Namaless
Ho provato un paio di giorni questa nuova versione by Samsung e finalmente un Firmware Samsung come si deve.
Ho applicato qualche patch giusto per renderla più performante. Al momento non viene rilasciata per terminare un periodo di test.
FUNZIONI:
- Gingerbread 2.3.6 - Samsung Firmware DDKP3.
Replace Kernel with Vurrut Kernel UC V6 ([I][URL="http://forum.xda-developers.com/showpost.php?p=21522791&postcount=2"]thanks vurrut[/URL][/I]).- Stock Kernel with CWM by Amit.
- Deodexed and ZipAligned.
- Rooted.
- Removed Boot Sound.
- Replace Samsung Boot animation with Custom boot animation.
- Replace Samsung Keyboard with Samsung Galaxy S2 Keyboard.
- Add Power menu without Header (Reboot, Reboot Recovery, Reboot Download).
- Add ICS Animations (need activate all animations in Settings -> Display menu).
- Remove reboot confirmation.
- Remove shoutdown animation.
- Replace Gingerbread fonts with ICS fonts.
- Add battery mod (use samsung icon).
- Notifications with LED (use CyanogenMod source).
- Add OLD CRT effect for Lockscreen.
- Enabled GPU acceleration for rendering the system interface.
- Auto-rotating Dialer and call screen (in development).
- Call recording (in development).
- Add Bravia Engine support (in development).
- Add Camera MOD for working with less 15% of battery (in development).
- Add Camera MOD for get photo with lock button (in development).
- Disable sync feature in sqlite.
- Add more tweaks in build.prop (thanks knzo);
NON FUNZIONA:
Al momento tutto funziona regolarmente, comprese le notifiche push con Wifi e 3G.
