Description
ROM Mobile Bedove x21 – ROM Android 4.0.9
ROM Official Bedove X21-6577-12G21_X21_ICS.V1_3.121120T1.FWVGA.4P4_COM_CN
Language support: Multilang
ROM Install :
1.Brush system: new download good rom directly put on the sd card brush, do not need to boot into the system!
2.android system and data quick format (wipe)
3.Some advanced settings, such as removing the battery information.
4. Powerful U disk mount function
5.Turned off press Volume + and power button to enter.
6. System backup and restore all the data, including data
Note: Do not use the restore factory settings with the SD card installed, because he will empty your external SD card.
or
To unpack TOOL run Flash_tool.exe
Select a the in MT6577_Android_scatter_emmc.txt in Recovery with Flashtools
Click Flash_tool.exe interface Firmware-> Upgrade
Phone after taking the battery in put something
Connect the data cable
Brush finished with green circles appears
ATTENTION !!!!
it's the chinese locked version. it's IMEI locked
follow this tutorial
Tutorial write imei number for MTK 65XX
