Sono ben accettati i ringraziamenti, grazie
http://www.stampicementofaidate.altervista.org/ Mi 9 - Mi 8 -- LEeco LE 3 PRO X720 -
ottimo , scaricata funziona benissimo con X620 in piu mi si e aggiunta la funzione corsa che monitorizza il battito cardiaco, che prima non vi era. grazie daniele facci anche sapere quando sono disponibili i nuovi mii band quelli con il display grazie.
esperanza (08-06-16)
Post 3 sezione MODS aggiunta mod per impostare un blocco per ogni singola app usando impronta o PIN o sequenza
Enjoy!
installato e funziona benissimo, Ottimo!!
Hi! First of all,well done for this ROM,works great! Also,please tell me if the light notification for calls,sms,email,work?I try activate all this from pulse notification light and from permissions (app permission management and notification permissions) but without any results.Thank you very much in advance for response
DanieleGS (09-06-16)
Hi BB72, once again thank you for your advice.After enable in pulse notification light - "other", works.Best regards
Hi, BB72
Thank you for great job =)
I have found some bug - Google Play Music (All Access) plays one/two songs normally, then sound disappear.
If I change track manually sound come back for one song, then again disappear.
Other music player work fine - Apple Music, Yandex Music
The same problem as here - https://www.reddit.com/r/oneplus/com..._but_no_sound/
Could you fix that or say what could I do?
Thank you very much!
