un Crash continuo della UI se attivavo credo Pie e Cycle bar. In quel caso l'unica é stata procedere con un factory reset
