Tablet Nordmende
Salve ragazzi, devo acquistare un tablet per mio figlio di 12 anni e quindi non con grandissimi pretese. La mia scelta è caduta su 2 tablet nordmende, grazie ad un volantino trovato nella cassetta della posta, ma non avendo mai utilizzato un tablet, chiedo al forum un consiglio tra questi due tablet.
La differenza di prezzo non consideratela perchè entrambi hanno un prezzo intorno ai 100 euro.
I modelli sono questi:
Tablet ND-7012RK
CPU : Rockchip RK3066 Chipset 1.6GHz, ARM Cortex A9 Dual Core processor, up to 1.6Ghz,Mali400 Quad Core GPU
OS: Android 4.1
Language : English supported Multi languages
Screen : 7.0 800x480 Capacitive touch screen, 5 points touch
Ram : 1GB DDR3
Rom : 8GB NAND flash
Extended Storage: TF card, Maximum 32GB
Battery : 3.7V 2600mAh. Standby time about 100 hours. Play video time: about 3 hours.
Transfer Box : USB Host, USB OTG
Micro SD : Support Maximum 32GB
Earphone connector : 3,5mm
Speakers : Stereo
Camera : 0.3M Front and 0.3M back
Video : support
TV Out: 1080P HDMI
G-Sensor : Support
Connectivity : Wi-Fi Yes IEEE 802.11b/g/n
Ethernet : External
3G: 3G DONGLE(External 3G)
Video decoder : support up to HD 2160P;
Audio Format : MP1, MP2, MP3, WMA, WAV, OGG, OGA, APE, FLAC, AAC, M4A, 3GPP and more
Picture browser : JPG, JPEG, BMB, GIF,PNG, JFIF and more max 8000x 8000 resolution
Graphics acceleration : 2D
Network application : WWW browser, Google search, market, You Tube, MSN, Facebook, Skype, Email POP3/SMTP/IMAP4, flash 11.
Link sul sito del produttore
Tablet ND-8014RK
CPU : ROCHCHIP RK3066 1.6GHz, Dual Cortex A9 with 3D accelerator
OS: Android 4.1
Screen : 8.0 800x480 Capacitive touch screen, 5 points touch
Ram : 1GB DDR3
Rom : 4GB NAND flash
Battery : 3.7V 3500mAh. Standby time about 100 hours. Play video time: about 3 hours
Speakers : Stereo
Video : Support
G-Sensor : Support
Ethernet : External
Video decoder : support up to HD 2160P; support AVI,MPG,MKV,RM, RMVB, MP4, MOV, VOB, DAT, FLV, TS, 3GP,WEBM, VP8), etc…
Network application : WWW browser, Google search, market, You Tube, MSN, Facebook, Skype, Email POP3/SMTP/IMAP4, flash 10
Grazie per i consigli.
Alla fine ho preso il secondo....grazie a tutti per i consigli ed i suggerimenti.
cuvetto
Sai dirmi se il Nordmende nd8014 non ti da problemi con Google Play e ti permette di scaricare tutte le applicazioni e giochi?
Personalmente ho scaricato ed installato poche app e giochi, ma senza alcun problema.....
Se hai qualche problema con qualcosa di specifico dimmelo che provo a scaricarlo/installarlo.....
Ciao qualcuno sa se assomiglia a qualche altro modello rimarcato???
Mi piacerebbe rootarlo qualcuno ha qualche notizia in merito??
eliminatore
se ti riferisci al modello postato da me, io il mio l'ho rootato tranquillamente. ....
Ti dico subito che non è semplicissimo, devi partire da una base di conoscenza ed avere un po' di dimestichezza....
Trovi tutto su questo link
ma come si fa a sostiture i file su e busybox nella directory system/bin non ho i diritti per farlo
ma sei riuscito anche ad installare la cwm??
Sinceramente non mi interessa la recovery perché nn intendo installare rom moddate, mi basta il root per smanettarci un po...
Se vuoi stasera ti posto in link....
era per stare un po' piu' al sicuro magari si fa un nanodroid
mi interssa rootarlo, ho cercato un po' in giro ma non ho capito molto bene come si fa.
Io ho altri dispositivi rootati ma di solito ci sono pragrammini di aiuto, quio non ho ancora trovato niente
Te lo avevo detto prima....non esiste supporto....è una cinesata rimarcata, anche se devo dirti che sono soddisfatto. ...
Studiati quel sito, eventualmente stasera quando sono a casa ti do una mano io....
anche io sono contento, purtroppo io la sera non mi collego
ma la procedura a grandi linee quale e'??
Ciao, ho regalato questo table cinese a natale a mia madre ma ora come lo accendo
appare sempre virus polizia locale e non posso fare nulla, nemmeno entrare nel menu
impostazioni. cosa grave poi non riesco a resettarlo,
mi puoi dare una mano? sono disperato..
grazie mille
