		calendario in eclipse
		Ehi ciao a tutti.. ho implementato questa parte di codice consultando il web per creare un sistema calendario gregoriano.. ma purtroppo mi da svariati errori, qualcuno saprebbe dirmi cosa manca?
 Qui sotto c'è il codice seguito dai relativi errori
 grazie in anticipo :)
 package simple.calendar;
 import java.text.ParseException;
 import java.text.SimpleDateFormat;
 import java.util.ArrayList;
 import java.util.Calendar;
 import java.util.Date;
 import java.util.GregorianCalendar;
 import java.util.HashMap;
 import java.util.List;
 import java.util.Locale;
 import android.R;
 import android.app.Activity;
 import android.content.Context;
 import android.graphics.Color;
 import android.os.Bundle;
 import android.text.format.DateFormat;
 import android.util.Log;
 import android.view.LayoutInflater;
 import android.view.View;
 import android.view.ViewGroup;
 import android.view.View.OnClickListener;
 import android.widget.BaseAdapter;
 import android.widget.Button;
 import android.widget.GridView;
 import android.widget.ImageView;
 import android.widget.TextView;
 public class SimpleCalendarViewActivity extends Activity implements OnClickListener
 private static final String tag = "SimpleCalendarViewActivity";
 private Button selectedDayMonthYearButton;
 private Button currentMonth;
 private ImageView prevMonth;
 private ImageView nextMonth;
 private GridView calendarView;
 private GridCellAdapter adapter;
 private Calendar _calendar;
 private int month, year;
 private final DateFormat dateFormatter = new DateFormat();
 private static final String dateTemplate = "MMMM yyyy";
 /** Called when the activity is first created. */
 @Override
 public void onCreate(Bundle savedInstanceState)
 super.onCreate(savedInstanceState);
 setContentView(R.layout.simple_calendar_view);
 _calendar = Calendar.getInstance(Locale.getDefault());
 month = _calendar.get(Calendar.MONTH) + 1;
 year = _calendar.get(Calendar.YEAR);
 Log.d(tag, "Calendar Instance:= " + "Month: " + month + " " + "Year: " + year);
 selectedDayMonthYearButton = (Button) this.findViewById(R.id.selectedDayMonthYear);
 selectedDayMonthYearButton.setText("Selected: ");
 prevMonth = (ImageView) this.findViewById(R.id.prevMonth);
 prevMonth.setOnClickListener(this);
 currentMonth = (Button) this.findViewById(R.id.currentMonth);
 currentMonth.setText(dateFormatter.format(dateTemp  late, _calendar.getTime()));
 nextMonth = (ImageView) this.findViewById(R.id.nextMonth);
 nextMonth.setOnClickListener(this);
 calendarView = (GridView) this.findViewById(R.id.calendar);
 // Initialised
 adapter = new GridCellAdapter(getApplicationContext(), R.id.calendar_day_gridcell, month, year);
 adapter.notifyDataSetChanged();
 calendarView.setAdapter(adapter);
 * @param month
 * @param year
 private void setGridCellAdapterToDate(int month, int year)
 _calendar.set(year, month - 1, _calendar.get(Calendar.DAY_OF_MONTH));
 public void onClick(View v)
 if (v == prevMonth)
 if (month <= 1)
 month = 12;
 year--;
 else
 month--;
 Log.d(tag, "Setting Prev Month in GridCellAdapter: " + "Month: " + month + " Year: " + year);
 setGridCellAdapterToDate(month, year);
 if (v == nextMonth)
 if (month > 11)
 month = 1;
 year++;
 else
 month++;
 Log.d(tag, "Setting Next Month in GridCellAdapter: " + "Month: " + month + " Year: " + year);
 @Override
 public void onDestroy()
 Log.d(tag, "Destroying View ...");
 super.onDestroy();
 // Inner Class
 public class GridCellAdapter extends BaseAdapter implements OnClickListener
 private static final String tag = "GridCellAdapter";
 private final Context _context;
 private final List<String> list;
 private static final int DAY_OFFSET = 1;
 private final String[] weekdays = new String[]{"Sun", "Mon", "Tue", "Wed", "Thu", "Fri", "Sat"};
 private final String[] months = {"January", "February", "March", "April", "May", "June", "July", "August", "September", "October", "November", "December"};
 private final int[] daysOfMonth = {31, 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31};
 private final int month, year;
 private int daysInMonth, prevMonthDays;
 private int currentDayOfMonth;
 private int currentWeekDay;
 private Button gridcell;
 private TextView num_events_per_day;
 private final HashMap eventsPerMonthMap;
 private final SimpleDateFormat dateFormatter = new SimpleDateFormat("dd-MMM-yyyy");
 // Days in Current Month
 public GridCellAdapter(Context context, int textViewResourceId, int month, int year)
 super();
 this._context = context;
 this.list = new ArrayList<String>();
 this.month = month;
 this.year = year;
 Log.d(tag, "==> Passed in Date FOR Month: " + month + " " + "Year: " + year);
 Calendar calendar = Calendar.getInstance();
 setCurrentDayOfMonth(calendar.get(Calendar.DAY_OF_  MONTH));
 setCurrentWeekDay(calendar.get(Calendar.DAY_OF_WEE  K));
 Log.d(tag, "New Calendar:= " + calendar.getTime().toString());
 Log.d(tag, "CurrentDayOfWeek :" + getCurrentWeekDay());
 Log.d(tag, "CurrentDayOfMonth :" + getCurrentDayOfMonth());
 // Print Month
 printMonth(month, year);
 // Find Number of Events
 eventsPerMonthMap = findNumberOfEventsPerMonth(year, month);
 private String getMonthAsString(int i)
 return months[i];
 private String getWeekDayAsString(int i)
 return weekdays[i];
 private int getNumberOfDaysOfMonth(int i)
 return daysOfMonth[i];
 public String getItem(int position)
 return list.get(position);
 @Override
 public int getCount()
 return list.size();
 * @param mm
 * @param yy
 private void printMonth(int mm, int yy)
 Log.d(tag, "==> printMonth: mm: " + mm + " " + "yy: " + yy);
 // The number of days to leave blank at
 // the start of this month.
 int trailingSpaces = 0;
 int daysInPrevMonth = 0;
 int prevMonth = 0;
 int prevYear = 0;
 int nextMonth = 0;
 int nextYear = 0;
 int currentMonth = mm - 1;
 String currentMonthName = getMonthAsString(currentMonth);
 daysInMonth = getNumberOfDaysOfMonth(currentMonth);
 Log.d(tag, "Current Month: " + " " + currentMonthName + " having " + daysInMonth + " days.");
 // Gregorian Calendar : MINUS 1, set to FIRST OF MONTH
 GregorianCalendar cal = new GregorianCalendar(yy, currentMonth, 1);
 Log.d(tag, "Gregorian Calendar:= " + cal.getTime().toString());
 if (currentMonth == 11)
 prevMonth = currentMonth - 1;
 daysInPrevMonth = getNumberOfDaysOfMonth(prevMonth);
 nextMonth = 0;
 prevYear = yy;
 nextYear = yy + 1;
 Log.d(tag, "*->PrevYear: " + prevYear + " PrevMonth:" + prevMonth + " NextMonth: " + nextMonth + " NextYear: " + nextYear);
 else if (currentMonth == 0)
 prevMonth = 11;
 prevYear = yy - 1;
 nextYear = yy;
 nextMonth = 1;
 Log.d(tag, "**--> PrevYear: " + prevYear + " PrevMonth:" + prevMonth + " NextMonth: " + nextMonth + " NextYear: " + nextYear);
 else
 nextMonth = currentMonth + 1;
 nextYear = yy;
 prevYear = yy;
 Log.d(tag, "***---> PrevYear: " + prevYear + " PrevMonth:" + prevMonth + " NextMonth: " + nextMonth + " NextYear: " + nextYear);
 // getDay() returns 0 for Sunday.
 int currentWeekDay = cal.get(Calendar.DAY_OF_WEEK) - 1;
 trailingSpaces = currentWeekDay;
 Log.d(tag, "Week Day:" + currentWeekDay + " is " + getWeekDayAsString(currentWeekDay));
 Log.d(tag, "No. Trailing space to Add: " + trailingSpaces);
 Log.d(tag, "No. of Days in Previous Month: " + daysInPrevMonth);
 if (cal.isLeapYear(cal.get(Calendar.YEAR)) && mm == 1)
 ++daysInMonth;
 // Trailing Month days
 for (int i = 0; i < trailingSpaces; i++)
 Log.d(tag, "PREV MONTH:= " + prevMonth + " => " + getMonthAsString(prevMonth) + " " + String.valueOf((daysInPrevMonth - trailingSpaces + DAY_OFFSET) + i));
 list.add(String.valueOf((daysInPrevMonth - trailingSpaces + DAY_OFFSET) + i) + "-GREY" + "-" + getMonthAsString(prevMonth) + "-" + prevYear);
 // Current Month Days
 for (int i = 1; i <= daysInMonth; i++)
 Log.d(currentMonthName, String.valueOf(i) + " " + getMonthAsString(currentMonth) + " " + yy);
 if (i == getCurrentDayOfMonth())
 list.add(String.valueOf(i) + "-BLUE" + "-" + getMonthAsString(currentMonth) + "-" + yy);
 else
 list.add(String.valueOf(i) + "-WHITE" + "-" + getMonthAsString(currentMonth) + "-" + yy);
		// Leading Month days
 for (int i = 0; i < list.size() % 7; i++)
 Log.d(tag, "NEXT MONTH:= " + getMonthAsString(nextMonth));
 list.add(String.valueOf(i + 1) + "-GREY" + "-" + getMonthAsString(nextMonth) + "-" + nextYear);
 * @param year
 * @param month
 * @return
 private HashMap findNumberOfEventsPerMonth(int year, int month)
 HashMap map = new HashMap<String, Integer>();
 // DateFormat dateFormatter2 = new DateFormat();
 // String day = dateFormatter2.format("dd", dateCreated).toString();
 // if (map.containsKey(day))
 // Integer val = (Integer) map.get(day) + 1;
 // map.put(day, val);
 // else
 // map.put(day, 1);
 return map;
 @Override
 public long getItemId(int position)
 return position;
 @Override
 public View getView(int position, View convertView, ViewGroup parent)
 View row = convertView;
 if (row == null)
 LayoutInflater inflater = (LayoutInflater) _context.getSystemService(Context.LAYOUT_INFLATER_  SERVICE);
 row = inflater.inflate(R.layout.calendar_day_gridcell, parent, false);
 // Get a reference to the Day gridcell
 gridcell = (Button) row.findViewById(R.id.calendar_day_gridcell);
 gridcell.setOnClickListener(this);
 // ACCOUNT FOR SPACING
 Log.d(tag, "Current Day: " + getCurrentDayOfMonth());
 String[] day_color = list.get(position).split("-");
 String theday = day_color[0];
 String themonth = day_color[2];
 String theyear = day_color[3];
 if ((!eventsPerMonthMap.isEmpty()) && (eventsPerMonthMap != null))
 if (eventsPerMonthMap.containsKey(theday))
 num_events_per_day = (TextView) row.findViewById(R.id.num_events_per_day);
 Integer numEvents = (Integer) eventsPerMonthMap.get(theday);
 num_events_per_day.setText(numEvents.toString());
 // Set the Day GridCell
 gridcell.setText(theday);
 gridcell.setTag(theday + "-" + themonth + "-" + theyear);
 Log.d(tag, "Setting GridCell " + theday + "-" + themonth + "-" + theyear);
 if (day_color[1].equals("GREY"))
 gridcell.setTextColor(Color.LTGRAY);
 if (day_color[1].equals("WHITE"))
 gridcell.setTextColor(Color.WHITE);
 if (day_color[1].equals("BLUE"))
 gridcell.setTextColor(getResources().getColor(R.co  lor.static_text_color));
 return row;
 @Override
 public void onClick(View view)
 String date_month_year = (String) view.getTag();
 selectedDayMonthYearButton.setText("Selected: " + date_month_year);
 try
 Date parsedDate = dateFormatter.parse(date_month_year);
 Log.d(tag, "Parsed Date: " + parsedDate.toString());
 catch (ParseException e)
 e.printStackTrace();
 public int getCurrentDayOfMonth()
 return currentDayOfMonth;
 private void setCurrentDayOfMonth(int currentDayOfMonth)
 this.currentDayOfMonth = currentDayOfMonth;
 public void setCurrentWeekDay(int currentWeekDay)
 this.currentWeekDay = currentWeekDay;
 public int getCurrentWeekDay()
 return currentWeekDay;
 L ultima parte di codice
		ERRORI:
 [2011-12-12 17:56:49 - SimpleCalendarImp]     (skipping index file 'C:\Documents and Settings\R.salvioni\Desktop\progetto eclipse\progetti\eclipse\SimpleCalendarImp\res\dra  wable\Thumbs.db')
 [2011-12-12 17:56:49 - SimpleCalendarImp]     (skipping index file 'C:\Documents and Settings\R.salvioni\Desktop\progetto eclipse\progetti\eclipse\SimpleCalendarImp\res\dra  wable-hdpi\Thumbs.db')
 [2011-12-12 17:56:49 - SimpleCalendarImp]     (skipping index file 'C:\Documents and Settings\R.salvioni\Desktop\progetto eclipse\progetti\eclipse\SimpleCalendarImp\res\dra  wable-ldpi\Thumbs.db')
 [2011-12-12 17:56:49 - SimpleCalendarImp]     (skipping index file 'C:\Documents and Settings\R.salvioni\Desktop\progetto eclipse\progetti\eclipse\SimpleCalendarImp\res\dra  wable-mdpi\Thumbs.db')
 [2011-12-12 17:56:49 - SimpleCalendarImp] C:\Documents and Settings\R.salvioni\Desktop\progetto eclipse\progetti\eclipse\SimpleCalendarImp\res\lay  out\calendar_day_gridcell.xml:9: error: Error: No resource found that matches the given name (at 'style' with value '@style/calendar_event_style').
 [2011-12-12 17:56:50 - SimpleCalendarImp] Error in an XML file: aborting build.
 [2011-12-12 17:57:56 - SimpleCalendarImp]     (skipping index file 'C:\Documents and Settings\R.salvioni\Desktop\progetto eclipse\progetti\eclipse\SimpleCalendarImp\res\dra  wable\Thumbs.db')
 [2011-12-12 17:57:56 - SimpleCalendarImp]     (skipping index file 'C:\Documents and Settings\R.salvioni\Desktop\progetto eclipse\progetti\eclipse\SimpleCalendarImp\res\dra  wable-hdpi\Thumbs.db')
 [2011-12-12 17:57:56 - SimpleCalendarImp]     (skipping index file 'C:\Documents and Settings\R.salvioni\Desktop\progetto eclipse\progetti\eclipse\SimpleCalendarImp\res\dra  wable-ldpi\Thumbs.db')
 [2011-12-12 17:57:56 - SimpleCalendarImp]     (skipping index file 'C:\Documents and Settings\R.salvioni\Desktop\progetto eclipse\progetti\eclipse\SimpleCalendarImp\res\dra  wable-mdpi\Thumbs.db')
 [2011-12-12 17:57:56 - SimpleCalendarImp] C:\Documents and Settings\R.salvioni\Desktop\progetto eclipse\progetti\eclipse\SimpleCalendarImp\res\lay  out\calendar_day_gridcell.xml:9: error: Error: No resource found that matches the given name (at 'style' with value '@style/calendar_event_style').ù
 E gli errori
