Pagina 1 di 6 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 54
[ROM][KQE]broodROM Business Edition BETA 0.5
    Androidiano L'avatar di zakary26
    Ringraziato 22 volte in 21 Posts
    Exclamation
    [ROM][KQI]broodROM Business Edition v1.2 [UPDATE]
    [ ROM ][KQI]broodROM Business Edition v1.2 [UPDATE] - xda-developers
    Changelog for v1.2:
    - Added patches from v1.1.1
    - Fixed FM Radio problem (thnx to jarjar09!)
    - Changed min freq to 245MHz for higher overall stability
    - Updated bootanimation
    - Added broodrom_scripts dir inside /system/etc (run with script manager (su) or su -c "sh /system/etc/broodrom_scripts/...")
    -- activate_i8150_gpu (change to i8150 gpu drivers)
    -- activate_i9001_gpu (change to i9001 gpu drivers)
    -- auto_calibrate_battery (calibrates battery when 100%)
    -- clear_ram_cache (clears ram cache)
    -- defragment_databases (defrags available databases)
    -- factory_reset (wipes /data, /cache)
    -- fix_permissions (fixes a lot of permissions)
    -- hard_reset (wipes /data, /cache and /sdcard)
    -- wipe_dalvik (wipes /data/ dalvik-cache )
    -- zipalign_apps (zipaligns all apps)
    ROM Features:
    - Based on XXKQI 2.3.6 (ICS Value Pack)
    - XXKPM Modem Included
    - broodKernel v1.2
    - Custom boot animation of broodROM Business Edition v1.1
    - Debloated
    - Rooted
    - Deodexed
    - Zipaligned
    - Init.d Scripts: (both are from broodKernel)
    -- 00broodkernel
    --- Configuration of several things such as readahead
    -- 01screenstatescaling
    --- Extended Screenstatescaling script / configuration / tweak script
    - Extended Power Menu (with screenshot function & quick reboot function)
    - 9 Lockscreens
    - Extended Status Bar 15 Toggles
    - Disabled ScrollingCache (smooth scroll)
    - Removed "Battery Charged Notification"
    - GPS Patch
    - Cyanogenmod APNS List
    - No Adds
    - Percent Battery (UOT)
    - Some stock replacements
    - Mail exchange security policy removed
    broodKernel v1.2 Features:
    - Added Auto Mount
    -- All partitions mounted in noatime / RW
    -- Cache / Data & Persist mounted with barrier=0 / commit=60
    - Added AOSP bootanimation library
    - Added init.d Support (runs at the end of the boot process)
    - Changed Kernel Security settings
    -- ro.secure=0
    -- ro.allow.mock.location=0
    -- ro.debuggable=1
    -- persist.service.adb.enable=1
    - Adjusted Low Memory Killer
    -- LMK 60MB Based
    - Added build.prop Tweaks
    -- Smoother GUI Tweak
    -- Less Ringtone Delay
    -- GPU Rendering
    - Added IPv4 Tweaks
    -- Changed Buffersizes
    -- Tweaks in /sys/proc/net/core
    -- Tweaks in /sys/proc/net/ipv4
    - Added Touchscreen Tweaks
    -- Sensitive touch
    - Added Kernel Tweaks
    - Added SD-Card Tweaks
    - Added VM (writeout) Tweaks
    - Added Zipalign
    - Added Vacuum (sqlite_optimize)
    - Added GT-i8150 GPU Drivers
    - Added 00broodkernel in init.d:
    -- Set I/O Scheduler
    -- Set SDCard Readahead
    -- Enable/Disable Error Reporting
    -- Enable/Disable sysctl.conf file
    - Added 01screenstatescaling in init.d:
    -- Set Awake Governor & min/max freq
    -- Set Sleep Governor & min/max freq
    -- Enable/Disable Governor tweaks
    -- Option to use 01screenstatescaling as the only cpu management source (disable init.qcom.post_boot.sh)
    - Non Rotational Readahead boost
    Follow androidiani on Twitter
    Questo è l'ultimo capolavoro di Mister BroodPlank
    forum.xda-developers.com/showthread.php?t=1696381
    Altamente performante senza sfronzoli, stock kernel e gps istantaneo,wifi ok....batteria 2 giorni
    Da provare.....
    NO BUGS
    Ultima modifica di zakary26; 10-08-12 alle 13:53 - Motivo: update
  2. I seguenti 2 Utenti hanno ringraziato zakary26 per il post:
    peppolax79 (11-06-12),sbrista (13-08-12)
    107 visite e nessun commento....
  5. Il seguente Utente ha ringraziato zakary26 per il post:
    edino (12-06-12)
  6. #3
    Le ho provate tutte ma questa risponde appieno alle mie esigenze, bella e veloce aspettando la cm9 senza bug.
    Grazie x la dritta
    edino
  7. #4
    Androidiano L'avatar di peppolax79
    Ringraziato 34 volte in 27 Posts
    Quote Originariamente inviato da edino Visualizza il messaggio
    Grazie x la dritta edino
    Ciao edino, ho letto su xda che lagga quando e' in sleepmode.. ovvero quando e' in lockscreen e vuoi sbloccarlo impiega qualche secondo prima che reagisce, mi puoi confermare??
  8. #5
    A me non da problemi xo' la sto usando da un giorno comunque fila che e' un piacere anche il gps fantastico
    Inviato dal mio GT-I9001 usando Androidiani App
  9. #6
    Androidiano L'avatar di ElDroidX
    Ringraziato 44 volte in 39 Posts
    Installata!
    Ottima ROM, risponde a pieno alle mie esigenze
    Galaxy S Advance i9070P 4.1.2 - AOSP Pure Vanilla V5
  10. #7
    Androidiano VIP L'avatar di Pignata#man
    Ringraziato 529 volte in 348 Posts
    magari qualche screen non guasterebbe affatto, le puoi postare su tinypic e inserire con link qui se ti interessa....
    "Experimentare humanum est"
    "Trasmissione" da Guerrino S3 Avanzato
    Extreme Rom TF Android Developer + Amplify + Greenify + PowerNap + Nitro X Spark
  11. #8
    Se riesco volentieri. Comunque graficamente è la Stock poi se vuoi personalizzi con go launcher
    Inviato dal mio GT-I9001 usando Tapatalk
  12. #9
    Quote Originariamente inviato da zakary26 Visualizza il messaggio
    Ed è proprio questo che mi piace, non ha fronzoli "home made" ad esempio come la nitrox che ho tolto per questo motivo
  13. #10
    Androidiano VIP L'avatar di Bigguzzo
    Palermo
    LG G3
    Ringraziato 261 volte in 217 Posts
    Quote Originariamente inviato da ElDroidX Visualizza il messaggio
    si a parer mio non fanno altro che appesantire il tutto e creare inutili microlag =)
    "... Non vogliate negar l'esperienza
    di retro al sol, del mondo sanza gente.
    Considerate la vostra semenza
    fatti non foste a viver come bruti
    ma per seguir virtute e canoscenza"
    SE TI HO AIUTATO IL TASTO THANKS SI TROVA IN BASSO A SINISTRA , ALTRIMENTI........HADOUKEEEN!!!!
