[rom] [aosp/ics] build 33
    Androidiano L'avatar di yumer96
    Aviano, PN
    Nokia 6120c, Nexus S i9020
    Ringraziato 31 volte in 18 Posts
    AOKP
    Andoid Open Kang Project
    Changelog:
    bug fixes
    1. Bluetooth: Fixed memory leak and file handles leak
    2. Nav bar & tablet status bar FCs fixed
    3. Fixed some init.d scripts not running due to lack of bash
    4. Changing brightness by sliding on the top of the statusbar (if enabled) shouldn’t FC anymore
    5. Fixed Data toggle not updating properly
    6. Torch should be acting normally again
    7. ROM Control: Fixed scrolling cache not setting properly
    8. Weather will refresh whenever SystemUI starts instead of when the phone boots (so if it gets restarted, it should fetch weather again, it didn’t before)
    9. Lockscrens: Added lockscreen wallpapers to pin & pattern unlock screens
    10. Settings: fixed link mute states always being checked
    supersonic: Updated files (thanks to evervolv), should boot! I’ve also included a “camera hack” so it should work, Video camera will FC, so will panorama mode. It is what it is
    new features
    1. Added another ROM Control shortcut that opens ROM Control
    2. Added ability to translate weather conditions (only German is translated for now I think)
    3. Mms: added ability to strip unicode (CM)
    4. Mms: added emoji icons (CM)
    5. Mms: added quick emoji button to left of input (option you must enable)
    6. Added warnings to fast charge (will notify you if it’s enabled on boot)
    7. Hide navbar feature for tablets
    8. More music players supported for AVRCP 1.3
    Installazione:
    1. Controlla di avere l'ultima Clockworkmod recovery
    2. Fai un nandroid backup
    3. Altamente consigliato: wipe data/factory reset se si ha una vecchia versione - assolutamente richiesto se si proviene da altre rom
    4. Flasha la rom
    5. Flasha le Gapp
    6. Reboot
    Link alla rom per xoom 3g (stingray) http://teamkang.host4droid.com/sting...y_build-33.zip
    md5sum: 56204ea866c74f6cb476b5019eff6944
    Link alla rom per xoom wifi (wingray) http://teamkang.host4droid.com/wingr...y_build-33.zip
    md5sum: 9987e0bf22e95a32c468cb113513cba7
    Link alle Gapps Goo-inside.me Downloads - Downloading gapps-ics-20120317-signed.zip
    md5sum:dc560aa235e8dd8cb00df0cefb5abd38
    Link alla pagina ufficiale Build 33 - Releases - Releases - News
    Quanto ho scritto qua sopra è quanto viene detto sul sito ufficiale, ma per flashare ho usato la rogue, che dovrebbe leggere anche la memoria interna, anche se mi da errore. Conviene in ogni caso mettere lo zip nella memoria esterna.
    L'ho provata ed è ora in esecuzione sul mio xoom, va discretamente bene, la batteria dura come con le altre rom (ho lasciato i settaggi come sono di default per quanto riguarda governor, scheduler, frequenze ecc ecc ... )
    La UI ogni tanto va in crash con certe applicazioni (la barra con i tasti sparisce x 2/3 secondi e poi torna) e non fa più lo scherzo delle build precedenti che ogni tanto ripristinava lo sfondo originale. Le gapp funzionano a dovere, non danno problemi di nessun genere, funzionano a dovere le videochat su talk, i videoritrovi su google+ e i video su youtube...
    Se non fosse per il problema dei crash della UI sarebbe la migliore rom per xoom con ics, anche se già da adesso mi sembra meglio della eos...
    Immagini allegate
    <== Il tasto Thanks! è qui! Perchè non usarlo?
    Ringraziato 187 volte in 150 Posts
    E utms-everest ? Ovvero per il nostro 3g mz601 ? Perche stingray e' un altra cosa ...
    Xoom : team eos 4
    Maguro : VanirAOSP 4.4.4 ART F2FS / TWRP 2.7.1.1 f2fs / SmittyV-UR-NoMeM
    Sep 2009
    Quote Originariamente inviato da Nemis Visualizza il messaggio
    +1
    io ho provato e non vado oltre la pagia di welcome!
    L.
    Aviano, PN
    Ho propio il mz601, funziona bene....
    Ieri è uscita la build 34, adesso aggiorno...
    Aggiungo che non ho ancora provato a usare il modulo 3g per navigare, non ho mai inserito una sim nel tablet....
    Ultima modifica di yumer96; 25-04-12 alle 18:02
    Aviano, PN
    Hai fatto i soliti wipe?
    Non so se puo essere questo, ma io ancora con Honeycomb stoc avevo criptato la sd interna, perciò prima di installare ho fatto dal pc il rispristino, flashando le img stoc e poi installando (soprattutto x la boot) trovi la discussione iniziata da barabba qui (https://www.androidiani.com/forum/mo...originale.html) prova e poi dimmi
    Oppure prova da pc dando:
    fastboot erase linux
    fastboot erase recovery
    fastboot erase system
    fastboot erase userdata
    fastboot erase cache
    e poi riflashare la recovery e la rom.
    A proposito, che recovery hai?
    Ultima modifica di yumer96; 25-04-12 alle 17:35
    Aviano, PN
    *** BUILD 34 ***
    È uscita la build 34!
    ecco il changelog:
    • fixed mobile data toggle not updating for serious
    • fix navigation buttons for tablets
    • long press home options added to General Interface for phones that have hardware buttons
    • fix icon transparency being applied to right-side buttons (BT, etc)
    • updated NovaLauncher to 1.1.1
    • Add BT MAP Profile
    • fix font sizing in statusbar
    • fixed volume sliders not updating when volumes are linked
    • many fixes for ColorPicker in ROM Control
    • fixed sound playing when volume zoom is enabled in camera
    • last.fm AVRCP crash fixed
    • contact pictures now displaying properly in notifications when receiving new sms
    • many other things! check out all the commits at http://gerrit.sudose...atus:merged,n,z
    *** INSTALLAZIONE ***
    • Fare un Nandroid backup
    • Altamente raccomandato: wipe data/factory reset -- Assolutamente richiesto se si viene da altre rom
    • Flash della rom
    • Flash delle gapps
    • Reboot
    Link:
    - download (stingray) http://teamkang.host4droid.com/sting...y_build-34.zip
    md5sum: 1a5d0d00031a94f7c4f4d92eb5ee44e4
    - download (wingray) http://teamkang.host4droid.com/wingr...y_build-34.zip
    md5sum: 31a4c4ef56b11b5748e00ffc228e13ad
    - download gapps ( 20120422 ) Goo-inside.me Downloads - Downloading gapps-ics-20120422-signed.zip
    md5sum: 0b30df25505799b5e10c0b6409f73137
    Aviano, PN
    Sto controllando le nuove rom per ics, eccone una che promette bene https://www.androidiani.com/forum/mo...ml#post1462395
    Dato che il tablet serve a mio papà per lavorare, è ovvio che non posso provare ogni singola rom che esce (come invece faccio sul nexus s) ma sembra buona!
  9. #8
    Sep 2009
    Quote Originariamente inviato da yumer96 Visualizza il messaggio
    Purtroppo la versione per stingray supporta le reti cdma e non la gsm. Il ma se usate solo il wifi tutto sembra funzionare.
    La codenameandroid.org Android e ottima ma al momento non più sviluppata.
    L.
    Inviato dal mio Xoom usando Tapatalk
