questi file intaccano il volume del mic?mi sentono male e non succedeva da un po...cmq sia mic che speaker dovrebbero essere quei tre file,cavolo!!!!
Ho inserito la v2 ed ora mi sentono male quando chiamo. Come ripristino il vecchio audio?
Aggiornamento alla V7 senza distorsione
Official topic: [UPDATE: 09/07] Increase Max Volume - V7 DISTORTIONLESS! - LucidREM's Method Updated! - xda-developersV7 - (V2r2) - DISTORTIONLESS - *Latest* - *BEST QUALITY*
First fully working independent Version since V3 (e.g. not an update). FOR SERIOUS AUDIOPHILES!! well, for everyone really. Just about as loud as V2, if not a bit louder, but with 0 distortion. Yep, no distortion what-so-ever (within reason) i spent all day today playing with the EQ + the Compressor and found a good compromise. This is about as loud as i can get it without distortion occurring but as it's V2+ loudness, it's much better than stock whilst also sounding better! Win, Win!
These files were tested with Acoustic Music in mind (Jack Johnson and Newton Faulkner to be precise), so if that's what you like, these are for you! if not, don't worry, they're still the best for just about any music type. (also tested Eminem, Foo Fighters, Clutch, Pendulum, Bad Religion, 50 Cent, Pantera, Beethoven + other classical music, and got basically no distortion for any)
Copiare tutti i 3 files presenti nello zip
codice:adb remount adb push V7/AudioFilter.csv system/etc adb push V7/AudioPara4.csv system/etc adb push V7/AudioPreProcess.csv system/etc
nel magic il v7 fa sentire da culo il microfono, basti vedere la cm418
Vale la pena allora provare questo nuovo audio??? il mio problema è sempre stato il microfono
Premetto che uso i 3 file di nk02 nella sua 4.0.4
io ora sto usando quelli della vodafone originale, lasciateli stare i v7 !
nk02 potresti pubblicare i file audio della vodafone originale?
