Pagina 3 di 12 primaprima 12345 ... ultimoultimo
Visualizzazione dei risultati da 21 a 30 su 115
[ROM] [DEV] JellyPlus v2.0 [Eng]
  1. #21
    Ringraziato 15 volte in 4 Posts
    Quote Originariamente inviato da Michelasso
    Originariamente inviato da Fahmi1597
    Decode CWM 5.0.2.8 if one has fixed .. other bugs will come ._. this make me crazy o.O
    Sorry, what do you mean? There is one called "decode CWM"? Do you have a link? Or you want me to decode the CWM?
    Yep, michel.. the developer of px-kernel try to fix cwm 5.0.2.8 but if other one has fixed the another bugs will come ..
    Sent from My Galaxy Mini Plus with JPlus 2.0 via Androidiani App
    SAMSUNG GT-S5570I
    Ringraziato 1,091 volte in 873 Posts
    @fahmi: nice rom, I'm trying it right now, but as always I have some questions :
    1) Under settings -> quickpanel settings, tap on it and it FC, is it normal?
    2) Black characters on grey background make reading some options very annoying, can you change it?
    3) Your rom comes with stock kernel and you provide a link to cor plenus 2, is it the right 2.02 or just the plain 2.0? It's not the same . Also, if you wish to link cor optimi 1.0 or the latest plenus, you can check my repository. Almost all the files have the source thread attached.
    Regards
    Edit: there's also an invalid ota entry.
    Edit #2: it seems that the play store and youtube apps are not signed well to allow updates because I always get errors...
    Ultima modifica di Korgar; 08-11-12 alle 10:49
    Guida per partizionare la microsd: HERE
    Tutti i file per il Next Turbo nel mio repository: HERE
    Premi a sinistra per ringraziarmi se ti son stato d'aiuto!
  4. #23
    Androidiano L'avatar di mazh26
    Novara
    Huawei ascend y530
    Quote Originariamente inviato da Korgar Visualizza il messaggio
    Regards
    io sulla jelly plusv2 ho appena flashato sopra il cor optimi v1 sono impegnato in una chiamata, e funziona tutto bene, vediamo come va ala lunga
  5. #24
    Androidiano VIP L'avatar di ZackFair84
    LG G5
    Ringraziato 1,022 volte in 794 Posts
    Regards
    Fahmi, maybe I can help. If you do a batch signing of apps, maybe you did it wrong. I remind you that Gapps must have the original signature to allow updates, so you must leave them from the batch signature.
    Korgar, the ota error shown occures when there isn't any rom update registered on the server.
    Proud developer of Galaxy Next Turbo Custom Rom Optimus Rom™ 3.0.0 testing
  6. #25
    SAMSUNG GT-S5570I
    Cribbio, almeno a me rispondi in italiano
    Per ora ho rimesso la optimus.
  7. #26
    Novara
    Huawei ascend y530
    adesso rimetto anche io la optimus
  8. #27
    JL93
    Ragazzi qual'è il codice per l'italia?
  9. #28
    SAMSUNG GT-S5570I
    Quote Originariamente inviato da JL93
    Boh? Io ho messo la rom, flashato il plenus e l'apn pare sia giusto. Non ho inserito nessun codice csc.
    Inviato dal mio GT-S5570I usando Androidiani App
  10. #29
    JL93
    Io avendo visto l'avviso pensavo che fosse necessario. Comunque l'italiano c'è però lascia molte parti della rom non tradotte e poi ho notato che se voglio scrivere con la tastiera 3x4 e il T9 non posso impostare come lingua di inserimento l'italiano .-.
  11. #30
    Androidiano VIP L'avatar di Michelasso
    Treviso
    Ringraziato 984 volte in 486 Posts
    Quote Originariamente inviato da JL93 Visualizza il messaggio
    E tu sbattigli sopra il pacchetto T9 di Zack. O non può funzionare per questioni di firma?
    Se sono stato utile non dimenticare di premere Thanks!
    Visita la mia collezione di temi per telefoni e tablet Xperia!
