Utente del mese: bluemask con ben 32 Thanks ricevuti nell'ultimo mese
Pagina 1 di 12 12311 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 114
[DEV][ROM][4.1.2][JZO54K] Unofficial CyanogenMod10 for GT-S7500 | Alpha #2 | 28/2
    Androidiani Power User L'avatar di imre
    Bologna
    Nexus 5
    Ringraziato 1,000 volte in 466 Posts
    CyanogenMod 10 for Samsung Galaxy Ace Plus (GT-S7500) aka trebon
    CyanogenMod 10 is a free, community built, aftermarket firmware distribution of Android 4.1.2 (Jellybean), which is designed to increase performance and reliability over stock Android for your device.
    Generic Source Code - http://github.com/cyanogenmod
    Features - Features | CyanogenMod
    Device Config Source - https://github.com/parudthz/cm_device_samsung_trebon
    Kernel Source Code - https://github.com/parudthz/android_...msung_msm7x27a
    Cosa funziona :
    * Full GPU acceleration
    * RIL (calls/sms/mobile data)
    * Touchscreen
    * Touch keys
    * Multitouch
    * Audio
    * ADB
    * Mounting of internal/external storage
    * UMS
    * Keypad lights
    * Brightness control
    * Vibrator
    * Deep sleep
    * GPS
    * GAPPS
    * Sensors (all)
    * Data usage, limiter
    * HW v-sync
    Bug :
    * Camera ( 95% fixed* )
    * Bluetooth ( 60% fixed* )
    * Wi-Fi ( WIP )
    * Headphone
    Instructions :
    Download del file cm-10-xxx.zip dal link in basso
    Backup dei tuoi dati: contatti, apps, sms, etc. o backup via recovery
    Copia il file cm-10-xxx.zip sulla sdcard. Scarica le Google Apps per CM10 da qui ( Goo.im Downloads - Browsing gapps
    Avvia in modalità Recovery e: 1.'wipe data/factory reset' 2. Flash di cm-10-xxx.zip. Per farlo dovete: selezionare 'install zip from sdcard 3. Scegliere lo zip dalla sdcard e selezionare cm-10-xxx.zip 4. Flashdelle gapps allo stesso modo
    Reboot (richiede ~2 mins)
    Enjoy
    Downloads :
    discussione originale su xda
    Changelog :
    codice:
    Build #2
        Use Garuda Kernel Release #2
        Add Governors ( smartassV2, SavagedZen )
        Add I/O Schedulers ( Simple I/O, V(R), BFQ )
        Fix sensors rotation
        Fix incoming call
        I forgot xD
    Build #1
        Initial Release
    Credits :
    TheWhisp - So many thing
    Wayland_ACE - Camera HAL
    KonstaT - A lot of useful improvements
    Immagini allegate
    Ultima modifica di imre; 02-03-13 alle 17:03
    Alchemy ROM per Samsung Galaxy Ace Plus
    se vuoi ringraziarmi usa il tasto thanks
  2. I seguenti 4 Utenti hanno ringraziato imre per il post:
    antoniocapp (03-03-13),satch86 (03-03-13),tonyno (22-03-13),troll4 (14-03-13)
    Baby Droid L'avatar di ciuffetto1996
    Carpi
    Galaxy Ace Plus
    Anche questa Cyano è interessante! Penso che nella terza build che pubblicheranno funzioni tutto. imre sai nulla sullo sviluppo di questa rom?
  5. #3
    Senior Droid L'avatar di Inkubo
    Nexus 4
    Ringraziato 127 volte in 107 Posts
    Nessuno l'ha provata? I bug delle chiamate e della rotazione sono stati fixati?
    Inviato dal mio GT-S7500 con Tapatalk 2
    Lg G2 D802
    Nexus 4
    Samsung Galazy S2
    Samsung Galazy Ace Plus
    Iphone 4
  6. #4
    Carpi
    Galaxy Ace Plus
    Quote Originariamente inviato da Inkubo Visualizza il messaggio
    Non posso testarla, ma da quanto leggo nel changelog, quei due bug sono stati fixati. (:
  7. #5
    Androidiano L'avatar di Llorente
    Motorola Moto G
    Appena è completa la provo . per ora rimango con l'Alchemy 0.8 che mi trovo benissimo.
  8. #6
    Bologna
    Nexus 5
    la sto usando io adesso e devo dire che a parte il wifi che non funziona e a parecchi può dar noia (non a me che non uso praticamente il market) è nettamente superiore a quella sviluppata dall'altro team
  9. #7
    cagliari
    samsung galaxy ace plus
    Le gapps funzionano ?
    Inviato dal mio GT-S7500 usando Androidiani App
  10. #8
    Bologna
    Nexus 5
    si funzionano
  11. #9
    Androidiano VIP L'avatar di Genio98
    Huawei P9
    Ringraziato 155 volte in 140 Posts
    quando uscirà quella definitiva?
  12. #10
    cagliari
    Bene sta sera la provo
    P.s posso sincronizzare i miei contatti di gmail giusto ?
