Visualizzazione dei risultati da 1 a 10 su 48
[Thread Ufficiale] iNew V3 Plus (Inew V3A) ?
    Senior Droid L'avatar di spikeenzo
    Ringraziato 153 volte in 89 Posts
    Qualcuno è a conoscenza dell'uscita di questo modello?
    iNew V3 Plus
    Basic Information
    Model Inew V3 Plus/inew V3A
    Band 2G: GSM 850/900/1800/1900MHz
    3G: WCDMA 850/2100MHz
    Sim Card Dual sim dual standby
    Service Provide Unlocked
    Style Bar
    Color Black/White
    Shell Material Brushed-metal finish
    System
    OS Android 4.4
    CPU MTK6592, Cortex A7 Octa core, 1.7GHz; GPU: Mali-400
    ROM 16GB
    RAM 2GB
    Screen
    Display Size 5.0 Inch
    Type IPS, capacitive screen
    Resolution 1280 x 720 pixels HD screen
    Support Format
    Ringtones Type Polyphonic/MP3
    Audio File Format MP3/WAV/AMR/AWB
    Video File Format 3GP/MPEG4
    Image File Format JPEG/BMP/GIF/PNG/GIF
    E-book Format TXT/CHM/DOC/HTML
    FM Radio Yes
    Earphone Port 3.5mm
    Card Extend Yes, support TF card up to 32GB
    Data Transfer & Connectivity
    Data transfer USB/Bluetooth
    Mobile internet WAP/WiFi
    General
    Camera/Picture Resolution Dual Cameras, 5.0MP front camera; 13.0MP back camera with flashlight
    Language Bahasa Indonesian, Bahasa Melayu, German, English, Spanish, Filipino, French, Italian, Magyar, Dutch, Polish, Portugues (Brasil), Portugues (Portugal), Vietnamese, Turkish, Greek, Russian, Hebrew, Arab, Thai, Korean, Chinese (simp), Chinese(trad)
    Phonebook 500
    Message SMS/MMS
    Input Handwrite/Keypad
    TV No
    GPS Yes, built in, also support A-GPS
    With EPO assistance to speed up postioning
    JAVA No
    WIFI Yes, 802.11 b/g/n
    Bluetooth Yes
    Gravity Sensor Yes
    Multi-Touch Yes, 5 point touch
    Standby Time About 2~3 days
    Dimensions 142.5 x 70.8 x 6.5mm/5.61 x 2.78 x 0.25 inch
    Net Weight(Including battery) 128g
    Other Feature 3G, WIFI, GPS, FM, Bluetooth, Ebook, Email, Messaging, wallpapers,
    calendar, calculator, clock, camera, tethering & portable hotspot, etc
    Package
    Size 179 x 99.5 x 51.5mm/7.0 x 3.9 x 2.0 inch
    Weight 407g
    Accessories
    1 x 1830mAh Battery
    1 x USB Cable
    1 x Charger
    1 x 3.5mm Earphone
    l'avevano gia messo in vendita mesi fa quelli della goophone. si chiamava goophone v92 pro.
    era identico al v3 (compresa la ormai mitica ignobile batteria da 1830mah) ma con
    2GB di ram e il mediatek 6592 octacore. evidentemente oggi la inew se ne e' accorta e l'ha
    rimarchiato.
    Apr 2010
    esteticamente sembra bellissimo....da noto shop con 145€si compra spedito...sembra buono e ben fatto ma la batteria mi preoccupa
    @canaglia76: della batteria hai letto che fa ******** su modello goophone ?
    Vorrei riprendermelo. Ero un possessore del V3 e mi trovavo molto bene se non fosee stato per la batteria e il gps altalenante. Il nuovo processore garantirebbe maggior autonomia e miglior precisione del gps?
    Inviato dal mio ZP998 usando Androidiani App
    Ringraziato 56 volte in 42 Posts
    Dichiarano una migliore ottimizzazzione consumo batteria.. mah.. vedremo!
    Aug 2013
    Ringraziato 49 volte in 40 Posts
    Questo e la vera scheda del inew v3 plus
    iNew V3 Plus*Android phone*Tech Info*
    iNew V3 Plus owns a 5.0-inch HD OGS AUO Corning II Gorilla Glass screen with 1280*720 pixel display, MTK6592 Octa Core 1.4GHz processor, 2GB RAM, and 16GB storage. iNew V3 Plus installs Android 4.4 OS And Support OTG Function.
    Inviato dal mio ZP980 usando Androidiani App
    Oct 2014
    S5, S4, OPO, Honor 6, Mi2S ec
    Sapete che sono molto tentato ? eppure mi ero detto che dovevo smetterla coi cinafonini...
    ma questo ha un prezzo davvero basso e specifiche interessantissime e unico neo la batteria, di amperaggio abbastanza piccolo.
    Ieri ho ordinato, sullo stesso store che lo sta promuovendo scontato, l'elephone g6, ma li ho capito che c'erano due difetti : la mancanza di update ota e il partizionamento fastidioso delle app che era di solo 1 giga sugli 8 disponibili. Qui cercando in rete ho visto dei filmati e gli ota sono presenti, il dubbio però è : avete notizie circa il partizionamento dei dati di sto cinafonino ? saranno l'orrendo 1 giga di elephone, lo striminzito 3 giga di nubia z7 mini oppure ci sarà una partizione libera dei 16 giga come sui samsung, ad esempio?
    e sapete per caso se questo telefonino ha difetti noti come altri mediatek tipo fixing gps ecc???
    vi ringrazio in anticipo
  9. #8
    Androidiano L'avatar di Skalexlt
    May 2014
    Ciao ragazzi come da titolo, chiedo consigli per l'acquisto di un Inew V3 Plus, non avendo mai acquistato dai siti cinesi, (tantomeno smartphone)e dovendo poi regalarlo, mi occorrerebbe un sito affidabile sia sulla spedizione e che offra garanzie insomma, magari pure economico il chè non guasta😀😀
    Grazie in anticipo!!
  10. #9
    Ringraziato 51 volte in 46 Posts
    Quote Originariamente inviato da Skalexlt Visualizza il messaggio
    Ciao ragazzi come da titolo, chiedo consigli per l'acquisto di un Inew V3 Plus, non avendo mai acquistato dai siti cinesi, (tantomeno smartphone)e dovendo poi regalarlo, mi occorrerebbe un sito affidabile sia sulla spedizione e che offra garanzie insomma, magari pure economico il chè non guasta����
    di siti ce ne sono vari affidabili, sulle garanzie è ovvio che è un po rischioso diciamo che è meglio non averne bisogno, io personalmente ne ho acquistati tre negli ultimi 2 anni e fino ad ora senza alcun problema .le ultime due volte ho acquistato su eto...talk senza nessun problema
  11. Il seguente Utente ha ringraziato mjj72 per il post:
    Skalexlt (24-11-14)
  12. #10
    ma nfc è presente?
