Visualizza i risultati del sondaggio: Hai reboot con il Cor Plenus v2 e nel caso con quale SIM?
Chi ha votato
32. Non puoi votare questo sondaggio
  • NO: SIM 3
    2 6.25%
  • NO: SIM Wind
    4 12.50%
  • NO: SIM Tim
    3 9.38%
  • NO: SIM Vodafone
    2 6.25%
  • NO: Foreign SIM
    0 0%
  • SI: SIM 3
    0 0%
  • SI: SIM Wind
    14 43.75%
  • SI: SIM Tim
    3 9.38%
  • SI: SIM Vodafone
    3 9.38%
  • YES: Foreign SIM
    1 3.13%
Pagina 2 di 17 primaprima 123412 ... ultimoultimo
Visualizzazione dei risultati da 11 a 20 su 167
[SONDAGGIO] Reboot in Cor Plenus v2/ROM Optimus 2.0
  1. #11
    Ringraziato 15 volte in 4 Posts
    Quote Originariamente inviato da Michelasso Visualizza il messaggio
    Is your governor always set to "performance"?? That would be wrong, it always keeps the highest frequency (832Mhz in your case). use ondemand or lagfree.
    For testing you should try to use the other frequencies. Set them MAX=MIN=freq, with freq starting from 156MHz and raising. For each step you should try to reproduce the reboot. Then write it here the list of frequencies when the phone reboots.
    Still, if you say that with Cor Plenus v2.0 it was fine I believe that something may be wrong in the installation and/or /data. 2.0 is supposed to be much worse than 2.02 in terms of reboots.
    Which kernel are you sing right now anyway? I've got a bit lost.
    PS: Biancale, ma non avevi detto che i tuoi reboot erano spariti?
    Now i'm using cor optimi v1 with JellyPlus 2.0
    Yesterday, i'm using fresh stock rom with cor plenus 2.0.2 with 624Mhz-156Mhz and governor is Ondemand. I/O is sio (I'm always use this for saving my battery if i'm go to school and no problem with CPlenus 2.0)
    That condition still make my phone restarting (I'm not turning WiFi, but calling my friend ask for HW)
    Maybe next time i'll try your solution, time to sleep here and tomorrow is exam.. thanks for helping michel, keep work if you have much time with better kernel for our device
    Nice to join here
    Androidiano VIP L'avatar di Michelasso
    Treviso
    Ringraziato 984 volte in 486 Posts
    Quote Originariamente inviato da Fahmi1597 Visualizza il messaggio
    Nice to join here
    Well, when you have time please do. I forgot to ask which ROM people are using in the list. The mix of the two could cause issues too. But you were on stock ROM anyway. Still I need you to test it. You can install Cor Plenus v2.02, do the tests and install Cor Optimi v1 over it.
    PS: Ma gli italiani sono tutti con la Wind?!
    Se sono stato utile non dimenticare di premere Thanks!
    Visita la mia collezione di temi per telefoni e tablet Xperia!
  4. #13
    Androidiano L'avatar di themind
    OnePlus 2
    Ringraziato 37 volte in 22 Posts
    Beh la TIM e la Vodafone hanno delle tariffe troppo care e la tre non prende dappertutto. Resta la Wind.
    Del resto, c'è crisi
    Se vi sono stato utile fate un thanks
  5. #14
    SAMSUNG GT-S5570I
    Ringraziato 1,091 volte in 873 Posts
    Ecco la mia esperienza:
    - Tipo di scheda SIM: usim 3
    - Età della scheda: 11 mesi
    - Situazione in cui si verificano i reboot: frequentando un posto sconveniente (roaming ), solo una volta
    - Ogni quanto accadono: massimo 2-3 volte al mese se succede
    - Quale CPU Governor/Frequenze usate (lo vedete con NO Frills CPU): 156-832 ondemand sio
    - Se con il kernel stock perdevate il segnale e/o la connessione dati: no
    - Se con il kernel Cor Plenus v2 avete mai perso il segnale e/o la connessione dati: no
    Io ho avuto un'esperienza positiva con i vari kernel, probabilmente questo telefono predilige le sim recenti.
    Guida per partizionare la microsd: HERE
    Tutti i file per il Next Turbo nel mio repository: HERE
    Premi a sinistra per ringraziarmi se ti son stato d'aiuto!
  6. #15
    Treviso
    Il grafico inizia a mostrare quello che si sospettava da sempre… ossia che il problema è soprattutto con le schede Wind. Ma servono più dati…
    Forza ragazzi!! Non siate timidi!! Votate e riportate la vostra esperienza!!
    PS: peccato che il sondaggio sulla perdita del segnale/conessione dati nella sezione principale sia stato fatto male. Sarebbe stato interessante correlare i diversi dati!
  7. #16
    Galaxy Next Turbo
    - Tipo di scheda SIM: Wind 128K
    - Età della scheda: 1 anno
    - Situazione in cui si verificano i reboot: poco dopo l'inizio della chiamata
    - Ogni quanto accadono: spesso
    - Quale CPU Governor/Frequenze usate: quello standard
    - Se con il kernel stock perdevate il segnale e/o la connessione dati: SI
    - Se con il kernel Cor Plenus v2 avete mai perso il segnale e/o la connessione dati: non mi pare
  8. #17
    Androidiano VIP L'avatar di ZackFair84
    LG G5
    Ringraziato 1,022 volte in 794 Posts
    Quote Originariamente inviato da windman73 Visualizza il messaggio
    hai rom stock+kernel, oppure rom optimus+kernel?
    Proud developer of Galaxy Next Turbo Custom Rom Optimus Rom™ 3.0.0 testing
  9. #18
    Galaxy Next Turbo
    Quote Originariamente inviato da ZackFair84 Visualizza il messaggio
    Custom Rom Optimus Pro Beta 3.1
    Kernel Cor Plenus V.2.02
  10. #19
    LG G5
    grazie per le info comunque, dato che ho visto che hai frequenti reboot, potresti provare a mettere il kernel cor optimi v.1, e vedere se la situazione migliora, intanto
  11. Il seguente Utente ha ringraziato ZackFair84 per il post:
    windman73 (08-11-12)
  12. #20
    Treviso
    Vabbè, mi pare ormai un dato di fatto che il problema è con il modulo 3G del kernel (stock) e alcune schede Wind. Che a quanto pare non gradiscono le nuove frequenze/voltaggi. Per chi ha i reboot, se mettete il telefono in 2G, questi finiscono?
