Utente del giorno: luigif65 con ben 1 Thanks ricevuti nelle ultime 24 ore
Pagina 1 di 2 12 ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 17
Star S7189
    Senior Droid L'avatar di forziere
    HTC one
    Ringraziato 20 volte in 17 Posts
    Red face
    Star S7189
    VI lascio le informazioni base di questo telefono
    Model
    Star S7189
    Band
    2G: GSM 850/900/1800/1900MHz
    3G: WCDMA 850/2100MHz
    Sim Card
    Dual SIM Card Dual Standby
    Service Provide
    Unlocked
    Style
    Bar
    Color
    White/Gray
    Shell Material
    Plastic
    System
    OS
    Android 4.2
    CPU
    CPU MTK6589, Cortex A7 quad core, 1.2GHz;
    GPU: PowerVR SGX 544MP
    ROM
    4GB
    RAM
    1GB
    Screen
    Display Size
    5.3 Inch
    Type
    TFT, capacitive touch screen
    Resolution
    960 x 540 pixels
    Screen Color
    260K Colors
    Support Format
    Ringtones Type
    Polyphonic/MP3
    Audio File Format
    MP3/WAV/AMR/AWB
    Video File Format
    3GP/MPEG4
    Image File Format
    JPEG/BMP/GIF/PNG/GIF
    E-book Format
    TXT/CHM/DOC/HTML
    FM Radio
    Yes, earphone needed
    Earphone Port
    3.5mm
    Card Extend
    Support TF card up to 16GB extended
    Data Transfer & Connectivity
    Data transfer
    USB/Bluetooth
    Mobile internet
    WAP/WIFI
    General
    Camera/Picture Resolution
    Resolution Dual Cameras, front camera 1.3MP, back camera 8.0MP with flashlight and auto focus,up to 3264×2448 pixels resolution, support full screen capturing
    Language
    English, Bahasa Indonesia, Bahasa Melayu, Cestina, Deutsch, Espanol, Filipino, French, Italiano, Magyar, Nederlands, Polski, Portugues, Romana, Vietnamese, Turkish, Greek, Russian, Hebrew, Arabic, Persian, Thai, Korea, Simplified/Traditional Chinese
    Phonebook
    200
    Message
    SMS/MMS
    Input
    Handwrite/Keypad
    TV
    No
    GPS
    Yes, built in, also support A-GPS
    With EPO assistance to speed up postioning
    JAVA
    No
    WIFI
    Yes, 802.11 b/g/n
    Bluetooth
    Bluetooth 2.0
    Gravity Sensor
    Yes
    Multi-Touch
    Yes , 3 point touch
    Dimensions
    149 x 80 x 10mm
    Net Weight(Including battery)
    185g
    Standby Time
    About 2~3 days
    Other Feature
    3G, WIFI, GPS, FM, Bluetooth, Ebook, Email, Messaging,
    wallpapers, calendar, calculator, clock, camera, Play Store,
    tethering & portable hotspot, etc
    Package
    Size
    160 x 91 x 69mm
    Weight
    479g
    Accessories
    2 x 2800mAh Battery
    1 x Earphone
    1 x USB Cable
    1 x Charger
    1 x Case Cover
    1 x User Manual
    per le ROm e varie modifiche firmware:
    STAR S7189 5.5” Note 2 (N7100 ) Android 4.2 MTK6589 1.2GHz QuadCore - xda-developers
    qui trovate tutto!
    Ultima modifica di forziere; 01-07-13 alle 18:51
    HTC One Silver 32GB
    SIM: wind
    S-OFF - UnLocked - SuperCID
    HBOOT: 1.61.0000 NR
    RADIO: 4T.28.3218.04 - OPENDSP: v32.120.274.0909 - FIRMWARE: 7.19.1540.7
    RECOVERY: TWRP 2.8.5
    ROM: IC 7.0.4 snv 193
    KERNEL: STOCK
    C'è l'ho e sono soddifatissimo!
    Schermo luminoso, nitido e ben definito.
    Molto reattivo (grazie, probabilmente, ad android 4.2)
    Processore fantastico, ma problemi con qualche gioco (ad esempio real racing 3 non mi funziona).
    Per la root basta guardare su xda developers?
    HTC one
    Quote Originariamente inviato da amicofl Visualizza il messaggio
    Si il root é facile segui le guide..
    HTC One Silver 32GB
    SIM: wind
    HBOOT: 1.61.0000 NR
    KERNEL: STOCK
    HTC one
    che firmware hai?
    HTC One Silver 32GB
    SIM: wind
    HBOOT: 1.61.0000 NR
    KERNEL: STOCK
    Ciao,
    scusate l'intrusione, ho anche io questo telefono di cui sono soddisfatto... ma a voi i tethering wi-fi funziona?
    C'è modo di poterlo utilizzare?
    Grazie ciao
    Baby Droid L'avatar di slvrt2000
    Ciao a tutti, ho scoperto anche io adesso di avere questo telefono (...ero convinto di averne acquistato un'altro, ebbene si!) e mi trovo benissimo, ho già fatto il root e va davvero bene. Qualcuni puo darmi qualche indicazione si dove trovare la sua rom stock? giusto per averla da parte per quando mi verra il "prurito alle mani"... eheheh graaziiieeee
    Ciao a tutti
    Ho appena preso anche io questo modello. Prima avevo un N9330 sempre da 5.5 pollici con mtk6577
    Il nuovo processore lo trovo sicuramente più veloce, confermato anche da Antutu.
    Ho però riscontrato un problema, e vorrei sapere se per voi è lo stesso.
    Durante le riprese video, l'audio risulta essere particolarmente basso (anche con il semplice registratore audio) mentre durante le chiamate non mi sembra ci siano problemi.
    L'N9330 che avevo prima aveva una sensibilità microfonica in registrazione molto più alta e quindi l'audio in registrazione o durante le riprese video era meraviglioso. Qui invece risulta essere molto basso.
    Avete riscontrato lo stesso problema? Ovviamente io ho avuto il termine di paragone con il modello precedente, non so se voi avete avuto modo di fare un confronto con altri modelli.
    Salve a tutti,
    dopo circa 3/4 gg dall'acquisto di uno star S7189 ho cominciato ad avere questo tipo di problema.
    In pratica è come se il touch non rispondesse ai comandi.. il cell non è bloccato in quanto le animazioni di sfondo continuano ad essere in movimento.
    All'inizio mi succedeva tipo una volta ogni giorno e mezzo...
    adesso purtroppo succede ogni 3-4 ore.
    Dopo circa 3/4 minuti di completo non funzionamento dei comandi touch questo si sblocca e ritorna a funzionare normalmente.
    Ho disintallato quasi tutte le applicazioni antivirus compreso ma continua darmi questo problema.
    Il telefono quando non si blocca il touch è perfettamente funzionante .. fluido e veloce
    Avete esperienze simili? Avete indicazioni in merito..
    Poi vorrei sapere come si fa l'hard reset per il dispositivo..
    Anticipatamente ringrazio.
  10. #9
    Menú impostazioni e protezione... fai un reset di gabbrica.
  11. #10
    Questo l'ho fatto, intendevo quello che si ottiene di solito per esempio, schiacciando tasto volume e accensione assieme per qualche secondo..ma non trovo nulla di simile in internet..
