cw1200_wlan, Wi-Fi consuma eccessivamente
    Senior Droid L'avatar di Pulse
    Kleve - Deutschland
    Oneplus One
    Ringraziato 121 volte in 71 Posts
    Ciao a tutti! Ho un problema: ultimamente, qualsiasi rom io abbia, BetterBatteryStats mi rileva un wakelock WiFi-correlato ("cw1200_wlan"), che mi consuma eccessivamente batteria anche se apparentemente non scambia dati.
    Allego anche il mio build.prop, se può c'entrare qualcosa..
    codice:
    ##### Merging of the /util/data/semc_kernel_time_stamp.prop file #####
    ro.build.date=Tue Jan 8 12:00:33 2013
    ro.build.date.utc=1357642833
    ro.build.user=BuildUser
    ro.build.host=BuildHost
    ##### Final patch of properties #####
    ro.build.product=ST25i
    ro.build.description=ST25i-user 4.0.4 6.1.1.B.1.89 prt3zw test-keys
    ro.product.brand=SEMC
    ro.product.name=ST25i_1264-3545
    ro.product.device=ST25i
    ro.build.tags=release-keys
    ro.build.fingerprint=SEMC/ST25i_1264-3545/ST25i:4.0.4/6.1.1.B.1.89/prt3zw:user/release-keys
          ######################## Customized property values #########################
    ro.semc.version.cust=1264-3545
    ro.semc.version.cust_revision=R7G
    ro.config.ringtone=xperia.ogg
    ro.config.notification_sound=notification.ogg
    ro.config.alarm_alert=alarm.ogg
    ro.semc.content.number=PA5
    ################# Updating of the SW Version #################
    ro.semc.version.fs_revision=6.1.1.B.1.89
    ro.build.id=6.1.1.B.1.89
    ro.build.display.id=6.1.1.B.1.89
    ##### Values from product package metadata #####
    ro.semc.product.model=ST25i
    ro.semc.ms_type_id=AAD-3880130-BV
    ro.semc.version.fs=WORLD
    ro.semc.product.name=XPERIA U
    ro.semc.product.device=ST25
    ro.product.model=ST25i
    # begin build properties
    # autogenerated by buildinfo.sh
    ro.build.version.incremental=prt3zw
    ro.build.version.sdk=15
    ro.build.version.codename=REL
    ro.build.version.release=4.0.4
    ro.build.type=user
    ro.product.board=montblanc
    ro.product.cpu.abi=armeabi-v7a
    ro.product.cpu.abi2=armeabi
    ro.product.manufacturer=Sony
    ro.product.locale.language=en
    ro.product.locale.region=GB
    ro.wifi.channels=
    ro.board.platform=montblanc
    # ro.build.product is obsolete; use ro.product.device
    # Do not try to parse ro.build.description or .fingerprint
    ro.build.characteristics=nosdcard
    # end build properties
    # system.prop for kumquat
    rild.libpath=/system/lib/libu300-ril.so
    rild.libargs=-c UNIX -n 2 -p /dev/socket/at_core -s /dev/socket/at_core -i rmnet
    # The OpenGL ES API level that is natively supported by this device.
    # This is a 16.16 fixed point number
    ro.opengles.version=131072
    # debug.sf.hw=0 Use b2r2 as compositor in SurfaceFlinger
    # debug.sf.hw=1 Use Mali as compositor in SurfaceFlinger
    debug.sf.hw=1
    # Android defaults EGL preserved swap behaviour
    # This gives bad performace for deferred renderers
    # such as Mali.
    hwui.render_dirty_regions=false
    # system props for Battery test in Service menu
    ro.semc.batt.capacity=1265
    ro.semc.batt.test.z_threshold=50
    ro.semc.batt.test.min_level=70
    # System props for SOLS
    ro.semc.sols.product-code=98
    ro.semc.sols.company-code=5
    # STE: Low power audio - enable ULP mode
    ste.nmf.autoidle=1
    # prop to indicate what kind of external memory the product have.
    ro.semc.product.user_storage=emmc_only
    # STE: Address of DBus STE bus
    ste.dbus.bus.address=unix:path=/dev/socket/dbus_ste
    # STE: UNSOL_CALL_RING is only sent once from RIL.
    # Android needs to generate more rings if needed.
    ro.telephony.call_ring.multiple=false
    #Default values/Locales for the hiding languages feature
    ro.product.locale.excluded=ar_EG ar_IL fa_IR iw_IL
    #Limitation on how much hwmem MM codecs should use
    ste.video.decoder.max.hwmem=0x3600000
    ste.video.decoder.max.res=1080p
    ste.video.decoder.h264.max.lev=4.2
    #STE: Hardware video codecs configuration
    ste.video.dec.mpeg4.in.size=8192
    ste.video.enc.out.buffercnt=5
    ste.video.dec.recycle.delay=1
    #STE: Fast Dormancy Flag
    # Fast Dormancy based on USB Tether Events and Screen States
    ste.special_fast_dormancy=false
    # System props for audio
    persist.audio.hp=true
    # ADDITIONAL_BUILD_PROPERTIES
    ro.product-res-path=framework/SemcGenericUxpRes.apk
    ro.setupwizard.mode=DISABLED
    ro.com.google.gmsversion=4.0_r5
    ro.com.google.clientidbase=android-sonyericsson
    keyguard.no_require_sim=true
    ro.com.android.dateformat=MM-dd-yyyy
    ro.com.android.dataroaming=false
    ro.semc.xloud.supported=true
    dalvik.vm.heapstartsize=5m
    dalvik.vm.heapgrowthlimit=48m
    dalvik.vm.heapsize=128m
    ro.sf.lcd_density=240
    ro.am.max_recent_tasks=8
    ro.sf.display_rotation=0
    r
    o.usb.pid_suffix=171
    dalvik.vm.dexopt-flags=m=y,u=n
    net.bt.name=Android
    dalvik.vm.stack-trace-file=/data/anr/traces.txt
    ro.service.swiqi.supported=true
    persist.service.swiqi.enable=1
    ro.drm.active.num=3
    ro.drm.active.0=marlin,1
    ro.drm.active.1=hdcp_av8100,1
    ro.drm.active.2=playready,0
    ##Mods##
    #Battery Mods
    persist.sys.shutdown.mode=hibernate
    persist.radio.add_power_save=1
    wifi.supplicant_scan_interval=180
    ro.ril.disable.power.collapse=1
    ro.config.hw_fast_dormancy=1
    ro.config.hw_quickpoweron=true
    ro.mot.eri.losalert.delay=1000
    ro.config.hw_power_saving=1
    pm.sleep_mode=1
    power_supply.wakeup=enable
    ro.ril.sensor.sleep.control=1
    ro.config.hw_power_saving=true
    #Camera Mods
    ro.media.enc.jpeg.quality=100
    #Dalvik and Kernel Mods
    persist.android.strictmode=0
    ro.kernel.android.checkjni=0
    ro.kernel.checkjni=0
    ro.config.nocheckin=1
    dalvik.vm.execution-mode=int:jit
    dalvik.vm.verify-bytecode=true
    dalvik.vm.jmiopts=forcecopy
    debug.kill_allocating_task=0
    dalvik.gc.type=precise
    ro.ext4fs=1
    #Disable USB Debugging PopUp
    persist.adb.notify=0
    #Sound Quality
    dev.pm.dyn_samplingrate=1
    persist.af.resampler.quality=255
    af.resampler.quality=3
    af.resample=48000
    mpq.audio.decode=true
    ro.somc.clearphase.supported=true
    #Allow to free more ram
    #Signal And Call Tweaks
    ro.config.vc_call_steps=15
    ro.telephony.call_ring.delay=0
    #Keep launcher in memory
    #Smoother video watching
    video.accelerate.hw=1
    media.stagefright.enable-player=true
    media.stagefright.enable-meta=true
    media.stagefright.enable-scan=false
    media.stagefright.enable-http=true
    #Better internet browsing & download speed
    net.tcp.buffersize.default=4096,87380,256960,4096,16384,256960
    net.tcp.buffersize.wifi=4096,87380,256960,4096,16384,256960
    net.tcp.buffersize.umts=4096,87380,256960,4096,16384,256960
    net.tcp.buffersize.gprs=4096,87380,256960,4096,16384,256960
    net.tcp.buffersize.edge=4096,87380,256960,4096,16384,256960
    net.tcp.buffersize.hspa=4096,87380,256960,4096,16384,256960
    #3G Tweaks
    ro.ril.hsxpa=2
    ro.ril.gprsclass=10
    ro.ril.hep=1
    ro.ril.enable.dtm=1
    ro.ril.hsdpa.category=10
    ro.ril.enable.a53=1
    ro.ril.enable.3g.prefix=1
    ro.ril.htcmaskw1.bitmask=4294967295
    ro.ril.htcmaskw1=14449
    ro.ril.hsupa.category=5
    #Google Dns
    net.rmnet0.dns1=8.8.8.8
    net.rmnet0.dns2=8.8.4.4
    net.dns1=8.8.8.8
    net.dns2=8.8.4.4
    #Scrolling speed
    windowsmgr.max_events_per_sec=62
    ro.max.fling_velocity=12000
    ro.min.fling_velocity=8000
    debug.performance.tuning=1
    #UI Tweaks
    persist.sys.ui.hw=1
    view.scroll_friction=10
    debug.composition.type=gpu
    hwui.disable_vsync=true
    ##Build.prop by JDWALKER##
    ###AC!D Sound Tweaks by R-ikfoot###
    #Sony Xloud
    ro.semc.sound_effects_enabled=true
    persist.service.xloud.enable=1
    #Resampling Tweaks
    af.resample=48000
    ro.audio.samplerate=48000
    ro.audio.pcm.samplerate=48000
    persist.dev.pm.dyn_samplingrate=1
    persist.audio.samplerate=48000
    persist.audio.pcm.samplerate=48000
    persist.af.resample=48000
    #One X+ Beats
    persist.tegra.nvmmlite = 1
    persist.audio.SupportHTCHWAEC=1
    htc.audio.swalt.enable=1
    htc.audio.swalt.mingain=14512
    # V6 SuperCharger, OOM Grouping & Priority Fixes created by zeppelinrox.
    # DO NOT DELETE COMMENTS. DELETING COMMENTS WILL BREAK UNINSTALL ROUTINE!
    # BEGIN OOM_MEM_Settings
    ro.FOREGROUND_APP_MEM=2560
    ro.VISIBLE_APP_MEM=3840
    ro.PERCEPTIBLE_APP_MEM=5120
    ro.HEAVY_WEIGHT_APP_MEM=7680
    ro.SECONDARY_SERVER_MEM=8960
    ro.BACKUP_APP_MEM=12800
    ro.HOME_APP_MEM=6400
    ro.HIDDEN_APP_MEM=15360
    ro.CONTENT_PROVIDER_MEM=20480
    ro.EMPTY_APP_MEM=25600
    # END OOM_MEM_Settings
    # BEGIN OOM_ADJ_Settings
    ro.FOREGROUND_APP_ADJ=0
    ro.VISIBLE_APP_ADJ=1
    ro.PERCEPTIBLE_APP_ADJ=2
    ro.HEAVY_WEIGHT_APP_ADJ=4
    ro.SECONDARY_SERVER_ADJ=5
    ro.BACKUP_APP_ADJ=6
    ro.HOME_APP_ADJ=3
    ro.HIDDEN_APP_MIN_ADJ=7
    ro.EMPTY_APP_ADJ=15
    # END OOM_ADJ_Settings
    # End of V6 SuperCharged Entries
    ### Pimp my Rom : Allow the purge of assets to free-up more RAM
    persist.sys.purgeable_assets=1
    ### Pimp my Rom : Disable Android Logger
    ro.HOME_APP_
    ADJ=1
    ### Pimp my Rom : Proximity Sensor Delay
    ro.lge.proximity.delay=25
    mot.proximity.delay=25
    ### Pimp my Rom : Enable Adaptive Multi-Rate Wideband
    ro.ril.enable.amr.wideband=1
    ### Pimp my Rom : Increase photo and video recording quality
    ro.media.dec.jpeg.memcap=8000000
    ro.media.enc.hprof.vid.bps=8000000
    ro.media.capture.maxres=8m
    ro.media.panorama.defres=3264x1840
    ro.media.panorama.frameres=1280x720
    ro.camcorder.videoModes=true
    ro.media.enc.hprof.vid.fps=65
    Ringrazio chiunque provi ad aiutarmi..
    Kleve - Deutschland
    Oneplus One
    CREDO di aver risolto.
    Ho modificato la voce "net.tcp.buffersize.wifi=4096,87380,256960,4096,16 384,256960" in
    codice:
    net.tcp.buffersize.wifi=524288,1048576,2097152,262144,524288,1048576
    Kleve - Deutschland
    Oneplus One
    Niente, riapro il tema della richiesta in quanto questa soluzione ha funzionato solo per poco tempo. Qualcuno ha qualche idea o lo stesso problema?
