Sono tornato alla 2.4, ho avuto 2 freeze con l'ultimo kernel.
Samsung Galaxy S7
Rom: SuperStock
Kernel: Superstock 2.0
Recovery: TWRP 3.0.2.4
sulla mia rom AEONFLEX ho notato che ho la 1.4 (vecchiotta) quale consigliate che sia un buon compromesso trà stabilità -consumi- e prestazioni.....? grazie
( be Android)
Qualcuno mi può postare il link per scaricare il kernel originale? Non ho fatto il backup e vorrei rimetterlo ma non so dove prenderlo! Ho la D802 eur 10f grazie!
Ecco il link per il kernel originale e anche per le versioni precedenti del dorimanx
www.dorimanx.com/LG/
Se scrolli fino infondo lo vedi😉
marchino8 (02-03-14)
uscita la 2.9 stabile
Kernel 2.9 STABLE:
*Reverted some of KK Kernel source updates to gain stability.
*Merged new WIFI driver 1.88.60 + all patches
*Tuned ondemand Gov to deliver good performance.
*Merged USB + NET +HWMON code from KK Kernel source 20c
*Updated NFC Driver for all branches
*Merged fixes to workqueue code for I/O operations.
*Removed some debug counters to free cpu from useless jobs.
Kernel reported to be stable and fast as should be. (i dont care about bench!)
it's normal any way...
e la 3.0 in test
Kernel 3.0 IN TEST:
*Reverted Sound code update from ls980 ZVA to fix Flac 24Bit 96Khz playback
via default player. (was working with paid players)
*Added Sweep2Sleep on/off in STweaks TWEAK tab.
*Merged many updates from KK Source kernel! that include:
Power code that allow great battery save on sleep and wake.
Modem Driver code, bug fixes,
CPU code fixes,
Memory bugs fixes.
*Merged new option for force fast charge to fake USB connection and force as AC
this mode has side effect, connection will be x2, 2 sounds 2 vibrates...
*Fixed locked max mA charge to 1500, now max 1800.
*Removed GPU govs SIMPLE and CONSERVATIVE. unstable and not really needed.
*Boosted all CPU govs to deliver more power and give as smoothness.
3.1
Kernel 3.1 IN TEST
Fixed BUILD!
*Fixed boot for other branches
*Fixed high freq on idle.
*Updated with 3.4.83 main line patches.
*Merged some Power MNG code from KK Source
*Merged new updates to Intelli Hot Plug and Intelli Temp from Faux123 source!
*Merged Voltage corrections to cpu/gpu/screen to reduce power waste.
*Fixed Ondemand sampling rate and updated functions from Hyper to ondemand!
*Merged update to Alucard Hotplug
*Updated MMC code from KK Source! will reduce power usage on sleep.
*Merged fixes to cpu boost code! much less micro lags..
*Updated Entropy random code to speed up the system.
*Reverted some power/board merges from KK source that we cant use and best not to have till we move to KK ROM + Kernel.
*New the CPU Freq limit will work much better it's will not let user or any service / app to change cpufreq higher than the limit!
USE STWEAKS TO CONTROL MAX FREQ LIMIT!!!
30/03/14
Kernel 3.3
*Fixed delays in ondemand gov. now it's has supreme power.
*Merged CM11 KK updates from codeaurora.org
A lot of CPU, ARM and RAM bug fixes and improvements!
130 Commits!
CPU heat reduced. and delays eliminated.
Suspend improved and much more.
29/03/14
Kernel 3.2.1 STABLE.
*Fixed critical BUG with Intelli Hotplug and CPU stress tests!
any bench app was making hot boot if using Intelli HotPlug
Now OK. please update!
28/03/14
Kernel 3.2 IN TEST
*Fixed CPU idle! now stay more on low freq and save power.
*Fixed Ram leaks
*Reverted some of the USB and PWR code that i merged from KK and ZVA
i dont see any change, only more stable STOCK code.
*I and Alucard_24, we did really big rework to Intelli Hot plug driver and to Alucard HotPlug!
Now they work better and faster.
intelli HotPlug can be selected ONLY via STweaks! other apps dont see it any more.
The control path is changed, i have alerted Faux123 and offered to update his code and app with new path.
*Tuned intelli thermal control driver.
*Reworked all CPU govs to use global function!
*Updated to Max Entropy random generator code from 3.14.rc6 kernel.
*Updated MMC (Sdcard) code.
*Patched with 3.4.84 patch.
kernel is stable and fast for me D802!
I hope it's will be the same for other branches.
30/03/14
Kernel 3.3
130 Commits!
05/04/14
Kernel 3.4
*Patched with 3.4.85 + 86 main line updates.
*Alucard24 made many updates/fixes to Alucard hotplug gov.
it's stable and good to use any time.
*Me and Alucard24, we updated the Intelli HotPlug and fixed all bugs in it.
Now it's working great, i use it as daily driver! it's extremely fast and powerful.
*Merged updates for OOM so RAM management is improved.
*Merged fix for RAM leak in video driver.
*Added SuperSu 1.94 to kernel zip.
*Updated Interactive and Ondemand Cpu Govs.
and tuned for best performance vs battery preserve.
*Boosted internal kernel clock from 100HZ to 200HZ
This give us performance boost in all functions across the kernel.
Dont look in BENCH tests, it's not shown there...
*Tweaked ROM Thermal Engine driver,
now it's will allow 82C max and stop limiting freq below 65C was (80/60) = Small performance boost.
*Fixed Block Ads file update. now will work as should.
Ultima modifica di edoardomarco; 09-04-14 alle 11:06
05/04/14
Kernel 3.4 STABLE
12/04/14
Kernel 3.5
*New updates to Alucard HotPlug by DEV him self.
It's more smart and very powerful but that comes with the price of more battery drain.
Any way it's very good.
*Tuned and Updated Ondemand Gov. now much more battery friendly and still smart and fast.
*Many fixes to RAM and OOM code from main line kernel.
*I have merged Darkness CPU gov and Alucard Cpu GOV.
Darkness is good for battery save it's simple and doing what it's should by his name! Sleep!
The alucard gov is not working as should, so leave it alone for now, it's STUCK on max freq all the time.
*I have merged Intelli Thermal driver in too MSM Thermal Driver + updated from KK Source.
We still have DEFAULT thermal that uses ROM binary + file config for temp control
And we have the Intelli Thermal as was but CORE of it is a lot better now! as it's now has all the rest of the driver that was OFF till now.
Any way it's working great with Intelli HotPlug or Alucard HotPlug.
Do not use it with Default HotPlug! freq will be stuck on on limited point when overheated!
Rom HotPlug have no idea how to rise to max again...
*Added some missing Kernel configuration based on KK Source!
Many of network code was missing for LS980 and VS980!
So this may fix many NET problems!
*Merged all new Critical patches for Kernel RAM and USB + MMC
This is probably LAST JB Kernel! new will be KitKat base ( tradotto: questo sara il mio ultimo kernel su base JB, il prossimo sara su base KITKAT )
Ultima modifica di edoardomarco; 17-04-14 alle 11:53
Scusate il triplo post, comunque:
IL KERNEL E' ORA COMPATIBILE ANCHE CON KITKAT
