[ROM][KQI]broodROM Business Edition v1.2 [UPDATE]
[ROM][KQI]broodROM Business Edition v1.2 [UPDATE] - xda-developers
Changelog for v1.2:
- Added patches from v1.1.1
- Fixed FM Radio problem (thnx to jarjar09!)
- Changed min freq to 245MHz for higher overall stability
- Updated bootanimation
- Added broodrom_scripts dir inside /system/etc (run with script manager (su) or su -c "sh /system/etc/broodrom_scripts/...")
-- activate_i8150_gpu (change to i8150 gpu drivers)
-- activate_i9001_gpu (change to i9001 gpu drivers)
-- auto_calibrate_battery (calibrates battery when 100%)
-- clear_ram_cache (clears ram cache)
-- defragment_databases (defrags available databases)
-- factory_reset (wipes /data, /cache)
-- fix_permissions (fixes a lot of permissions)
-- hard_reset (wipes /data, /cache and /sdcard)
-- wipe_dalvik (wipes /data/dalvik-cache)
-- zipalign_apps (zipaligns all apps)
ROM Features:
- Based on XXKQI 2.3.6 (ICS Value Pack)
- XXKPM Modem Included
- broodKernel v1.2
- Custom boot animation of broodROM Business Edition v1.1
- Debloated
- Rooted
- Deodexed
- Zipaligned
- Init.d Scripts: (both are from broodKernel)
-- 00broodkernel
--- Configuration of several things such as readahead
-- 01screenstatescaling
--- Extended Screenstatescaling script / configuration / tweak script
- Extended Power Menu (with screenshot function & quick reboot function)
- 9 Lockscreens
- Extended Status Bar 15 Toggles
- Disabled ScrollingCache (smooth scroll)
- Removed "Battery Charged Notification"
- GPS Patch
- Cyanogenmod APNS List
- No Adds
- Percent Battery (UOT)
- Some stock replacements
- Mail exchange security policy removed
broodKernel v1.2 Features:
- Added Auto Mount
-- All partitions mounted in noatime / RW
-- Cache / Data & Persist mounted with barrier=0 / commit=60
- Added AOSP bootanimation library
- Added init.d Support (runs at the end of the boot process)
- Changed Kernel Security settings
-- ro.secure=0
-- ro.allow.mock.location=0
-- ro.debuggable=1
-- persist.service.adb.enable=1
- Adjusted Low Memory Killer
-- LMK 60MB Based
- Added build.prop Tweaks
-- Smoother GUI Tweak
-- Less Ringtone Delay
-- GPU Rendering
- Added IPv4 Tweaks
-- Changed Buffersizes
-- Tweaks in /sys/proc/net/core
-- Tweaks in /sys/proc/net/ipv4
- Added Touchscreen Tweaks
-- Sensitive touch
- Added Kernel Tweaks
- Added SD-Card Tweaks
- Added VM (writeout) Tweaks
- Added Zipalign
- Added Vacuum (sqlite_optimize)
- Added GT-i8150 GPU Drivers
- Added 00broodkernel in init.d:
-- Set I/O Scheduler
-- Set SDCard Readahead
-- Enable/Disable Error Reporting
-- Enable/Disable sysctl.conf file
- Added 01screenstatescaling in init.d:
-- Set Awake Governor & min/max freq
-- Set Sleep Governor & min/max freq
-- Enable/Disable Governor tweaks
-- Option to use 01screenstatescaling as the only cpu management source (disable init.qcom.post_boot.sh)
- Non Rotational Readahead boost
