Pagina 3 di 23 primaprima 1234513 ... ultimoultimo
Visualizzazione dei risultati da 21 a 30 su 230
[ROM] Official CyanogenMod 10.2 [4.3]
  1. #21
    Quote Originariamente inviato da Rebecca92 Visualizza il messaggio
    ti va di postarlo?
    Since Wed Aug 14 06:52:28 UTC 2013
    android
    •*299b991 libusbx
    bionic
    •*4172806 libc: add tegra2 TARGET_CPU_VARIANT
    external/heimdall
    •*61f67d4 fixes for building windows
    •*c546475 Switch UsbLogLevel back to an int.
    •*49a02b8 Merge remote-tracking branch 'bd/master' into cm-10.2
    •*c82df27 switch to libusbx
    external/koush/Superuser
    •*17c92e9 Superuser: CS translation
    external/libusbx
    •*591d976 Fixes for libusbx on AOSP.
    frameworks/base
    •*def69e1 Merge "Frameworks: FR translation" into cm-10.2
    •*f3e9f42 SystemUI & core: fixed FI translations
    •*24bffcd Frameworks: FR translation
    •*7916ca9 Remove redundant click action from date & time container layout
    frameworks/opt/telephony
    •*dec32f9 Merge "Telephony: prevent NPE" into cm-10.2
    •*72c14ed Telephony: prevent NPE
    •*3fdb1fc telephony: set PROPERTY_DATA_NETWORK to data technology
    hardware/qcom/audio-caf
    •*06163d2 Merge "alsa_sound: Add support for sound card in Galaxy S4 Mini" into cm-10.2
    •*4ff6902 alsa_sound: Don't use USB devices for calls
    •*e36366f alsa_sound: Clean up makefiles
    packages/apps/CMFileManager
    •*87dbdd4 Merge "CMFileManager: FR transaltion" into cm-10.2
    •*d27191a CMFM: PT-BR translations
    •*7d08d11 CMFileManager: FR transaltion
    packages/apps/CMUpdater
    •*f52ad8f CMUpdater: FR translation
    packages/apps/Calendar
    •*e4f0372 Calendar: FI translations
    packages/apps/DSPManager
    •*aa7abce DSPManager: PT-BR update translations
    •*027547d Add category for docks and USB devices
    packages/apps/Dialer
    •*acd7b06 Merge "Dialer: FR translation" into cm-10.2
    •*551f79e Merge "Dialer: IT translations" into cm-10.2
    •*6984f7d Dialer: PT-BR update translations
    •*95dfc7e Merge "Dialer: FI translations" into cm-10.2
    •*5ba4bf0 Dialer: FI translations
    •*4259867 Dialer: FR translation
    •*0e6cf3f Dialer: HU translation
    •*688f47f Dialer: IT translations
    packages/apps/Email
    •*e98bcdf Email: FI translations
    •*9a44280 email occasionally crash on boot complete
    packages/apps/Focal
    •*b19f054 Merge "Focal: General code reformat" into cm-10.2
    •*f22f178 Focal: PT-BR update translations
    •*bf06f2d Focal: General code reformat
    packages/apps/Gallery2
    •*fe6f4f7 Merge "Gallery2: ES translations" into cm-10.2
    •*20e3e8e Gallery2: PT-BR update translations
    •*f571c44 Gallery2: ES translations
    packages/apps/KeyChain
    •*bc38178 KeyChain: FR translation
    packages/apps/LockClock
    •*dd46c40 LockClock: PT-BR update translations
    •*f764bcb Merge "LockClock: HU translation" into cm-10.2
    •*255c2d4 cLock: NL translation
    •*5bc37b0 LockClock: HU translation
    packages/apps/Mms
    •*ff5a08c Merge "Mms: RU translation: plurals" into cm-10.2
    •*0005688 Mms: PT-BR update translations
    •*625a255 Mms: RU translation: plurals
    •*053e9d9 Merge "Mms: HU translation" into cm-10.2
    •*bbb03de MMS: NL translation
    •*139922a Mms: HU translation
    packages/apps/Phone
    •*ddb954f Merge "Phone: PT-BR update translations" into cm-10.2
    •*2ad43bd Phone: PT-BR update translations
    •*fdd5576 Phone: HU translation
    packages/apps/Settings
    •*0c1e1a6 Merge "Settings: EL translations" into cm-10.2
    •*dec9477 Settings: PT-BR update translations
    •*997c328 Settings: EL translations
    •*051862c Merge "Fix adding lockscreen targets." into cm-10.2
    •*2fa3107 Merge "Remove unused stuff." into cm-10.2
    •*fa1f967 Remove debug leftovers.
    •*8e91d6c Remove unused stuff.
    •*aab9868 Fix adding lockscreen targets.
    packages/apps/Trebuchet
    •*4101b1d Trebuchet: Reset to AOSP strings
    •*12e91c0 Trebuchet: FI translations
    •*e7ecbd3 LiveFolders : Scale icon sizes
    packages/apps/VoicePlus
    •*d746a26 VoicePlus: FR translation
    packages/inputmethods/LatinIME
    •*9906e38 LatinIME: FI translations
    vendor/cm
    •*2b91300 Merge "Add a default root access mode." into cm-10.2
    •*127ac8a Add a default root access mode.
    •*a3310a3 vendorsetup: Use cm-10.2 lunch targets
    lg optimus 4x hd
    Le mie prime impressioni sulla batteria sono positive
  4. #23
    Gravina di Catania
    Lg Optimus 4X
    ragazzi ho fatto l'aggiornamento ma mi si blocca il cell sul logo cyano. ho fatto tutti i wipe tranne i data /factory visto che non ho fatto un backup dei dati e ogni volta che installavo una nuova versione della cyano andavo a fare solo il wipe cache e dalvik. Ora è tutto bloccato e non posso usare il cell. Mi date una mano per favore?
  5. #24
    Androidiano VIP L'avatar di lucaarx
    Sant'Angel!!!
    LG Optimus 4X HD
    Ringraziato 564 volte in 418 Posts
    ma con la cyano non serve fare wipe cache e dalvik con l'aggiornamento via ota... scarichi la rom da info su telefono/aggiornamenti e poi fa tutto lui.
    Dovresti provare a flashare da recovery una versione precedente che funziona...
    C'è chi è stato ammaestrato e subisce col capo chinato... noi no...
    Chi non ha mai vomitato ubriaco, chi ha servito lo stato.... noi no....
    Chi ha amore per il potere, chi ti dirà "Sissignore!!"... noi no...
    Chi un'opinione la gira a seconda del vento che tira.... noi no....
  6. Il seguente Utente ha ringraziato lucaarx per il post:
    Bruxon (16-08-13)
  7. #25
    Gravina di Catania
    Lg Optimus 4X
    vengo dalla 10.1 , in pratica stamattina ho fatto l'aggiornamento senza accorgermi che sarei passato alla 10.2, ho fatto i due wipe di cui parlavo sopra ma il cell non riusciva ad avviarsi normalmente. Ovvero continuava a rimanere sul logo cyano. Cosa mi consigliate di fare? Ho dei dati importanti sul cell tra cui alcune foto. Con il wipe data/factory le perdo?
  8. #26
    Gravina di Catania
    Lg Optimus 4X
    Quote Originariamente inviato da lucaarx Visualizza il messaggio
    ci ho provato ma rimane bloccato sempre sul logo cyano. Avevo rimesso la 10.1 ma niente di niente
  9. #27
    Sant'Angel!!!
    LG Optimus 4X HD
    no, non le perdi. Non perdi nulla, a parte le applicazioni che hai installato tu. Wipe data/factory reset cancella solo le cartelle /data e /cache, non va a toccare la /sdcard.
    Come mai non aggiorni via ota?
  10. Il seguente Utente ha ringraziato lucaarx per il post:
    Bruxon (16-08-13)
  11. #28
    Gravina di Catania
    Lg Optimus 4X
    per via ota intendi da info telefono-aggiornamento cyano, no? Dicevo se perdo le foto perchè alcune le ho sulla sd esterna altre invece sul telefono. Ma se mi dici che non perdo nulla allora procedo.
  12. #29
    Gravina di Catania
    Lg Optimus 4X
    non potrebbe essere una incompatibilità con le gapp nuove?passando ad una nuova versione della cyano magari quelle che avevo non sono compatibili
  13. #30
    Sant'Angel!!!
    LG Optimus 4X HD
    si, così intendo. Aggiornando in quel modo non serve fare wipe cache e dalvik.
    No, non perdi nulla.... la cartella /sdcard e la microsd esterna non vengono toccate
    non saprei.... penso che android dovrebbe comunque partire, e dare errore con le gapps.... va beh, prova a riflashare...
    Ultima modifica di lucaarx; 16-08-13 alle 10:42
  14. Il seguente Utente ha ringraziato lucaarx per il post:
    Bruxon (16-08-13)
