Lo Zopo ZP999/3X (finalmente) si arricchisce di nuove ROM, merito del rilascio dei codici sorgente, ma soprattutto dell' instancabile impegno dei modder.
Il 20/10/2015 Juliotec ha pubblicato su Needrom la sua CHILAPOS che trovate qui
Zopo Z999 - ROM CHILAPOS (by Juliotec) 16.10.2015
ed eccone il changelog:
L'installazione si esegue tramite SP Flash (se hai Linux puoi seguire la mia guida in firma)Quote:
Chilapos v3 ZP999-20151016-151557
- compiled and modified with official stock source code mt95_l901_s5530mul_zwx_cc_kk_lte_ds_5m-cs_mul_20150825
- fixed some logcat Errors spam, like touchfilter, gsmallocation and others
- remplaced libtouchfilter.so with a better that dont do spam.
- rooted with supersu, but using symlinks from xbin/su to daemonsu, /bin/.ext/su etc, those files are su file with diferents names, supersu when is installed with the zip copy the same file and just renamed them, but i did symlinks, just sugote is su file too but have a diferent selinux type and it was changed too in the source code and its symlink, so its better do it in this way to save space, and dont copy files when you can use symlinks and selinux change types.
- removed lovelyfonts, not just the apk, I removed in the all source code, like settings, res, activity manager etc etc. so the loadingfonts error now is not showing in logcat.
- removed many apks that dont be in system, like velvet, genie widgets., cloud print, talkback, Plant3d, malposed and others, moved to vendor/opperator/app to be installed on boot and can be uninstalled or updated, to free many space in system.
- removed youtube, whatsapp and all vendor apks from system too, you can installed later.
- removed QuickSearchBox, because now its used google search box.
- removed mtklogger, mtkthermal, those apks are for eng mode, are unnecesary.
- now the ram just use 540 mb in boot,
- added 3 lines in build.prop to save battery when phone is in sleep mode.
- added recovery, bootloader in power menu so you can reboot in recovery and bootloader there.
- changed the recovery to twrp 2.8.7.0 compiled with CM12.1, now booting in my phone, with all the functions like adb sideload, usb otg, mtp and others.
- boot.img is unsecure and adb too.
- Io la trovo molto leggera rispetto alla stock. molto bloat è stato rimosso e il tasto di spegnimento da la possibilità do riavviare anche in recovery.Quote:
Important
- Install with sp flash tools and Fimware Upgrade Option
- Backup IMEI and Data
- You can use it for ZP999 or ZOPO 3X.
- Già installato SuperSU perfettamente funzionante.
- E' stato rimosso flashplayer quindi o si fa un backup prima di piallare la stock o si deve riscaricare in apk e non è facile oggi da trovare.
- Pare risolto anche il fastidioso problema dello spegnimento quando lo si scollega dalla carica ( a me qualche volta lo faceva).
- Mi sembra inoltre che sia migliorata la ricezione del segnale. Prima in camera mia prendeva malissimo, ora invece va tranquillo in 3G.
L'ho installata con SP flash tool 5 per Linux facendo Firmware Upgrade.
Con la CHILAPOS la batteria va benissimo, se non meglio, sto rimanendo piacevolmente soddisfatto.
Staccato dalla carica alle 6.00 di ieri mattina, uso non intensissimo, ma neanche blando, e impostato in modo che si spenga la notte e si riaccenda al mattino.. ebbene sono sono quasi le sei del pomeriggio ho il wifi attaccato dalle 15.00, ho fatto navigato, telefonato, e la batteria è ancora al 47%.
I primi due giorni arrivavo per miracolo all'ora di cena, ma sopo 2 cicli di carica tutto è andato al suo posto.
Qualche immagine e test del GPS effettuato con 2 app diverse (GPSTest e AndroiTS GPS Test Free) oltre a Maps:
https://www.androidiani.com/forum/at...7&d=1447754494https://www.androidiani.com/forum/at...8&d=1447754502https://www.androidiani.com/forum/at...9&d=1447754535https://www.androidiani.com/forum/at...0&d=1447754561https://www.androidiani.com/forum/at...1&d=1447754566
