Uei! Grande Frank! Immaginavo ti stessi già muovendo nell'ombra .. ed eccoti qua!#!/system/bin/sh
## Voltage Control boot script by FrankCilo #####
echo "200000" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
echo ""
echo "---------------"
echo "1600000" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
echo ""
for i in `ls /sys/block/stl*` /sys/block/bml* /sys/block/mmcblk* /sys/block/mtdblock* ; do
echo "sio" > $i/queue/scheduler;
echo "$i/queue/scheduler";
done;
echo "---------------";
echo "pegasusq" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
echo ""
#UV_BEGIN#
echo "1275 1225 1175 1150 1125 1100 1075 1050 1025 1000 975 950 925 900 875 850 825" > /sys/devices/system/cpu/cpu0/cpufreq/UV_mV_table
echo "54 108 160 266 350 440 533 640 733 800" > /sys/devices/system/gpu/freq_table
echo 54 800 > /sys/devices/system/gpu/volt_table
echo 108 825 > /sys/devices/system/gpu/volt_table
echo 160 850 > /sys/devices/system/gpu/volt_table
echo 266 900 > /sys/devices/system/gpu/volt_table
echo 350 950 > /sys/devices/system/gpu/volt_table
echo 440 1000 > /sys/devices/system/gpu/volt_table
echo 533 1050 > /sys/devices/system/gpu/volt_table
echo 640 1100 > /sys/devices/system/gpu/volt_table
echo 733 1150 > /sys/devices/system/gpu/volt_table
echo 800 1200 > /sys/devices/system/gpu/volt_table
echo 160 > /sys/devices/system/gpu/min_freq
echo 533 > /sys/devices/system/gpu/max_freq
echo 50 10 > /sys/devices/system/gpu/thresholds
echo "85" > /sys/devices/system/cpu/cpufreq/pegasusq/up_threshold
echo "50" > /sys/devices/system/cpu/cpufreq/pegasusq/up_threshold_at_min_freq
echo "40000" > /sys/devices/system/cpu/cpufreq/pegasusq/sampling_rate
echo "0" > /sys/devices/system/cpu/cpufreq/pegasusq/io_is_busy
echo "300000" > /sys/devices/system/cpu/cpufreq/pegasusq/freq_for_responsiveness
echo "5" > /sys/devices/system/cpu/cpufreq/pegasusq/freq_step
echo "1" > /sys/devices/system/cpu/cpufreq/pegasusq/sampling_down_factor
echo "10" > /sys/devices/system/cpu/cpufreq/pegasusq/down_differential
echo "300000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_1_1
echo "100000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_2_0
echo "400000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_2_1
echo "200000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_3_0
echo "500000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_3_1
echo "200000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_4_0
echo "100" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_1_1
echo "100" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_2_0
echo "250" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_2_1
echo "250" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_3_0
echo "350" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_3_1
echo "350" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_4_0
echo "10" > /sys/devices/system/cpu/cpufreq/pegasusq/cpu_up_rate
echo "30" > /sys/devices/system/cpu/cpufreq/pegasusq/cpu_down_rate
echo "800000" > /sys/devices/system/cpu/cpufreq/pegasusq/flexrate_max_freq
echo "3" /sys/module/cpuidle_exynos4/parameters/enable_mask
echo "5" > /sys/devices/system/cpu/cpufreq/pegasusq/freq_step_dec
echo ""
#UV_END#
Eccomi!
Io li ho cambiati così, perché quelli originali tendevano ad un utilizzo spropositato delle alte frequenze:
Allora andiamo a modificare di script l' S91voltctrl.. giusto?
Da editare come al solito, sono curioso di provare...
Sarebbe bello che qualcuno capace facesse una guida ai settsggi da STweaks, com'era x il siyah..
Grazie per esserti fatto vivo
Sent from my Cis80-GT-N7100-290dpi mod!
