Pagina 1 di 2 12 ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 18
[ROM][KQI]Shadow0-Rom-v2.1-DemonSlayer<17Lockscreen | Useful | Stable> kingsonwongs
    Nov 2010
    Ringraziato 30 volte in 27 Posts
    Download:
    v2.1 Download link:
    Full rom:Shadow0-Rom-v2.1-DemonSlayer.zip
    removed app recovery patch:Shadow0-Rom-v2.1 removed app recovery patch.zip
    Theme Download link:
    SGS2 Theme(v2.4):Shadow0-Rom-v2.1 SGS2-Theme-Patch v2.4.zip
    ICS Theme(v3.1):Shadow0-Rom-v2.1 ICS-Theme-Patch v3.1.zip
    Transparent Theme(v2.2):Shadow0-Rom-v2.1 Transparent-Theme v2.2.zip
    Other Patch Download link:
    I9001XXKQI GPU Driver patch:Shadow0-Rom-i9001xxkqi-gpu driver.zip
    I8150ZCLA2 GPU Driver patch:Shadow0-Rom-i8150zcla2-gpu driver.zip
    V6 SuperCharger patch:V6 SuperCharger Patch.zip
    Support:
    My Paypal Donate link
    Installation:
    put file into the sdcard
    go to CMW Recovery mode
    install Shadow0-Rom-v2.1-DemonSlayer.zip
    install any patch you like
    reboot and enjoy!
    Features:
    Based on KQI
    Deodexed
    Use KP4 Kernel with init.d support
    Fix kqi's tw4 bugs(use i9000xxjw4 tw4)
    Remove "connect your charge message" in all lockscreen
    APK signature Check removed
    3 Themes(SGS2[Default],ICS,Transparent)
    Tweaks:
    Build Prop Tweaks
    Zipalign
    Impove I/O
    SD card Speed
    I8150zcla2 3d driver
    V6 SuperCharger(Patch)
    Function:
    Extended Power Menu with Screenshot Function
    17lockscreen with music widget
    -Rings
    -Epic
    -Epic 2.0
    -S2 Glass(with weather widget,clock position setting)
    -S2 Tab(with weather widget)
    -Circle(with weather widget,clock position setting)
    -Glass
    -Puzzle
    -Rotary
    -StarWar
    -JKAY
    -Rotary Revamped
    -Lense
    -HoneyComb(with weather widget)
    -Android
    -4Tab
    -Lezo
    JobManager :
    use Tw4(i8150)'s ram manager
    extreme clear function(Menu switch clear mode)
    SystemUI :
    16 Toggles Quickpanel : long pressing a toggle brings you to the corresponding menu and customisable
    carrier text : color + removable / customizable
    date clock : color + removable
    clock : ability to center left or right + small AM-PM option
    MIUI battery bar : color + removable
    dbm : color + removable
    battery text : color + removable
    Hide Battery
    Hide Alarm
    Swipe to remove notification
    Browser :
    increased to 7 Tabs
    fullscreen mode
    user agent selection
    Dialer :
    Smart dialer
    Combine Contacts Logs
    NO SMS and MMS Logs
    Contacts :
    NO SMS and MMS Logs
    MMS :
    two reading mms mode
    Phone :
    Non-Increasing Ringtone
    enhance outgoing call vibration
    Camera :
    power button focuses and takes photo
    Without alert 15%
    Music Player :
    Without alert 10%
    Video Player :
    Without alert 10%
    FM Radio :
    Without alert 10%
    Works in airplane mode
    Settings :
    Auto sleep mode(auto silent and turn off Music,Fm,Wifi)
    Screen display(Lockscreen and CRT ON,OFF animation contral)
    Statusbar Settings
    Touch key light duration
    Special:
    Update some samsung app from i8150 and i9100
    Update some app to the newest version
    Rooted
    3 New languages(Chinese(CN),Chinese(TW),Chinese(HK))
    SGS2 Time and Weather Widgets
    remove some app(have a recovery patch)
    Themes Features:
    SGS2 Theme(v2.4)[Default Theme]
    ICS Theme(v3.1):
    with holo launger
    Other Patch Features:
    GPU Driver:
    i9001XXKQI GPU Driver
    i8150ZCLA2 GPU Driver[Default Driver]
    Credits:
    ownhere
    lidroid
    l70
    zzc
    jkay
    crybert
    lirik0
    last1left
    much more people...
    Galaxy S3 Neo
    Androidiano L'avatar di zakary26
    Ringraziato 22 volte in 21 Posts
    Mi viene voglia di provarla questa nuova Shadow....
    Nov 2010
    Infatti..
    Inviato dal mio GT-I9001 usando Androidiani App
    Galaxy S3 Neo
    Posta info se la provi... obbiettivamente con la Giga mi ci trovo benissimo per il mio utilizzo Gps compreso
    non c'è il toggle 2g che io utilizzo sulla Shadow, bisogna flasharlo a parte e poi non è detto che sia compatibile
    Androidiano VIP L'avatar di hypnos17
    Pan Daemonium
    Galaxy s plus
    Ringraziato 3,444 volte in 2,652 Posts
    C'è già il thread di Pignata avrebbe aggiornato come ha sempre fatto..
    Ultima modifica di hypnos17; 23-08-12 alle 14:03
  9. I seguenti 2 Utenti hanno ringraziato hypnos17 per il post:
    Picciotto (23-08-12),Pignata#man (23-08-12)
  10. #8
    Nov 2010
    il toggle 2g come ben sai ho provato di utilizzarlo in tutte le salse ma non ha mai funzionato...
    lo sviluppatore ha detto che se non si riscontrano bugs
    questa potrebbe essere la final release
    Galaxy S3 Neo
  11. #9
    Nov 2010
    Quote Originariamente inviato da hypnos17 Visualizza il messaggio
    Link
    Inviato...con qualcosa di ignoto..
    non sapevo se ne occupasse pignata...
    magari lo cancello se è lui ad occuparsene
    Galaxy S3 Neo
  12. #10
    Nov 2010
    come si cancella il 3d?
    Galaxy S3 Neo
