Pagina 34 di 86 primaprima ... 2432333435364484 ... ultimoultimo
Visualizzazione dei risultati da 331 a 340 su 855
[RACCOLTA, CONSIGLI & CONFRONTI] Elenco CUSTOM ROM (Samsung Next S5570)
  1. #331
    Androidiano L'avatar di IlBella95
    Torino
    Quote Originariamente inviato da peppedb92 Visualizza il messaggio
    salve.. ho flashato GingerMod by ahmadsafar, Come faccio a spostare le app su SD?? s2e non va
    Io usavo Droidsail APP2SD
    Inviato dal mio Galaxy Next con Tapatalk 2
    Ciao Andrea
    Angry
    Quote Originariamente inviato da IlBella95 Visualizza il messaggio
    L'ho appena provato, ma delle quasi 25 app che ho installato me ne riconosce solo 5!! altri suggerimenti_??
  4. #333
    Torino
    Come solo 5?!? Io le spostavo tutte
    Ciao Andrea
  5. #334
    Androidiani Power User
    Apr 2011
    Samsung Galaxy A7 (2018)
    Ringraziato 1,953 volte in 1,221 Posts
    Aggiornamenti:
    MIUI GB by Siznex
    Versione BETA 1e
    Aggiornamento 18 aprile 2012
    Changelog:
    • fix theme ( you not to create "theme" at /data/system/ again
    • keyboard is look good --> thanks to P00t
    • Resized launcher 96% fix
    • SlaidyBoost-V2.3 --> thanks to slaid480
    • Beats --> Thanks to RockoDev and midomad
    • ... etc
    DOWNLOAD
    FONTE
    DreamW by Spawk
    Versione 1.1a
    Changelog:
    1- replaced ADW launcher with 2 auther {Go launcher,Go notification,Go weather}
    {G D E } launcher from here
    2 - add CM compass
    3 - add walkman player
    4- add equalizer [ in OC-Rom removed DSP manager for crashing on call ]
    5-add Radio [work with BT activated ]
    6-ICS themed in Go launcher and 3 other in GDE launcher for who loving cars
    7-youtube with download
    8- tweak in sound beter sound with effect ..etc just folow equalizer option
    all apps notificat if updat is released for [Go Notifier]
    9- changed bootanimation
    10-many tweak forget it [ ro tested and work very fine]
    V 1.1a
    1-changed launcher by 360 whit ics lock just set it from my theme
    2-bravia engain add
    3- tweek like zipalign debug ram etc etc add
    4- changed font
    and other forget it
    After fresh install 1.1a we have 127 Mo space into internal storage USED only 51 MO look screnshoot
    DOWNLOAD
    FONTE
    N.B: Ovviamente il primo post viene tenuto costantemente aggiornato!
  6. #335
    Monza
    samsung galaxy next
    ciao io vorrei sapere cosa intendi dicendo che consigli il primo kernel...non ho capito tra quali....quelli dei link??poi non so come aggiornare android dato che ho kies ma non mi permette di farlo non capisco....comunque mi sono iscritto oggi quindi capisco benissimo che è facile che non sappia cosa fare....però mi interessa molto quello che si vede nel video...rapido, pulito...ottimo....se riesci a darmi una guida dettagliata e esplicativa (mi piace capire cosa faccio!) ti sarei molto grato
  7. #336
    Ringraziato 23 volte in 17 Posts
    Ragazzi, Tj-Style è tornato a lavorare sul Next ed ha rilasciato la Andro-ID 3.3.1 se volete vi metto changelog e link
  8. #337
    Apr 2011
    Beh... il topic è fatto per quello
    io non trovo notizie... Google non mi trova nulla scrivendo "andro-id 3.3.1"
  9. #338
    [DEV] Andro-ID v3.3.1 ROM for GT-
    S5570
    (Author : tj_style)
    « Today at 08:44:09 PM »
    Andro-ID v3.3.1 Samsung Galaxy
    Mini (GT-S5570)
    Changes:
    V3.3.1:
    Android Gingerbread 2.3.6
    Clean and Great Performance
    Andro-ID Artwork (UI & Animation)
    Kernel 2.6.35.14
    OC up to 864Mhz
    Tiny Preempt RCU Subsystem
    IO Schedulers: NOOP, CFQ, BFQ,
    SIO, VR
    Added more CPU Governor:
    Interactive, InteractiveX, SmartAss,
    SmartAss2, Scary, SavagedZen,
    SmoothAss, BrazillianWax, MinMax
    & LagFree
    Swap Enabled
    Using EXT4 filesystem
    Pre Rooted
    Busybox installed
    Bash installed
    Redefined StatusBar
    App2SD removed (so you can
    choose to installing DT App2SD or
    S2E manualy)
    Reboot and Recovery shortcut
    added
    Swipe to Remove Notification
    (Thanks to hansip87)
    CMScreenshot added
    CRT on/off Animation (Thanks to
    Whitehawkx)
    Using ICS Transition Animation
    Fully customized Touchwiz
    Framework and added more
    Touchwiz Widget
    Some Bloatware removed
    All hardware is working great
    Flash from Recovery, but make sure
    you have to backup your current
    ROM first..
    please don't mirror the download
    link..
    V3.3.1:
    Andro-id_v3.3.1_tass_signed.zip
    md5sum:
    255c7499b9670462ae909c9bc9d17a6a
    Make sure the md5sum is match
    before flashing the roms..
    LINK: http://download.andro-id.net/ROMS/GT...ass_signed.zip
    FONTE: http://forum.andro-id.net/gts5570_sy...570_294.0.html
    Ultima modifica di massithereaper; 18-04-12 alle 23:25
  10. I seguenti 2 Utenti hanno ringraziato massithereaper per il post:
    astrone (19-04-12),millo1978 (18-04-12)
  11. #339
    http://download.andro-id.net/index.p...ile=Camera.apk
    Questo è il link per il fix della fotocamera, scaricarlo e rimpiazzare l'app in system/app
  12. Il seguente Utente ha ringraziato massithereaper per il post:
    astrone (19-04-12)
  13. #340
    susa una volta installate la rom v3.0 come faccio per applicare quei due temi ???
