ad un attenta analisi secondo me la famosa libreria libDxDrmDlcCore.so esegue anche un controllo aggiuntivo sul root su
codice:
.text:00133B0A ; ---------------------------------------------------------------------------
.text:00133B58 LDR.W R10, =(_GLOBAL_OFFSET_TABLE_ - 0x133B68)
.text:00133B5C MOV R5, R0
.text:00133B5E LDR R0, =(aSu - 0xF9E1E0)
.text:00133B60 MOV.W R1, #0xFFFFFFFF
.text:00133B64 ADD R10, PC ; _GLOBAL_OFFSET_TABLE_
.text:00133B66 ADD R0, R10 ; aSu ; "su"
.text:00133B68 BL sub_1020E8
.text:00133B6C LDR R2, =(dword_F5C853 - 0xF9E1E0)
.text:00133B6E ADD R0, R5
.text:00133B70 LDR R1, =(aJni______Platf - 0xF9E1E0)
.text:00133B72 ADDS R6, R0, #3
.text:00133B74 ADD R2, R10
.text:00133B76 ADD.W R0, R1, R10 ; "jni/../../../PlatformUtils/Client/Andro"...
.text:00133B7A MOVW R1, #0x185
.text:00133B7E MOV R3, R6
.text:00133B80 BL sub_18141C
.text:00133B84 MOV R5, R0
.text:00133B86 CMP R5, #0
.text:00133B88 BEQ.W loc_133D80
.text:00133B8C LDR R0, =(_GLOBAL_OFFSET_TABLE_ - 0x133B96)
.text:00133B8E MOV R3, R7
.text:00133B90 LDR R2, =(aSu - 0xF9E1E0)
.text:00133B92 ADD R0, PC ; _GLOBAL_OFFSET_TABLE_
.text:00133B94 LDR R1, =(aSS - 0xF9E1E0)
.text:00133B96 ADD R2, R0 ; aSu ; "su"
.text:00133B98 STR R2, [SP,#0x2B8+var_2B8]
.text:00133B9A ADDS R2, R1, R0 ; "%s/%s"
.text:00133B9C MOV R0, R5
.text:00133B9E MOV R1, R6
.text:00133BA0 BL sub_1002C8
da quel che ne posso dedurre secondo me la strings "su" viene cercata da qualche parte con questa espressione "%s/%s"...
NOTE:
RootCloak non dovrebbe aiutare in questo caso poichè si legge nella descrizione:
App: Yelo TV - Telenet -
https://play.google.com/store/apps/d...e.telenet.yelo
Method: Detects root via native library (built with Android NDK). Unsure of exact method, but the strings "ERROR: Device is rooted. aborting execution" and "ERROR: Debbuger running. aborting execution" can be found in the library.
Relevant Files: libDxDrmDlcCore.so
non penso neanche TabletMetrics, che dovrebbe essere solo per Spotify...
EDIT: FUNZIONA! E' bastato installare "Hide My Root" al posto di RootCloak e tutto è andato a buon fine sul mio Nexus5, fantastico! grazie mille blknit!!!
