Nook color: installare ubuntu, multipli problemi!
Ciao a tutti, ho una marea di problemi ad applicare la guida trovata su xda [WIP] [DEV] [HOWTO] Ubuntu on Nook Color! UPDATE 1/5/11 - xda-developers
Il terminale: nook color con ultima nightly build CM7 installata sulla memoria interna.
appena lancio lo script ubuntu.sh su adb connesso tramite wifi (lo stesso ma leggermente modificato usato sul nexus S) gli errori sono questi (e il pių strano č il mount non riconosciuto)
codice:
# sh ./ubuntu.sh
mount: not found
modprobe: module 'ext2' not found
mkdir: can't create directory '/data/local/mnt': File exists
rm: remove '/system/bin/fsrw'? y
rm: can't remove '/system/bin/fsrw': Read-only file system
rm: remove '/system/bin/bootubuntu'? y
rm: can't remove '/system/bin/bootubuntu': Read-only file system
rm: remove '/system/bin/unionfs'? y
rm: can't remove '/system/bin/unionfs': Read-only file system
unknown option -- /BusyBox v1.16.2androidfull (2010-08-01 14:57:25 EDT) multi-call binary.
Usage: rm [OPTIONS] FILE...
Remove (unlink) FILEs
Options:
-i Always prompt before removing
-f Never prompt
-R,-r Recurse
cp: can't create '/system/bin/fsrw': File exists
cp: can't create '/system/bin/bootubuntu': File exists
cp: can't create '/system/bin/unionfs': File exists
cp: can't create '/system/bin/mountonly': File exists
chmod: *: No such file or directory
chmod: InputChannel_test: Read-only file system
chmod: InputDispatcher_test: Read-only file system
chmod: InputPublisherAndConsumer_test: Read-only file system
chmod: InputReader_test: Read-only file system
chmod: Looper_test: Read-only file system
chmod: ObbFile_test: Read-only file system
chmod: String8_test: Read-only file system
chmod: alsa_amixer: Read-only file system
chmod: alsa_aplay: Read-only file system
chmod: alsa_ctl: Read-only file system
chmod: alsa_ucm: Read-only file system
chmod: am: Read-only file system
chmod: app_process: Read-only file system
chmod: audioloop: Read-only file system
chmod: backuptool.sh: Read-only file system
chmod: bluetoothd: Read-only file system
chmod: bmgr: Read-only file system
chmod: bootanimation: Read-only file system
chmod: bootubuntu: Read-only file system
chmod: bugreport: Read-only file system
chmod: cat: Read-only file system
chmod: clear_bootcnt.sh: Read-only file system
chmod: cmp: Read-only file system
chmod: compcache: Read-only file system
chmod: dalvikvm: Read-only file system
chmod: date: Read-only file system
chmod: dbus-daemon: Read-only file system
chmod: dd: Read-only file system
chmod: debuggerd: Read-only file system
chmod: dexopt: Read-only file system
chmod: dhcpcd: Read-only file system
chmod: dmesg: Read-only file system
chmod: dnsmasq: Read-only file system
chmod: dspexec: Read-only file system
chmod: dump_image: Read-only file system
chmod: dumpstate: Read-only file system
chmod: dumpsys: Read-only file system
chmod: dvz: Read-only file system
chmod: e2fsck: Read-only file system
chmod: e2label: Read-only file system
chmod: erase_image: Read-only file system
chmod: fix_permissions: Read-only file system
chmod: flash_image: Read-only file system
chmod: fsck_msdos: Read-only file system
chmod: fsrw: Read-only file system
chmod: gdbjithelper: Read-only file system
chmod: gdbserver: Read-only file system
chmod: getevent: Read-only file system
chmod: getprop: Read-only file system
chmod: gzip: Read-only file system
chmod: handle_compcache: Read-only file system
chmod: hciattach: Read-only file system
chmod: hd: Read-only file system
chmod: id: Read-only file system
chmod: ifconfig: Read-only file system
chmod: iftop: Read-only file system
chmod: ime: Read-only file system
chmod: input: Read-only file system
chmod: insmod: Read-only file system
chmod: installd: Read-only file system
chmod: ioctl: Read-only file system
chmod: ionice: Read-only file system
chmod: iptables: Read-only file system
chmod: keystore: Read-only file system
chmod: keystore_cli: Read-only file system
chmod: kill: Read-only file system
chmod: linker: Read-only file system
chmod: log: Read-only file system
chmod: logcat: Read-only file system
chmod: logwrapper: Read-only file system
chmod: lsmod: Read-only file system
chmod: lsof: Read-only file system
chmod: mediaserver: Read-only file system
chmod: mke2fs: Read-only file system
chmod: mkyaffs2image: Read-only file system
chmod: modelid_cfg.sh: Read-only file system
chmod: monkey: Read-only file system
chmod: mountonly: Read-only file system
chmod: mtpd: Read-only file system
chmod: nandread: Read-only file system
chmod: ndc: Read-only file system
chmod: netcfg: Read-only file system
chmod: netd: Read-only file system
chmod: netstat: Read-only file system
chmod: newfs_msdos: Read-only file system
chmod: notify: Read-only file system
chmod: omx_tests: Read-only file system
chmod: pand: Read-only file system
chmod: ping: Read-only file system
chmod: pm: Read-only file system
chmod: pppd: Read-only file system
chmod: printenv: Read-only file system
chmod: ps: Read-only file system
chmod: pvrsrvinit: Read-only file system
chmod: qemu-props: Read-only file system
chmod: qemud: Read-only file system
chmod: racoon: Read-only file system
chmod: radiooptions: Read-only file system
chmod: reboot: Read-only file system
chmod: record: Read-only file system
chmod: renice: Read-only file system
chmod: resize2fs: Read-only file system
chmod: rild: Read-only file system
chmod: rmdir: Read-only file system
chmod: rmmod: Read-only file system
chmod: route: Read-only file system
chmod: rtp_test: Read-only file system
chmod: run-as: Read-only file system
chmod: schedtest: Read-only file system
chmod: schedtop: Read-only file system
chmod: sdcard: Read-only file system
chmod: sdptool: Read-only file system
chmod: sendevent: Read-only file system
chmod: service: Read-only file system
chmod: servicemanager: Read-only file system
chmod: setconsole: Read-only file system
chmod: setprop: Read-only file system
chmod: sh: Read-only file system
chmod: showlease: Read-only file system
chmod: skia_test: Read-only file system
chmod: sleep: Read-only file system
chmod: smd: Read-only file system
chmod: stagefright: Read-only file system
chmod: start: Read-only file system
chmod: stop: Read-only file system
chmod: surfaceflinger: Read-only file system
chmod: svc: Read-only file system
chmod: sync: Read-only file system
chmod: sysinit: Read-only file system
chmod: system_server: Read-only file system
chmod: tc: Read-only file system
chmod: testid3: Read-only file system
chmod: tiap_cu: Read-only file system
chmod: tiap_loader: Read-only file system
chmod: toolbox: Read-only file system
chmod: top: Read-only file system
chmod: tune2fs: Read-only file system
chmod: uim-sysfs: Read-only file system
chmod: unionfs: Read-only file system
chmod: unyaffs: Read-only file system
chmod: uptime: Read-only file system
chmod: vdc: Read-only file system
chmod: verify_cache_partition_size.sh: Read-only file system
chmod: vmstat: Read-only file system
chmod: vold: Read-only file system
chmod: watchprops: Read-only file system
chmod: wipe: Read-only file system
chmod: wlan_cu: Read-only file system
chmod: wlan_loader: Read-only file system
chmod: wpa_cli: Read-only file system
chmod: wpa_supplicant: Read-only file system
Ubuntu Chroot Bootloader v0.1
Ubuntu Bootloader is now installed!
This process does NOT damage Android OS!
Original Installer by Charan Singh
Modified for Ubuntu Chroot by Max Lee at NexusOneHacks.net
To enter the Debian Linux console just type 'bootubuntu'
# bootbuntu
bootbuntu: not found
# whoami
root
qualche ideA?
