Pagina 9 di 205 primaprima ... 78910111959109 ... ultimoultimo
Visualizzazione dei risultati da 81 a 90 su 2042
Carica lenta Galaxy s3
  1. #81
    Senior Droid L'avatar di momo87
    Nexus 6P
    Ringraziato 77 volte in 68 Posts
    Vi riporto un articolo in inglese che parla proprio di questo problema causato da Jelly Bean (come ho notato nel mio caso) e non solo, con alcune possibili soluzioni. Spero possa essere d'aiuto a qualcuno e anche a me invece di aspettare un aggiornamento!
    All the 30 million Galaxy S3 users in the world wished for the Jelly Bean update to come up to their phones. Indeed, the update arrived and started to advance from country to country. The results were positive as Jelly bean brings true improvements to the previous Android version Ice Cream Sandwich.
    There is though one thing that seems to bother a really big number of Galaxy S3 users. After updating the Galaxy S III to Android 4.1 Jelly Bean the battery doesn’t work as it should anymore. What does this mean: after updating to Jelly Bean the Galaxy S3 battery charges very slow or it doesn’t fully charge to 100%, not even 90%. So basically the battery takes too long to charge compared to how it used to charge when running ICS.
    With the previous OS installed a normal charge lasted between 2h to 4h. Now it takes between 4h and 8h. That’s how you know it’s an issue.
    It is not clear yet if this is a common Galaxy S3 problem that all users have after updating to Android 4.1 Jelly Bean, but it is certainly a widespread problem that was addressed more than a few times.
    What are the reason the Galaxy S3 battery takes too long to charge?
    The following reasons why this happen are not applicable to all users but they have seemed to be the reason in most cases.
    • It is said that if you don’t update your phone with 100% battery and you update it with little battery, then the phone remembers that as being fully charged at a lower percentage. This is what some experts say, but it may not be 100% true.
    • Also, another bug in the Jelly Bean software is that it doesn’t recognize the charger as being an AC charger but as being an USB charger because of the two piece charge formed by the USB cable and the AC adapter.
    • There is a bug in the Jelly Bean software
    • SOLUTIONS: You need to use a charger formed of only one piece, not the USB + adapter charger. Also use only Samsung chargers. If you have a Galaxy S2 charger you can try that one.
    • Do a complete re calibration of the battery. This means drain the battery completely to 0% and then charge it overnight with the phone turned off. Do this 2 times.
    • This problem may not be a permanent one and sometimes after charging the Galaxy S3 a few times it optimizes itself and re calibrates the battery to normal. So try a few charges before thinking this is a permanent issue.
    • Another solution is to install CWM Recovery and go to ‘advanced’ > ‘wipe battery stats’.
    If none of these solutions work for you you should try to use other batteries to see if they act the same. This will tell you if the problem is with the phone or with the battery. If it’s indeed the battery then you should consider replacing it or switching it at warranty.
    Fonte: http://www.samsungupdate.com
    Edit: infatti io con la prima soluzione di usare un caricatore unico come quello dell'S2/Ace l'avrei risolta la questione. Chissà se con uno unico da 1.0 A carica normale oppure no. Sarebbe una bella controprova!
    Ultima modifica di momo87; 18-11-12 alle 12:32
    Se il mio aiuto è servito, un click su "Thanks" è sempre gradito!
  2. Il seguente Utente ha ringraziato momo87 per il post:
    theblindbg (19-11-12)
    Androidiano L'avatar di ZoRm
  5. #83
    Nexus 6P
    Sì andrebbe bene, col mio è stata una soluzione valida
  6. #84
    Androidiano L'avatar di Pistone85
    Spero di risolvere anche io con il caricatore da 0,7A l'ho ordinato sto aspettando che mi arriva!!
  7. #85
    Baby Droid L'avatar di Lafuentes
    Ciap a tutti ragazzi...stesso e identico problema brand TIM...lo aveva fatto tempo fa anche con ICS 1 volta mi sembra...ma poi tutto regolare...adesso dopo aver fatto l'aggiornamento a JB proprio una tartaruga...dalle 23 di ieri notte 18% alle 7 di stamattina 78%.....stasera sono andato a giocare a calcetto...alle 20.42 28%...ritornato alle 23-10 solo 36%.....sto provando a cambiare il caricatore utilizzando quello del galaxy tab 7"....vediamo cosa succede...
  8. #86
    Io confermo che con il vecchio caricatore con 0,7A ho risolto. Qualcuno sa però se non va ad incidere sulla salute della batteria??
  9. #87
    Ho fatto la Prova con il caricatore USB del Galaxy Tab 7"....se non sbaglio è da 2A....stamattina trovato carico al 100%...
  10. #88
    Nexus 6P
    Quote Originariamente inviato da ZoRm Visualizza il messaggio
    No non c'è nessun problema
    Inviato dal mio Galaxy S3 Pebble Blue!
  11. #89
    Nexus 6P
    Quote Originariamente inviato da Lafuentes Visualizza il messaggio
    Io avevo provato anche con quello ma non cambiava niente, sempre lento. Dopo 5 ore arrivava al 100%. Se puoi guarda quanto tempo impiega però.
  12. #90
    ma è assurdo che per risolvere il problema bisogna cambiare carica batterie!!! nn c'è nessun'altra soluzione???
