Pagina 1 di 4 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 38
[ ROM ][JB-XXMB4] KYRILLOSv7B **Fast n' Lite** [01/03/2013]
    Senior Droid L'avatar di iSNoW
    Livorno
    Ringraziato 121 volte in 108 Posts
    Nota: Tutti i crediti vanno all'utente kyrillos13 di XDA, io mi sono solo limitato a riportarla su androidiani.
    Nota: Non mi ritengo responsabile per danni provocati o brick in seguito all'installazione della rom
    Specifiche
    • Based on JellyBean: I8160XXMF1 [03 June 2013] ~new
    • Rooted [SuperSU v1.34]
    • Default Governor: Ondemand (+ up_threshold set to 80)
    • Deodexed & Zipaligned
    • All system apps except SuperSU moved to preload partition [More space on system!]
    • 4way-reboot options
    • CRT-OFF Animation
    • More AOSP JB like theme (+ JB framework/systemui layouts, +black statusbar, +aosp jb app icons) ~in progress
    • Disabled edge zoom
    • AOSP lockscreen toggle [+Unlock with menu key disabled]
    • Ripple Effect toggle
    • Disabled scrolling cache
    • Disabled switch input method notification icon while typing
    • Disabled home button lag
    • Long-press Back to Kill app ~new
    • Removed blotware
    • Enabled scrolling wallpaper on TouchWiz Launcher
    • Init.d support
    • Disabled increasing ringtone
    • New, better optimize script [+New zipalign/sqlite3 binaries]
    • New Sounds/ringtones
    • Build.prop tweaks [Updated]
    • GPS tweaks
    • Init.d tweaks [Updated]
    • Sysctl tweaks [Updated]
    • Ripple Effect toggle added to Lockscreen Settings
    • Ad-free
    • Messaging MOD: Up to 1000 Recipients, SMS to MMS auto-conversion disabled, Schedules Messages, Save/Restore Messages, Sent time instead of received ~new
    • Camera/Camecorder MOD: Use flash at any % battery level & while in call, Shutter sound toggle. ~new
    • Dialer MOD: SMS/MMS are now hidden from Call Log ~new
    • Updated Timezone files to 2013b (previous: 2012c) ~new
    • Installation of non-market apps enabled by default ~new
    • Device Status set to "Official" instead of "Custom" ~new
    • Supercharged! ~new
    • Exchange Security Disabled
    Downloads
    1.Stock I8160XXMF1 firmware [Download: I8160 OXAMB4 Leaked]
    2.CWM Recovery 6.0.2.8 [Download: [JB] CWM Recovery 6 - xda-developers]
    3.Odin (per flashare la MF1) [Download: Dev-Host - Odin307.rar ]
    4.Kyrillos ROM v8 XXMF1 ROM [Download: http://d-h.st/C8K]
    Instruzioni Installazione
    1. Assicurati di avere la I8160XXMF1 Jelly Bean installata e la Temporary CWM6 nella scheda SD esterna. Se non li hai già:
    -Segui questa guida per flashare la stock MF1.
    -Copia la CWM6 temporanea nella tua scheda SD esterna.
    2.Copia la KYRILLOSv8 nella tua scheda SD.
    3.Premi Vol up + Home + Tasto accensione per entrare in Recovery.
    4.Parte 1: Stock Recovery:
    - Wipe data/factory reset
    - Apply Update from external storage
    - Seleziona la CWM6 che hai scaricato prima.
    5.Parte 2: CWM6 Recovery
    - Apparirà la CWM6 Recovery!
    - Vai a mounts and storage
    - Mount: system, cache, data, preload (Attenzione: Monta queste partizioni o l'installazione non sarà completa!!)
    - Torna indietro, seleziona install zip from sdcard, scegli zip from sdcard, scegli KYRILLOSv8_JB_XXMF1.zip.
    - Aspetta che l'installazione sia completata e poi seleziona reboot system now
    6. Divertiti!
    Extra
    Screenshots
    Ultima modifica di iSNoW; 27-06-13 alle 20:28
    Smartphone attuali: Moto G 2014
    Smartphone precedenti: Xiaomi Mi5 - LG Nexus 5x - OnePlus One - LG Nexus 4 - Samsung Galaxy Ace 2 - Brondi Glory 2
  2. I seguenti 4 Utenti hanno ringraziato iSNoW per il post:
    asdroid (23-02-13),MrMat (23-02-13),peppnnn (06-03-13),RicoStyle (02-03-13)
    Ringraziato 896 volte in 608 Posts
    c'è già un post delle rom di kyrillos, lo prossima volta magari avvisa, ti avrei passato il mio thread, senza incasinare con 50000 post sul forum
    E' una buona rom, ma sta uscendo la MB4, sicuramente la aggiornerà, peccato che molti elementi non sono tradotti..
    Ultima modifica di mkel91; 23-02-13 alle 16:55
    Motorola Moto G 16gb : Official CyanogenMod 12.1 - CM 12.1 Kernel - Bootloader unlocked
    Lenovo TAB 2 A7 30-H: Stock Lenovo Lollipop - Android 5.0.1
    I miei lavori - My Works: The Italian Job Series for Galaxy Ace 2
  5. #3
    Livorno
    Scusa non avevo visto. Magari chiediamo a un moderatore di unire i 2 post.
  6. #4
    Androidiano L'avatar di MoonHe
    Ferrara
    Galaxy Ace 2
    Ringraziato 31 volte in 11 Posts
    Quando esce la MB4 aggiorno il primo post del Thread su MB2 :0
    Comunque sono tentato dall'installare la Krillos, solo che oggi o domani esce la MB4....e se hanno risolto i bug...meglio aspettare quella D:
  7. #5
    Livorno
    Quote Originariamente inviato da MoonHe Visualizza il messaggio
    Io l'ho appena flashata soltanto per il tema, il verde è veramente brutto!
  8. #6
    Ferrara
    Galaxy Ace 2
    Il verde? :0 Quale verde?
  9. #7
    Livorno
    Il verde della batteria e nelle impostazioni della stock, invece questa ROM è tutta nera e blu, contrasto molto più piacevole a mio parere.
    Cmq ho notato che in questa Rom nn c'è bisogno di usare no-frills cpu, è già tutto settato a dovere.
  10. #8
    è tutto settato nel suo script, ho dato un'occhiata allo script
    ragazzi non usate ram manager, ha già settato lui i valori idonei..
    @iSnow: potrei darti un suggerimento? per una migliore visibilità, abbassa la risoluzione delle immagini a 320x240, ne gioverà molto
    Ultima modifica di mkel91; 23-02-13 alle 19:36
  11. #9
    Livorno
    Quote Originariamente inviato da mkel91 Visualizza il messaggio
    Come si fa? Ahahahahha ogni volta che parlo con te mi sento sempre più ignorante!
    Edit: forse ho capito! bisogna modificare lcd_density nel build.prop? ma qual'è il valore da inserire? io ora ho 240.
    Ultima modifica di iSNoW; 23-02-13 alle 19:56
  12. #10
    no no, mi sono espresso male io, scusami, dicevo le immagini del forum qui, se riesci mettile a risoluzione 320x480, diventeranno più piccole e si vedrà meglio
    Tranquillo, siamo qui tutti quanti per imparare
