Frenz75
Prima prova a installare questi drivers:
https://www.dropbox.com/s/tgjcv4mbvx...river.zip?dl=0
In alternativa se sai l'inglese prova questa soluzione:
SOLUTION FOR CONNECTING REDMI NOTE 3 PRO TO PC !
You need to download nothing!
The Driver you can use is just into Windows 10, the name is wpdmtp.inf
Here is network path:
C: \ Windows \ INF \ wpdmtp.inf
This is Process step by step:
1. Disconnect the phone to PC.
2. Enable 'DEVELOPER OPTIONS' : go to Settings>About Phone and tap MIUI version about 6 times, then you will see a pop up notification that you are now a developer.
3. Enable 'USB debugging' : after enabling developer option you should go to settings>additional settings>Developer options then enable USB debugging.
4. Only now you can connect your Xiaomi phone to your PC via USB cable.
5. On your computer go to PC > C drive > windows > INF > and look for wpdmtp.inf (make sure your xiaomi phone is connect via usb) then right click on the file wpdmtp and click install with your phone plugged in. You can choose others systems to gather the phone to driver, too.
For example, by Control Panel > Hardware, looking for for new device and click on right button of mouse > Property
- choose the sheet Hardware and click on Property
- in the new sheet select Change Setting
- in the new window select the sheet Driver and now click on Update driver
- in the new window select the second option 'Find driver software into the PC' (sorry, my windows is in another language)
- in the new window select the second option 'Choose manually the driver into the PC'
- in the new window select 'Disco driver' and in the new window click on 'Browse...'
- now finally choose the network path: C: \ Windows \ INF \ wpdmtp.inf and click on Open.
6. Now, finally the driver is correctly installed and you can see it in Hardware window of Control Panel.
IMPORTANT :
- When you connect via USB you have an option on the top notification of the phone.
Select:
- either to charge only, transfer photos or tranfer files. You should select transfer file!
After this steps your Xiaomi Phone will be detected by your computer and you can access immediately to its internal memory.
Ciao seguendo la guida in inglese sono riuscito a far riconoscere il mio Note 3 pro.
L`unica differenza e` che quando dal "gestione dispositivi" me lo faceva vedere, con il punto esclamativo, sono andato sul dispositivo, tasto destro,
Scegli manualmente un driver nel tuo pc, ti esce una lista di driver compatibili e li ho scelto "dispositivo MTP USB" e...
rieccoti il Note 3 pro visibile.
Ovviamente devi avere il Debug USB abilitato e sul telefonino devi scegliere "Trasferisci file MTP"...
spero di eeserti stato di aiuto.
Novità?
Inviato dal mio Redmi Note 3 utilizzando Tapatalk
