errore in admob
Ciao!
Sto seguento un tutorial x inserire ad mob nella mia app con eclipse...
ma non capisco come mai quando inserisco
nel file main.xml
<LinearLayout
xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:myapp="http://schemas.android.com/apk/res/admobsimo.packadsimo.infoadmobsimo"
android:orientation="vertical"
android:layout_width="fill_parent"
android:layout_height="fill_parent">
<com.admob.android.ads.AdView
android:id="@+id/ad"
android:layout_height="wrap_content"
myapp:backgroundColor="#000000"
myapp:primaryTextColor="#FFFFFF"
myapp:secondaryTextColor="#CCCCCC"
</LinearLayout>
mi da errore all’ altezza della linea <com.admob.android.ads.AdView
Multiple annotations found at this line:
- error: No resource identifier found for attribute
'secondaryTextColor' in package
'admobsimo.packadsimo.infoadmobsimo'
'backgroundColor' in package 'admobsimo.packadsimo.infoadmobsimo'
'primaryTextColor' in package 'admobsimo.packadsimo.infoadmobsimo'
da errore anke in admobsimo.packadsimo.infoadmobsimo - AdmosimpleActivity.java in setContentView(R.layout.main); dice ke R cannot be resolved to a variable
il mio file AndroidManifest.xml è il seguente e non da errori:
<?xml version="1.0" encoding="utf-8"?>
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
package="admobsimo.packadsimo.infoadmobsimo"
android:versionCode="1"
android:versionName="1.0" >
<uses-sdk android:minSdkVersion="8" />
<application android:icon="@drawable/icon" android:label="@string/app_name" android:theme="@android:style/Theme.NoTitleBar">
<activity android:name=".adMain"
android:label="@string/app_name">
<intent-filter>
<action android:name="android.intent.action.MAIN" />
<category android:name="android.intent.category.LAUNCHER" />
</intent-filter>
</activity>
<!-- The application's publisher ID assigned by AdMob -->
<meta-data android:value="mioid" android:name="ADMOB_PUBLISHER_ID" />
<!-- AdMobActivity definition -->
<activity android:name="com.admob.android.ads.AdMobActivity"
android:theme="@android:style/Theme.NoTitleBar.Fullscreen"
android:configChanges="orientation|keyboard|keyboa rdHidden" />
<!-- Track Market installs -->
<receiver android:name="com.admob.android.ads.analytics.Inst allReceiver"
android:exported="true">
<intent-filter>
<action android:name="com.android.vending.INSTALL_REFERRER " />
</intent-filter>
</receiver>
</application>
<uses-permission android:name="android.permission.INTERNET" />
</manifest>
spero possiate aiutarmi grazie mille ciao!
Prova ad aggiungere questo attributo al LinearLayout che contiene tutto il tuo layout:
xmlns:ads="http://schemas.android.com/apk/lib/com.google.ads"
Poi fai attenzione alla versione di API con cui compili l'app; per far funzionare AdMob devi compilare per Android 3.2 API 13
oltre ad mob come posso inserire pubblicita nelle mie app android???
grazie mille
Originariamente inviato da Galaxy2Simo
grazie mille
Provider alternativi a admob non ne conosco. Se invece vuoi mettere la tua pubblicità ti basta una imageview cliccabile con file da far scaricare alla tua app da un tuo server.
scusami ma non ho capito l image view...usando app inventor???
Galaxy2Simo
Su AppInventor non so aiutarti; probabilmente esiste un elemento imageview che puoi trascinare sul tuo layout. Poi dovresti fare in modo che la sorgente dell'immagine sia su web.
