Pagina 23 di 24 primaprima ... 1321222324 ultimoultimo
Visualizzazione dei risultati da 221 a 230 su 239
[Thread Ufficiale] iNEW 6000 6.5" FULLHD MTK6589T
  1. #221
    GrossoShop
    Quote Originariamente inviato da albanomax Visualizza il messaggio
    preso a 212€ niente da dire ma l'audio si sente bassino per il resto bello e perfetto!!
    Questo che segue vi può servire per calibrare il volume della suoneria, audio di ascolto e altre cosucce
    MTK phone to adjust the earpiece volume method -- *#*#3646633#*#*
    Hidden content
    Select AUDIO -----> NORMAL MODE, turn off the input method window . To see the following values ​​. {Note : NORMAL MODE values ​​with LoudSpeaker demanded the same. NORMAL MODE } first change in the SPH, and then change LoudSpeaker the SPH. Now says LEVEL setting these values. Fill your own figures, click on SET enough. No restart the phone goes into effect
    Select FIR 5, TYPE Select SPH, now set several LEVEL value. Are as follows:
    LEVEL 0 ------ VALUE 0 SET
    LEVEL 1 ------- VALUE 48 SET
    LEVEL 2 ------- VALUE 96 SET
    LEVEL 3 ------- VALUE 112 SET
    LEVEL 4 ------- VALUE 128 SET
    LEVEL 5 ------- VALUE 148 SET
    LEVEL 6 ------- VALUE 160 SET
    2 , the ringer volume is adjusted method : first change NORMAL MODE the Ring, and then change LoudSpeaker the Ring. Now says LEVEL setting these values. Fill your own figures, click on SET enough. No restart the phone it goes into effect , are as follows:
    LEVEL 0 - VALUE 0
    SET LEVEL 1 --- VALUE 60
    SET LEVEL 2 --- VALUE 150
    SET LEVEL 3 --- VALUE 176
    SET LEVEL 4 --- VALUE 190
    SET LEVEL 5 --- VALUE 210
    SET LEVEL 6 --- VALUE 246
    SET
    Max Vol This value is 148 requires alignment it once .
    3, the multimedia volume method : first change NORMAL MODE in Media, and then change LoudSpeaker in Media. Now says LEVEL setting these values. Fill your own figures, click on SET enough. No restart the phone it goes into effect , are as follows:
    LEVEL 0 - VALUE 0
    SET LEVEL 2 --- VALUE 72
    SET LEVEL 3 --- VALUE 84
    SET LEVEL 4 --- VALUE 96
    SET LEVEL 5 --- VALUE 150
    SET LEVEL 6 --- VALUE 220
    SET Max Vol this value is 152 requires alignment it once .
    4, the microphone volume setting method: first change NORMAL MODE in MIC, then change LoudSpeaker the MIC. Now says LEVEL setting these values. Fill your own figures, click on SET enough. No restart the phone it goes into effect , are as follows:
    LEVEL 0 - VALUE 200
    SET LEVEL 1 --- VALUE 200
    SET LEVEL 2 --- VALUE 210
    SET LEVEL 3 --- VALUE 224
    SET LEVEL 4 --- VALUE 238
    SET LEVEL 5 --- VALUE 246
    SET LEVEL 6 --- VALUE 252
    SET
    Microphone above the test values ​​after the call came for the best. But each phone has different, so break the sound when it ourselves . Summary : Just set NORMAL MODE with LoudSpeaker same value , there would not be poor sound quality issues . Other phones also can be changed , but there you have the value measured according to their phones up . ( Limited MediaTek MTK mobile phones, mobile phones according to their own values ​​to adjust )
    GrossoShop
    Dopo alcune segnalazioni preciso che cè un applicazione utile che si chiama MTK Engineering Mode. Serve a modificare e personalizzare un pó di cose.
  4. #223
    frai78
    salve, con questi parametri, l'audio in capsula e per le casse, si sente molto meglio? sono indeciso fra questo e il Newman k2s
  5. #224
    Banned
    Sep 2013
    Ordinato da ******* per mio fratello.. aspetto che arrivi! Non vedo l'ora di provarlo!
  6. #225
    GrossoShop
    Non ti deluderà ne sono certo
  7. #226
    Banned
    Aug 2013
    Ringraziato 145 volte in 115 Posts
    Quote Originariamente inviato da poweris Visualizza il messaggio
    Il mio è già partitooo!!
  8. #227
    frai78
    salve sto per prenderlo usato ad un buon prezzo....vi chiedo una cosa: ma come si aggiorna? via ota o tramite flastool? grazie
  9. #228
    Banned
    Oct 2013
    Come si trova tuo fratello? tu l'hai testato?
  10. #229
    GrossoShop
    Quote Originariamente inviato da frai78 Visualizza il messaggio
    consigliato flashtool.
  11. Il seguente Utente ha ringraziato GrossoShop per il post:
    magagnad (12-05-14)
  12. #230
    Ma qualcuno mi dice anch ein pvt dove prenderlo? Possibilmente per averlo in poco tempo.
    ROcky Balboa
    Ma quello che sto cercando di dirvi è che se io posso cambiare, e voi potete cambiare, allora tutto il mondo può cambiare!!!
