Utente del mese: megthebest con ben 42 Thanks ricevuti nell'ultimo mese
Visualizzazione dei risultati da 1 a 10 su 30
[ROM-alpha] CyanogenMod 9.0.0 RC0 (Android 4.0.3)
    Androidiano L'avatar di 4ndr3
    Mar 2010
    Ringraziato 30 volte in 27 Posts
    [ROM] CyanogenMod 9.1.0a (Android 4.0.4)
    Source: https://github.com/nadlabak
    Home page: CyanogenMod 9 for Milestone A853 | android.doshaska.net
    Build from source: CM9 for Milestone - build from source | android.doshaska.net
    Changelog:
    9.1.0a (4.0.4) 11.12.2012
    - fix relaunch of some activities on keyboard slide out/in (e.g. YouTube playback, Root Explorer...)
    - CMFileManager included (backport from JB)
    - fix unwanted lcd-backlight activation by camera button while the screen is off (was related to the light sensor workaround that allows to use camera button to provoke sending of light sensor data without waiting for ALS interrupt)
    - better handling of Basband Processor panic (by maniac103) - instead of immediate reboot like in stock firmware, user is notified and can choose to postpone the reboot (e.g. when he's got some work to finish first). Note about the reason of reboot is displayed after restart.
    - workarounds for some motorola RIL issues that cause occasional data connectivity problems (by maniac103)
    - optional swap activation on boot via /system/etc/init.d/12swap
    -- requires swap partition present as third partition on sdcard
    -- swap size (in kB) is determined by persist.sys.swapsize property
    -- no persist.sys.swapsize property defined or set to 0 means no swap activation
    example how to set persist.sys.swapsize property in terminal:
    su
    setprop persist.sys.swapsize 16384
    9.1.0 (4.0.4) 05.12.2012
    notable recent fixes and features:
    - support for connecting to adhoc wifi
    - fixed wifi networking when using UPnP/DLNA apps
    - note that this build is done from the branch with removed theme engine,
    as the theme support seems to be too heavy, hurting performance of our device
    07.03.2012
    update-cm-9-20120307-SNAPSHOT-umts_sholes-signed.zip
    - video recording (not exactly smooth yet, but working nevertheless)
    - added missing sysctl to prevent RAM fragmentation (cause of gmaps freezes)
    - etc.
    03.03.2012:
    - camera is working (only taking pictures, not video recording; panorama mode is not working)
    - switched back to Calendar and LatinIME built from source (use the updated gapps-ics-4.0.3-20120302)
    - bootanimation is enabled by default, it can be disabled under performance settings
    - baseband selection is under device>advanced settings
    - usb and native wifi tethering is not working yet (but should be fixed soon, probably in the next build)
    14.01.2012:
    notes:
    - until the open source solution will be ready, Google builds of Calendar and CalendarProvider are installed via gapps to provide Google Calendar sync. Google build of LatinIME is included to provide access to downloadable dictionaries.
    - most of the gapps are installed to /data/vendor. if you are updating from earlier CM9 build, use "rm -r /system/*" in recovery console before installation to make sure you don't run out of space in /system because of previously installed gapps
    - bootanimation is disabled (debug.sf.nobootanimation=1 in build.prop), because the default bootanim takes more than 80MB of RAM while running, which may cause issues - from very long boot time to bootloops.
    Download:
    CM9.1.0a: https://github.com/downloads/nadlaba...mts_sholes.zip
    gapps: Dev-Host - gapps-ics-20120605.zip - The Ultimate Free File Hosting / File Sharing Service
    OpenRecovery 2ndbootOR: http://code.google.com/p/cyanogenmod...ootOR_v1_1.zip
    Thread su XDA
    Immagini allegate
    Ultima modifica di 4ndr3; 14-12-12 alle 15:59
  2. I seguenti 2 Utenti hanno ringraziato 4ndr3 per il post:
    FABIOT84 (15-01-12),Vinsent (18-01-12)
    Jun 2010
    Samsung Galaxy Note Edge
    Ringraziato 64 volte in 61 Posts
    Installato e va bene per essere la rc solo che non funziona il lockscreen, pin
    Samsung Galaxy Note 9 8GB - 512GB Midnight Black + Regalo microSd 512GB xc Samsung
    Samsung Galaxy Note 8 6GB - 64GB Midnight Black
    Samsung Galaxy S3 blue
    Motorola Photon 4G
    Motorola Milestone
  5. #3
    Jun 2010
    reinstallato le gapps e adesso funziona tutto tranne il pin
    Motorola Photon 4G
    Motorola Milestone
  6. #4
    l'ho provata e va benino...manca ovviamente quel pizzico di fluidità in più e purtroppo non funge la fotocamere
  7. #5
    Jun 2010
    il problema è che la fotocamera non funziona su nessuna rom mod 9 , , sembra non esserci ancora driver ufficiali rilasciati
    Motorola Photon 4G
    Motorola Milestone
  8. #6
    Exclamation
    Quote Originariamente inviato da leomaxi Visualizza il messaggio
    Vabbè sperando che lo sviluppo continui
  9. #7
    Jun 2010
    pero con app fotografiche di terze parti, la fotocamera funziona, anche se qualitativamente non esaltante pero si puo usare
    Motorola Photon 4G
    Motorola Milestone
  10. #8
    Mar 2010
    Quote Originariamente inviato da thebestluis Visualizza il messaggio
    si, kabaldan ha detto che sta lavorando in parallelo su cm7 e cm9
  11. #9
    Androidiano L'avatar di Master
    Jun 2010
    @leomaxi: Mi puoi fare un esempio? Grazie!
  12. #10
    Jun 2010
    camera 360 ma ho scoperto funzionare solo con htc desire , deve l'app base della camera non funzionava e pensavo fosse lo stesso per il mile e invece no
    Motorola Photon 4G
    Motorola Milestone
