http://i43.tinypic.com/mjmvqp.jpg
Ecco un'altra rom, ancora una volta basata su Android 4.2.2, e anche questa con l'obbiettivo di diventare sempre più fluida, veloce e performante!
LiquidSmooth Github:
https://github.com/liquidsmooth
SCREENSHOTS
http://i41.tinypic.com/300vfvr.jpg http://i41.tinypic.com/23lb34l.jpg http://i39.tinypic.com/2rmsk7o.jpg http://i40.tinypic.com/2946wbt.jpg http://i41.tinypic.com/2w6cdjo.jpg
FEATURES
Comprehensive speed enhancements, including Linaro -O3
Customizable lockscreen buttons and sliders
Chronus clock widget
Customizable hardware and software keys
Transparent navbar and status bar
Customizable navbar ring
Navigation bar widgets
Customizable power menu
Notification power widget
Customizable quicksettings panel
Statusbar mods
Theme engine
Quiet hours
Volume rocker music controls
Full Rotation
Customizable battery and notification light
INSTALLAZIONE
INSTALLAZIONE
Do a nandroid backup
Put ROM and Gapps on the sdcard
Reboot into recovery (CWM or TWRP)
Full wipe (wipe /data /cache /dalvik-cache and format system)
Flash ROM and Gapps
Fix permissions, reboot system
Enjoy
AGGIORNAMENTI
Wipe Cache/Dalvik cache
Flash ROM and Gapps
Fix permissions
Reboot sytem
DOWNLOAD
Liquid JB v2.9-ancora-RC3:
Dev-Host - Liquid-JB-v2.9-OFFICIAL-RC3-ancora.zip - The Ultimate Free File Hosting / File Sharing Service
MD5sum: 0ba8a76bef304d22dd0e1e1d4664d4ea
Liquid Recovery edition:
Dev-Host - Liquid_Recovery_Ancora_v6.0.3.6_20132408.zip - The Ultimate Free File Hosting / File Sharing Service
CHANGELOG
codice:
Release 3 [24.08.2013]
ROM Changes:
*Sync to latest changes made by arco
*MMS: Updated German Translations (thanks to Rhonin86)
*Phone: Updated German Translations (thanks to Rhonin86)
*Settings: Updated German Translations (thanks to Rhonin86)
*Final updates on the 4.2.2 branches from the Liquid Smooth Team
Performance Control v2.0.9:
*New DiskInfo TAB - display the total and free space of: /system. /data, /cache, /sdcard, /ext-sd partitions
*Added Optimize Databases (SQLite Vacuum) - Tools Tab
*Change Fix Permission script for better compatibility with CM-10.2
*Added Tab Menu (manage all tabs from one window -> accessible through the Menu key)
*Added German and Romanian translations (thanks to Rhonin86 and Laurentyu1995)
*Added recovery and kernel flash support for Samsung Galaxy S II and Samsung Galaxy S III
*Added "Fix Permission" option (as it is removed from newer CWM recoveries)
*Added "Clean Residual Files" option
*Minor Bug Fixes
*UI Improvements
Release 2 [03.08.2013]
ROM Changes:
*Loads of HALO updates/bigfixes (full list here)
*Liquid Smooth v2.9 Official Changelog
*Sync to latest CM/LS Sources
Performance Control changes: (credits and thanks to h0rn3t)
*Added the ability to flash kernels and recoveries from the /sdcard
Supported devices: GALAXY S PLUS, GALAXY W, GALAXY S IV (Qualcomm Variant), GALAXY NEXUS, NEXUS 4, HTC ONE X
*Update Performance Control Low Memory Killer UI
*Other minor UI changes
Release 1 [17.07.2013]
ROM Changes:
*First Official Build
*Bump LS to version 2.9
*Built with SaberMod GCC 4.7 toolchain (with some more optimization flags)
*Revert back to system defined dalvik heap (credits to arco)
*Enabled world phone preferences menu (credits to CastagnaIT)
*Fix audio in Hangouts (credits to Steve Kondik)
*Put back dalvik.vm.dexopt-data-only=1 (credits to arco)
*MMS: Fix possible NPE; Mms: switch inverted text color back (credits kufikugel)
*HALO is a trusted overlay (yes, you can install APK's while it's ON)
*HALO: Size customizability
*HALO: Add more coloros
*HALO: Tablet mode support
*HALO: New vertical gestures
*Other changes for HALO from PA team
*Privacy Guard Manager: Settings->Security->Privacy Guard (CM)
*Updated German Translations for HALO (thanks Rhonin86 for help)
*New USB Mass Storage Interface logo (replace the SlimBean one with the Liquid Smooth one)
*Sync with latest CyanogenMod sources (CM-10.1.2)
Performance Control: (credits and thanks to h0rn3t)
*NEW BATTERY TAB (kernel must support Fast Charge)
- View current battery voltage
- View current battery status
- View current battery Temperature
- Fast Charge Toggle
*Memory Settings:
- Enable/Disable Not Killable Processes (kernel must support this feature)
- Set the Processes Whitelist (kernel must support this feature)
*NEW TOOLS TAB:
- Set a custom shell command which will be executed at every boot
- Wipe Cache and Dalvik cache (directly from the app, without booting into recovery)
BUILD 3 [27.06.2013]
*Fixed HALO Settings (HALO can be disabled and settings persist upon exit)
*Update Performance Control (thanks h0rn3t)
*Privacy Guard support
*Liquid Smooth Official Changelog
Liquid Smooth v2.7 [22.06.2013]
*Bump LS version to 2.7
*Fix front camera orientation
*HALO (fully working)
*New bootanimation (thank you @Pat_Man)
*Sync to latest CM/LS sources
Modded and adapted performance control by @h0rn3t - thanks mate
*VDD Levels customization now works properly (yes, you can change the Voltage Values now, without getting FC)
*More stable app (fix for some FC's)
*Added the ability to customize BLX values (only if the kernel supports it)
*Reduce time spend at boot when a lot of values need to be saved.
*Minor UI updates
Build 2 [03.06.2013]
*Bump to v2.5
*Built with -O3 optimization
*Fixed Battery Charging animation when device is off
*Fixed Boot animation glitches (Thanks to DualJoe)
*Using arco's Alpha 6 device tree
*Sync CM repo (RC4)
*Sync to latest LS sources
ADDITIONAL FEATURES
Modded Performance Control
Change CPU Governor, I/O Scheduler and Clock Speed
Change Voltages Assigned to each CPU frequency
Customize MinFree Task Killer (set the amount of RAM the minfree taskiller will keep)
Customize SD read-ahead
VM Settings such as: Dirty Ratio, Dirty Backgroud ratio, Dirty expire centisecs, Dirty writeback centrisecs, Minfree kbytes, Overcommit ratio, Swappiness and VFS Cache pressure
Integrated CPU Spy
Linux Kernel information, CPU Information, Memory Information
Interface customization
Change LCD Density (default 240 DPI)
Dual Panel
Vibration Multiplier
Hardware keys
Modify Clock widget
Customize Notification Drawer
Statusbar customization
Autohide Statusbar
Brightness Control (adjust brightness by sliding across statusbar)
Customize Signal Style/Battery icon/Clock and date appearance and Statusbar Style
Xposed™ DPI
Customize DPI Values of specific apps
Tablet Mode
CREDITI
educk
krislibaeer
arco
Christopher83
camcory
Madridii (testing)
CyanogenMod Team
LiquidSmooth Team
