Pagina 2 di 6 primaprima 1234 ... ultimoultimo
Visualizzazione dei risultati da 11 a 20 su 53
[ROM] LeeDrOiD HD
  1. #11
    Senior Droid L'avatar di famonaco
    dopo una lunga attesa è uscita
    le caratteristiche sono eccellenti
    versione 1.50
    (New Kernel based on Apache Buzz latest source, forked and modified)
    Added LeeDrOiD V1.2a OC/UV Kernel (Partial UV - very stable)
    New heavily optomized Smartass govenor idles @ 245 - 422mhz (Ramps on demand)
    Default CPU freq 245-1032mhz @ smartass (Almost stock speeds)
    Heavily modified Cpu frequency table (for details refer to post #2)
    Heuge battery improvment
    A2SD+ included but optional (if you want it just add an ext3 partition, HOW TO in post 2)
    Further adjusted autobrightness values
    Added back "fly" animations < can be disabled in settings.
    Updated Adobe flash V10.1.106.16
    Updated Titanium backup V3.6.7.1
    Updated fancy widget V2.1.4.1
    Updated CIFS Manager V1.5
    Updated Ad-Free V0.6.4
    Updated Android Market V2.2.11
    More cleanups & Tweaks
    LeeDrOiD Kernel - Custom freq & Voltage table
    LeeDrOiD Freqs & Voltages -------------HTC "Stock Freqs & Voltages
    { 245000, 900, VDD_RAW(900) }, ----- | ----- { 245760, 1000, VDD_RAW(1000) },
    { 422400, 925, VDD_RAW(925) }, ----- | ----- { 368640, 1050, VDD_RAW(1050) },
    { 460800, 950, VDD_RAW(950) },
    { 499200, 950, VDD_RAW(950) },
    { 537600, 975, VDD_RAW(975) },
    { 576000, 975, VDD_RAW(975) },
    { 614400, 975, VDD_RAW(975) },
    { 652800, 1000, VDD_RAW(1000) },
    { 691200, 1000, VDD_RAW(1000) },
    { 729600, 1000, VDD_RAW(1000) },
    { 768000, 1025, VDD_RAW(1025) }, ---- | ---- { 768000, 1100, VDD_RAW(1100) },
    { 806400, 1025, VDD_RAW(1025) }, ---- | ---- { 806400, 1100, VDD_RAW(1100) },
    { 844800, 1025, VDD_RAW(1025) },
    { 883200, 1025, VDD_RAW(1025) },
    { 921600, 1050, VDD_RAW(1050) },
    { 960000, 1050, VDD_RAW(1050) },
    { 998400, 1050, VDD_RAW(1050) }, ---- | ---- { 1024600, 1200, VDD_RAW(1200) },
    { 1036800, 1075, VDD_RAW(1075) },
    { 1075200, 1075, VDD_RAW(1075) }, >>>>>>>>># Max allowed VDD is 1300
    { 1113600, 1075, VDD_RAW(1075) }, >>>>>>>>># Min allowed VDD is 750
    { 1152000, 1100, VDD_RAW(1075) },
    { 1190400, 1100, VDD_RAW(1075) }, <<<<<<<<<# All frequencies are using voltages within
    { 1228800, 1100, VDD_RAW(1100) }, <<<<<<<<<# Safe working limits
    { 1267200, 1125, VDD_RAW(1125) },
    { 1305600, 1175, VDD_RAW(1175) },
    { 1344000, 1175, VDD_RAW(1175) },
    { 1382400, 1200, VDD_RAW(1200) },
    { 1420800, 1225, VDD_RAW(1225) },
    { 1459200, 1225, VDD_RAW(1225) },
    { 1497600, 1250, VDD_RAW(1250) },
    sai che c'e' e' ke le caratteristiche sono eccellenti in tutte pero' poi bisogna vedere se e' veramente cosi' ehehehe
    Androidiano VIP L'avatar di lorefly
    Nov 2010
    livorno
    samsung galaxy s2
    Ringraziato 26 volte in 23 Posts
    versione 1.50
    l'hai provata questa rom??
    Samsung Galaxy Note 2
    Codice Modello: GT-7100
    Gestore Telefonico: H3g
    Rom: Omega v18
    Kernel: Stock
    Baseband MG1
    Versione Android: JB 4.1.2
  4. #13
    Androidiani Power User
    Dec 2009
    Rimini
    Quote Originariamente inviato da lorefly Visualizza il messaggio
    ce l'ho su adesso questa deve consumare ancora meno
    l'unica cosa ha il display un po basso ,ho chiesto se si puo alzare.....
  5. #14
    Nov 2010
    livorno
    samsung galaxy s2
    basso in che senso?
    ma le differenze tra questa e la revo 2.08?
    e piu stabile piu veloce ha delle cose che non ha la revo consuma neno?
    Ultima modifica di lorefly; 28-01-11 alle 15:55
    Rom: Omega v18
    Kernel: Stock
    Baseband MG1
  6. #15
    Jan 2011
    BERGAMO/valbrembo
    ho aggiornato a questa versione...
    sono l'unico che ha problemi con il market?
    scarica ma non lascia installare nulla...
    EDIT: mi correggo...il problema credo sia nel programma che gestisce l'installazione delle applicazioni e non nel market
    Ultima modifica di meis; 29-01-11 alle 17:54
  7. #16
    Dec 2009
    Rimini
    Quote Originariamente inviato da meis Visualizza il messaggio
    vai nelle applicazioni, gestisci applicazioni,tutte, e individua market
    poi cancella cache e dati
    riavvia e riprova
    vedi se va
  8. #17
    Androidiano VIP L'avatar di zzzg
    Jul 2010
    Provincia di Milano
    Galaxy s4
    Ringraziato 108 volte in 105 Posts
    Sembra che sia lo script di a2sd la causa,nel thread di lee c'è una patch che risolve eliminando lo script
    [ROM] LeeDrOiD HD v1.5.0 >>EPIC<< [27/01 | Fast | Stable | OC/UV | A2SD | CIFS | TUN] - xda-developers
    Smartphone:SENSATION XE
    ROM : SmartDroid Resurrection
    RADIO: 11.22.3504.07_M
    RIL : 4.0.0013HMQ
  9. Il seguente Utente ha ringraziato zzzg per il post:
    meis (30-01-11)
  10. #18
    Jan 2011
    BERGAMO/valbrembo
    risolto... gentilissimi come sempre
  11. #19
    Dec 2009
    Rimini
    è uscito il kernel 1.3 per questa rom
    http://db.tt/GKfKLLT
  12. #20
    Jan 2011
    BERGAMO/valbrembo
    ora ho...
    kernel 2.6.32.28-buzz_1.2.2_OC+
    radio 26.06.04.06_M
    con Leedroid_HD_V1.5.0
    consigliate di cambiare il kernel o qlks'altro?
