48 GB bonus on Dropbox!
da 48 GB bonus on Dropbox! - xda-developers
48 GB Free Dropbox storage from Samsung Galaxy SIII
Samsung has announced that that every consumer that buys and registers a Galaxy S III smartphone will get free 50GB cloud storage from Dropbox.
This is double of what Dropbox is giving HTC One series owners, however just like HTC, the free storage will only be valid for two years.
If you already have Dropbox installed on your Android device, you must Clear data, Force close and finally uninstall it from Settings > Applications > Manage Applications > Dropbox.
Thats installation for ClockWorkMod;
add apps here your internal sdcard and flash with CWM.
1.) Uninstall any Dropbox on your device.
2.) Download and install this :
CWM-S3-Dbox.zip
or;
https://hotfile.com/dl/157101366/c4e...-Dbox.zip.html
or;
CWM-S3-Dbox.zip Download - Directmirror.com - Upload & Mirror your files!
3.) Login, and after about 10-30 mins you'll get an email that says you've got 48GB of space more
İf you want to add manually , that's way ;
use root explorer or similar apps ;
add this files ;
system/app/Dropbox.apk
system/app/DropboxOOBE.apk
and;
system/framework/com.dropboxpartner.jar
give permission; rw- r-- r-- chmod 644 filename
after that reboot. thats it.
Some Pictures from My Account ;
https://www.dropbox.com/login?cont=h...dropbox.com/gs
Ricordo che qualche tempo fa su xda uscì un altra procedura per aumentare di molti Gb lo spazio dell'account ma dopo qualche giorno il tutto fu bloccato dai sviluppatori di Dropbox!
Anche se funzionasse per 24 mesi e dopo aver caricato 48 Gb di file alla scadenza del periodo di validità che succede? si perdono i dati? bisogna rinnovare pagando? non so ma è abbastanza contorta la cosa o_O
ktuluworld
Risponde DropBox (semplicemente, i file non si sincronizzano più):
https://www.dropbox.com/help/333/en
What happens if my paid account or promotion expires?
If your paid account expires or is downgraded, or the space granted to your account by a promotion expires, all of the files in your Dropbox folder will still be available to you on your computers, phones, and via the Dropbox website. However, Dropbox will only sync the amount of space allotted to your Dropbox account. This means that new files added to your Dropbox will not sync to other computers or be available online until the amount of disk space used in your Dropbox drops below the amount of Dropbox space allotted to your account.
In pratica allo scadere della promozione, non cancellano i file. Ma finchè non si svuota la cartella, fino a tornare ai gb di base, non si può più usare dropbox. giusto?,
