Ringrazio per il link.
Comunque ha funzionato anche quello che ho fatto io....
scaricato l'OTA...andato in RecoveryTWRP...pulito dalvik e cache...disinstallato magisk...installata la ROM...installato magisk...installata di nuovo la twrp cosi da sovrascrivere quella originale della open beta....infine riavviato.
Per ora tutto ok :)
Disponibile la Oxygen OS Open Beta 16
http://otafsg1.h2os.com/patch/amazon...79fe7a019e.zip
Changelog:
Camera
• Fixed beauty mode (now applies to photos from the rear camera)
• Improved stability of portrait mode for the front camera
Weather
• Improved stability of the Weather app
System
• General bug fixes and improvements
forum Ufficiale OnePlus
https://forums.oneplus.com/threads/o...lus-5t.903489/
Ecco la Open Beta 17
http://oxygenos.oneplus.net.s3.amazo...5dfd204bcc.zip
Changelog:
System
•Updated Android security patch to 2018.9
Weather
•Optimized UI for the Weather App
OnePlus Switch
•Added manual connection method if unable to connect switch with QR code on the old device
•Supported backup and recovery for application data including home screen, lock screen and APP layout
•Bug fixes and support for more Android models
Forum Ufficiale OnePlus (https://forums.oneplus.com/threads/o...lus-5t.912669/)
Inviato dal mio ONEPLUS A6003 utilizzando Tapatalk
Disponibile la Open Beta 18
http://otafsg1.h2os.com/patch/amazon...2e536a2d5c.zip
Changelog:
Gallery
• Supported new gesture to close picture by sliding down in gallery app
Community
• Community notices added as a feature
• New feed for following community members
• Stickied comments displayed on the app
• Added more options to share threads
• General user interface tweaks and bug fixes
Disponibile la nuova Oxygen OS 5.1.6
Changelog
System
•Supported Project Treble
•Supported IDEA India VoLTE (Default On)
•Improved Bluetooth stability for phone calls
•Updated Android security patch to 2018/ 10
forum ufficiale
https://forums.oneplus.com/threads/o...s-5-5t.929455/
Nuova Oxygen OS Open Beta 19
https://otafsg.h2os.com/patch/amazon...2c2665682a.zip
Changelog
System
• Updated Android security patch to 2018.10
OnePlus forum: https://forums.oneplus.com/threads/o...lus-5t.931603/
Disponibile Android Pie per OnePlus 5T con la rom Open Beta 20
Changelog
System
•Updated system to Android™ 9.0 Pie™
•Brand new UI for Android Pie
•Brand new navigation gestures (this is only for 5T)
•Updated Android security patch to 2018.11
•Optimizations for background app process handling
Do Not Disturb mode
•New Do Not Disturb mode with adjustable settings
Communication
•UI Improvements for emergency rescue
•Optimized UI for speed dial and calling interface
•Now able to assign a specific SIM for a specific contact or group of contacts when using dual SIM
Parallel Apps
•Added support for more apps (Telegram, Discord, IMO, Uber, OLA) in parallel apps
Weather
•Now able to switch dynamically to your current location
•Display more suggestions when the search function is used
•Fixed an issue that prevented the app from refreshing when the location is changed
•Fixed an issue that resulted in some users being unable to find certain locations
Links
• Thread: Forum
https://forums.oneplus.com/threads/o...lus-5t.954677/
edit:
• link full rom
https://otafsg.h2os.com/patch/amazon...31_d9e594c.zip
