[ROM][09/29/14] ILWT ROM 3.0.17 (KitKat) || ILWT CM7 879 (discontinued)
    copy paste and 2 much thanks to XDA-DEVELOPERS
    LINK: [ROM][09/29/14] ILWT ROM 3.0.17 (KitKat) || … | G2 and Desire Z | XDA Forums
    DISCLAIMER: I will take no responsibility if you brick your phone or if this ROM screws up your phone in any shape or form.
    Credits
    CyanogenMod
    Andromadus
    OmniROM
    Dirty Unicorns
    AICP
    SlimRoms
    Paranoid Android
    Chainfire
    JustArchi
    If anyone has been left out, please send me a PM and you will be added. I'm getting old and I can easily forget even the most obvious things.
    The Mods
    Find changelog on G+ community or in post #2
    Download Links
    BasketBuild : http://www.androidfilehost.com/?w=files&flid=17058
    AndroidFileHost (old releases) : http://www.androidfilehost.com/?w=files&flid=17058
    You can also use ILWT Updater from the ROM
    ILWT ROM 3.0.17 md5: 3567e66d4203cf6f5fb61af474cc3492
    ILWT ROM 3.0.16 md5: c01c40b85e2895fd8b48c916c0b5329a
    ILWT ROM 3.0.15 md5: 58a1df14c409c343487ec13a3795b2c4
    ILWT ROM 3.0.13 md5: 5dfb7ff9e137b2caa3fe6d6067d90169
    ILWT ROM 3.0.12 md5: cef400d5fa7ceb231182da926659b2b9
    Installation
    Simply flash the .zip file from recovery (it must support KitKat ROM, latest versions of TWRP and 4ext should work), nothing fancy needs to be done. Make sure to do a full wipe if you are coming from a different ROM.
    Bug Reports
    If you are going to report any bug, please do it only after a full wipe, with stock kernel, and no other modification to the ROM (especially no Xposed). Also, you must provide logs (logcat and/or last_kmsg). I will not look into the issue if any of these requirements aren't satisfied.
    G+ Community
    This is where I usually announce new releases and their changelog: https://plus.google.com/communities/...07512244821825
    Donators
    • bclark1000
    • KwiHa
    • Ditamae
    • bazantik
    • L-ViZ
    • dib_uk
    • Smajlo
    • mistm
    • dublox
    • dsip
    • =JKT=
    • PDignam
  2. Il seguente Utente ha ringraziato marameo89 per il post:
    JackTheJoker (24-10-14)
    Senior Droid L'avatar di JackTheJoker
    Cervia
    S7 edge
    MOMENTOMOMENTOMOMENTOMOMENTO
    ILWT KK? sembra natale+pasqua.
    scherzi apparte, pareri? battery drain, lag, bug riscontrati, etc?
  5. #3
    è inutilizzabile, in un ora ho tirato piu bestemmie che tocchi sul touchscreen
  6. #4
    Cervia
    S7 edge
    Quote Originariamente inviato da marameo89 Visualizza il messaggio
    peccato, anche perchè essendo discontinued non ci si possono aspettare aggiornamenti :c
  7. #5
    stai ancora usando la jelly mod? io si mi ci trovo molto bene, ho messo un task manager che quando blocco lo schermo mi leva tutti gli schifi di app in maniera che quando lo riaccendo sia svelto, eliminando la laggata che ogni tanto mi veniva fuori quando sbloccavo o quando dovevo rispondere a una chiamata (ogni tanto con impappinamento completo)
  8. #6
    Cervia
    S7 edge
    non ho ancora avuto voglia di provarla in verità XD (nè il tempo, tra scuola guida, studio etc. ho ben poco tempo libero ultimamente)
    ero tornato appunto per dare un'occhiata e vedere se le altre rom si erano aggiornate quando mi sono imbattuto su questa kk
  9. #7
    beh, beh, male mooolto male! xD
