strano
sicuro di aver messo il giusto nome della scheda?
dopo aver fatto
prova a postare il risultato dicodice:sudo mount /dev/sdX3 tmp
codice:mount
strano
dopo aver fatto
codice:mount
Dopo
sudo mount /dev/sdb tmp
mi dice
/dev/sdb already mounted or tmp busy
Dopo
mount
mi dice
/dev/sdal on / type ext4 (rw,errors=remount-ro)
proc on /proc type proc (rw,noexec,nosuid,nodev)
none on /sys type sysfs (rw,noexec,nosuid,nodev)
none on /sys/fs/fuse/connections type fusectl (rw)
none on /sys/kernel/debug type debugfs (rw)
none on /sys/kernel/security type securityfs (rw)
none on /dev type devtmpfs (rw,mode0755)
none on /dev/pts type devpts (rw,noexec,nosuid,gid=5,mode=0620)
none on /dev/shm type tmpfs (rw,nosuid,nodev)
none on /var/run type tmpfs (rw,nosuid,mode=0755)
none on /var/lock type tmpfs (rw,noexec,nosuid,nodev)
none on /lib/init/rw type tmpfs (rw,nosuid,mode=0755)
gvfs-fuse-daemon on /home/giorgiopc/.gvfs type fuse.gvfs-fuse-daemon (rw,nosuid,nodev,user=giorgiopc)
/dev/sdb1 on /media/bootloader type vfat (rw,nosuid,nodev,uhelper=udisks,uid=1000,gid=1000, shortname=mixed,dmask=0077,utf8=1,flush)
/dev/sdb2 on /media/boot type ext4 (rw,nosuid,nodev,uhelper=udisks)
/dev/sdb9 on /media/57f8f4bc-abf4-655f-bf67-946fc0f9f25b type ext4 (rw,nosuid,nodev,uhelper=udisks)
/dev/sdb6 on /media/misc type ext4 (rw,nosuid,nodev,uhelper=udisks)
/dev/sdb7 on /media/cache type ext4 (rw,nosuid,nodev,uhelper=udisks)
/dev/sdb8 on /media/57f8f4bc-abf4-655f-bf67-946fc0f9f25b_ type ext4 (rw,nosuid,nodev,uhelper=udisks)
/dev/sdb3 on /media/system type ext4 (rw,nosuid,nodev,uhelper=udisks)
/dev/sdb5 on /media/data type ext4 (rw,nosuid,nodev,uhelper=udisks)
non devi fare
sudo mount /dev/sdb
ma
sudo mount /dev/sdb3
(prima fai un
sudo umount /dev/sdb*
Dice
can't find /dev/sdb3 in /etc/fstab or etc/mtab
allora, riassumiamo:
1) inserisci la sdcard
2) esegui:
e posta il risultatocodice:sudo umount /dev/sdb* rm -r tmp/ mkdir tmp sudo mount /dev/sdb3 tmp cat tmp/etc/vold.fstab
## Vold 2.0 fstab for HTC Passion
Regular device mount
Format: dev_mount <label> <mount_point> <part> <sysfs_path1...>
label - Label for the volume
mount_point - Where the volume will be mounted
part - Partition # (1 based), or 'auto' for first usable partition.
<sysfs_path> - List of sysfs paths to source devices
# Mounts the first usable partition of the specified device
#/devices/platform/awsmc.3/mmc_host for sdio
dev_mount sd card /mnt/sdcard auto /devices/virtual/block/mmcblk0p10
dev_mount extsd /mnt/extsd auto /devices/platform/sunxi-mmc.1/mmc_host /devices/platform/sunxi-mmc.0/mmc_host
dev mount usbhost1 /mnt/usbhost1 auto /devices/platform/sw-ehci.1 /devices/platform/sw_hcd_host0 /devices/platform/sw-ehci.2
Purtroppo sulla mia SD da 8GB non entra il file image, mi dice che (per poco) non entra ... magari ci sono SD da 8GB più capienti
Samsung Galaxy ACE 2
vold.zipprova a sostituire il vold.fstab con quello contenuto nello zip allegato, rimetti la sd nel tablet, riavvia e vedi come va
Ho provato a fare drag&drop con il file, ma su system mi dice che non c'è spazio e non mi permette di spostare nel cestino il vecchio vold.fstab. Va fatto con qualche comando?
devi farlo da linux dopo aver eseguito
sovrascrivi quello nella cartella tmp
