La ROM è wipe per una migliore compatibilità, fate un NandroidBackup prima di procedere.
Download Link - BenzROM V6: BenzROM-V6.zip | by Benz for Galaxy S3 Mini
Download Link - BenzROM V6 NoWipe: BenzROM-V6-NoWipe.zip | by Benz for Galaxy S3 Mini
Nessun supporto per la versione NoWipe!
Thanks to Chainfire per il root.
Thanks to leather.face per gli script.
Thanks to my country neighbour dariolob for his DMod V3 build.prop tweaks and his mods.
Thanks to Exit_Only for his 4cyl Turbo Engine tweaks, awesome work!
Thanks to vonuzu for his Call Recording mod
Thanks to cheech01 for his StatusBar mods.
Thanks to wanam for his 23 toggles notification panel Lidroid mods.
La ROM adesso è veloce, fluida e più stabile!.
BenzROM V2
Fixed: Radio non funziona dopo il flash della ROM
BenzROM V3
Added: AOSP Lockscreen
Added: Ripple Effect LockScreen
Added: Long press back button to kill an app
Added: Darky zipalign
Added: V6 120MB LMK Addon
Added: Many build.prop tweaks
Fixed: SuperSU root not working after flash
Fixed: Some scripts not working properly
BenzROM V4
Added: Call Recording
Added: Ripple Effect LockScreen again (can be disabled or enabled)
Added: 4cyl Turbo Engine
Added: Bravia Engine
Added: xLoud Engine
Added: Battery tweak
Added: sqlite_optimize
Fixed: AOSP LockScreen causing problems when the phone locks in landscape
Fixed: Ripple Effect LockScreen causing some trouble with AOSP LockScreen
Fixed: Auto-Wipe will NOT wipe your internal storage anymore
Fixed: Long Press Back to kill an app toast frame text
Removed: Molti Samsung's bloatware
BenzROM V5
Added: Quad AOSP Lockscreen with 4 options
Added: Transparent Notification Bar
Added: Center Clock
Added: Black Status Bar by default
Added: Automatic Battery Calibration on first flash
Added: Colorized days in S-Planner
Added: Bravia Engine 2
Added: ClearAudio
Enabled: Sub-symbols on stock keyboard - Long press to insert symbol
Enabled: Scheduled messages in stock SMS app
Enabled: MMS download even with data off
Enabled: Folders for messages
Disabled: Contacts joining limit
Disabled: OTA Service and removed "Software Updates" from Settings
Disabled: Phone number auto-formatting
Modded: In-call vibration for notifications enabled
Modded: Inverted email app from black to white - much more readable
Modded: No MMS conversion,no contact limit, real timestamps with sent time instead of received
Modded: Added camera shutter sound toggle in settings
Modded: Camera is now available during a call
Modded: Enabled emojis in stock browser
Modded: Added confirmation prompt when exiting from browser
Modded: Added "Exit" button to browser in menu
Modded: Home browser page instead of about:blank when opening a new tab
Fixed: Long Press Menu Button will open Google Search
BenzROM V6
Added: 4-way Reboot Menu
Added: Smart Rotation
Added: SMS hack: displaying sent Time instead of the received time
Added: SMS hack: SMS 200 recipients, stop SMS to MMS auto-converting, increase SMS hour limit
Added: 23 toggles notification panel (Lidroid way)
Added: Notification panel lock screen and recent apps
Added: BenzROM Addons in Settings for QuickPanel buttons
Added: Ext4 Optimization Tweaks
Added: Camera flash available even if the battery is low
Removed: Darky zipalign
Removed: V6 120MB LMK Addon
Modded: Increased vibration intensity on AOSP Lockscreen
Modded: No Increasing Ringtone
Modded: Center clock in AOSP LockScreen
Modded: Camera flash available even if the battery is low
Fixed: SetupWizard doesn't start on the first boot
BenzROM V6 Hotfix:
Fixed: Icons now remain sorted as you sorted them after reboot
Fixed: Hidden programs now remain hidden after reboot
Removed: Black Status Bar by default
Download: http://forum.xda-developers.com/atta...5&d=1374758129
Istruzioni:
- Scaricare il file -zip
- Metterlo dentro la SD Card
- Riavvia in recovery (CWM o TWRP)
- Wipe cache, factory data e Dalvik cache
- Flashate BenzROM-V6.zip dalla vostra SD Card
- Reboot and enjoy
Screenshots!
Una tra le migliori ROM per SIII Mini creata da BenzOnator [XDA-Forum], thread originale: [ROM][CWM][Multi-CSC] Stock I8190XXAMB3 4.1.2 - BenzROM V6 - xda-developers
