Visualizzazione dei risultati da 11 a 20 su 24
[ROM] XPERIA Z3 V3.0 Kitkat 4.4.2 Xiaomi Hongmi WCDMA (MTK6589)
  1. #11
    Feb 2015
    Are you going to port final version 4.0? Thansk!
    Ringraziato 193 volte in 169 Posts
    Quote Originariamente inviato da siba01 Visualizza il messaggio
    Fatto, vedi primo post
    Ciao
    Rosario
  4. Il seguente Utente ha ringraziato edyros2003 per il post:
    siba01 (16-04-15)
  5. #13
    Quote Originariamente inviato da edyros2003 Visualizza il messaggio
    Porting Xperia Z3 V4 for Xiaomi Hongmi WCDMA
    V 4.0 UPDATES:
    -Xperia recent apps a shake and brush was added. Now if you are able to use at any time, both the xperia small apps.
    -Rom material interface
    -Audio for improvements were made.
    -Improvement works are made for gaming performance.
    -Walkman is fixed.
    -Sony recently changed versions of the applications.
    -Dialer has changed.
    -Rom is no theme support.
    -No Art support cause incompatibilities with some sony applications
    Details and original thread here http://forum.turkdevs.com/konu-4-4-2...4-0-final.html
    download:
    https://mega.co.nz/#!mt4QVBTZ!VMy6fL...9IqYHtTzxQ-5Dw
    Xperia V3:
    Porting della z3 kitkat su Redmi 1
    Progetto originale screenshot e maggiori dettagli XPERIA Z3 V3.0 Kitkat 4.4.2 for MicroMaX Canvas 2+ A110Q (MTK6589) | Custom Android Roms
    Caratteristiche Android 4.4 KitKat su Redmi 1 WCDMA (MTK6589)
    -Multilanguage
    -Android 4.4.2
    -Android 4.4.2 Stock Camera con galleria
    -Giochi fluidi
    -Nuovo Status Bar
    -3G su entrambe SIM
    -Sim Toolkit
    -Init.d Scripts
    - Small Apps Xperia (attivabili tenendo premuto per qualche secondo il tasto Home)
    E altro.........
    Installazione :
    Utilizzare recovery custom TWRP o CWM
    1) Download della ROM (link sotto)
    2) Copiare nella Esterna/Interna SD Card
    3) Andare in recovery custom
    4) Wipe Data/Factory Reset
    5) Wipe Cache
    6) Da Advance Menu Delvik Cache Clear
    7) Installare da SD
    8) Reboot
    (Sono necessari circa 5 Min. al primo boot)
    Download:
    https://mega.co.nz/#!vpgkTSCY!2DELFY...Nxj7QiMoyUztR8
    Correzione Bug torcia:
    Integrato nella ROM per aggiornare soltanto flashare questo zip http://goo.gl/T3H5BR
    NOTA BENE: Il porting è basato sulle librerie della miui 6 ancora in fase beta e alcuni bug si risolveranno con la versione stabile
    Sviluppatore Originale della ROM :- [4.4.2] *** Xperia? Z3 v3.0 Dr.Razor? *** - TurkDevs.Com Türkiye Android Geli?tiricileri Toplulu?u
    (credit : arraki, NeedRom, xda developers, 4pda.net e Swapnil Bunjkar )
    Scusami per chi ha la versione precedente e vuole aggiornare a questa versione è necessario fare un wipe completo o basta solo quello della dalvik cache? Poi il problema della torcia si deve sempre risolvere col patch?
  6. #14
    Apr 2015
    V 4.0 UPDATES:
    download:
    Incorrect link ?
  7. #15
    Quote Originariamente inviato da osholee Visualizza il messaggio
    Basta solo un wipe dalvik cache, dovessi avere dei problemi fai una installazione pulita.
    Non c'è bisogna di nessuna patch per la torcia è già integrata nella ROM
    Rosario
  8. Il seguente Utente ha ringraziato edyros2003 per il post:
    osholee (16-04-15)
  9. #16
    @xCats
    Ho corretto il link,grazie.
    Ciao
    Rosario
  10. #17
    Edyros vorrei passare alla miui v6 però ricordo che con la rom c'erano problemi con il segnale 3g che non era mantenuto bene. Potresti postare se ci sta il link della rom v6 più aggiornato rispetto a quello che dava problemi? Ti ringrazio in anticipo.
  11. #18
    L'ultima disponibile di sviluppo ufficiale multilingua la trovi qui MULTI - 5.4.17 | Unofficial International MIUI / Xiaomi Phone Support
    download diretto qui acid's Space - xiaomi.eu_multi_HM2013023_5.4.17_v6-4.4.zip - Tweaks Paradise
    Ultima modifica di edyros2003; 20-04-15 alle 01:17
    Rosario
  12. Il seguente Utente ha ringraziato edyros2003 per il post:
    osholee (23-04-15)
  13. #19
    Bisogna reperire anche le gapps o sono comprese nella rom? Se si dove si trovano? Scusa ancora per il disturbo. P.s La twrp recovery è sempre adatta?
  14. #20
    Le gapps sono comprese la twrp va bene
    Rosario
  15. Il seguente Utente ha ringraziato edyros2003 per il post:
    osholee (23-04-15)
