come fluidita...e poi nelle ultime non si vedono novità visive rispetto a quella del 18
com l'ultima ad esempio non riesco ad agganciare wifi
..il fancy a breve dovrebbe uscire
con r45 sto seguendo questi settaggi e non mi trovo male xD
Oneplus 9
Oneplus 5 6/64
ROM: Pixel Experience 9.0
Nexus 5
Galaxy Nexus (venduto)
nuova versione
BeanStalk-4.4.275-20140407-maguro
[Smartphone] Samsung Galaxy S6 Flat (SM-G920F)
[ROM] Noble Nougat Experience 4.5
[kernel] Kiboi kernel 2.5
morfances (07-04-14)
New build is out!!
Changelog
"add "Turn Wi-Fi off" action to the "open networks available" …
"Fix NPE for WiFi off notification action"
Correct the updation of extension sample rate
fix the mac build
fixes for battery saver mode
Volumes in Settings/Sound is slow to start
Frameworks: add a bunch of national roaming providers
releasetools: use variable instead of fixed name for bootable image
"Proper security labeling of multi-user data directories."
Revert "Merge "frameworks/base: forward port DC-HSPAP support from cm…
Revert "hammerhead: Update storage configuration for usbdisk"
Revert "usb: dwc3-msm: replace wakelock with wakeup source"
Revert "USB: u_ether: Set complete handler before queueing to endpoint"
random: adjust the generator polynomials in the mixing function slightly
random: speed up the fast_mix function by a factor of four
charger: Underp the backlight
email: add support for Server Name Indication (SNI)
mediaprovider: Add theme support to Ringtone activity
contacts: Holo Light ringtone picker dialog
build: Add support for Luxembourgish
Settings: Integrate Voice+ into Settings (1/2)
Settings: update Privacy Guard help text string
core: Add support for Luxembourgish
bootanim: Add continuous splash support
Camera2: if camera HAL does not return valid picture formats do not s…
Revert "Base: Fix for the race in Wallpaperservice"
Ultima modifica di morfances; 08-04-14 alle 08:12
Oneplus 9
Oneplus 5 6/64
Nexus 5
Oneplus 9
Oneplus 5 6/64
Nexus 5
a me va o.O
http://www.mediafire.com/download/7o...408-maguro.zipnasty007:
Sorry guys, but new build with new version is UP
I made build yesterday and today Beanstalk was updated to 278
Changelog- https://github.com/scotthartbti?tab=activity
morfances (09-04-14)
Oneplus 9
Oneplus 5 6/64
Nexus 5
io ho abbandonato l'app dei messaggi da tempo......... uso Hangout e basta!
Nexus 6--> NitrogenOS 7.1 /f2fs
GNEX--> [GNEX unified] OMNI 4.4.4 - cMetal ext4/f2fs NautyTRASP.
Oneplus 9
Oneplus 5 6/64
Nexus 5
ah! ...buono a sapersi...
