Questa è una rom puramente AOKP,nulla più nulla meno.
Thread XDA:
[ROM] Android Open Kang Project - i9100 - JB Build-1+ [Unofficial][28/08] - xda-developers
Queste sono build non ufficiali e sperimentali,usatele a vostro rischio e pericolo
Ultime build:
aokp_i9100_jb-build-1_20120903.zip(xfer.in) - MD5# f853d0aeb6584798c5a6a19925e51c5c
aokp_i9100_jb-build-1_20120903.zip (goo.im) - MD5# f853d0aeb6584798c5a6a19925e51c5c
Changelog:
Project name: platform_manifest
•Bajee11 - Track AOKP external/freetype & Theme Chooser
Project name: android_vendor_tmobile_providers_ThemeManager
•Marco Brohet - ThemeManager: Dutch translations
Project name: proprietary_vendor_samsung
•Brian Beloshapka - epicmtd: Modified charging_mode binary for 3.0 kernel.
•Steve Kondik - msm8660: Update blobs
•jt1134 - mesmerizemtd: remove files unneeded for jellybean
•Shareef Ali - d2: fix nfc on d2vzw board family
Project name: frameworks_av
•Haynes Mathew George - libstagefright: Pass aligned width to color convert routine
•Krishnankutty Kolathappilly - libstagefright: Fix crash during next clip playback
•Tejas Shikhare - audioflinger: Avoid deadlock for sound recording - LPA concurrency.
•Y Mehta - frameworks/av: Use software decoders for LPA clips
Project name: frameworks_base
•Zaphod - fix IME down arrow for custom navbar
•David Ferguson - SamsungQualcomm RILs: throttle multiple outstanding SEND_SMS requests
•Erez A. Korn - Correct Change I32c89b82
Project name: android_system_core
•Jim Huang - libpixelflinger: Add ARM NEON optimized scanline_t32cb16
•Jim Huang - libpixelflinger: Build NEON optimized routine per target configuration
Project name: android_hardware_qcom_display
•Andreas Schneider - qdutils: Add MDP v3.0.2 detection.
•Saurabh Shah - hwc: Unlock prev. buffers in N+1th draw round.
•Sravan Kumar D.V.N - display : Do not use copybit for composition when YUV layer is present.
•Neti Ravi Kumar - hwcomposer : Disable bypass, when connected to external display
•Andreas Schneider - qdutils: Don't assume we support overlay without version info.
aokp_i9100_jb-build-1_20120831.zip (goo.im) - repo sync EST 1:43 PM 31/08 - MD5# 0ade04cd153f36d1782cec1e13964d35
Changelog:
Project name: vendor_aokp
•remicks - Update SuperSU to v0.96
Project name: android_bootable_recovery
•Koushik Dutta - 6.0.1.3
•LorD ClockaN - Add hideable kill-all-button to recent switcher (1/2 FWB part)
•Johan Viktorsson - Added check of ActivityInfo launch mode when starting activity.
•Vairavan Srinivasan - ContentProviderRecord: Remove external process reference when finalized
•nadlabak - ActivityManagerService: stay away from zombie content providers
•Vairavan Srinivasan - ProviderMap: remove hashmap when entire user specific entries are removed
Project name: packages_apps_ROMControl
•dagr8 - Add hidable kill-all-button to recent switcher (1/2 RC part)
aokp_i9100_jb-build-1_20120830.zip(xfer.in) - repo sync EST 6:30 PM 30/08 - MD5# a2f87da8446f8bd5d86f6da10f8738c3
aokp_i9100_jb-build-1_20120830.zip goo.im) - repo sync EST 6:30 PM 30/08 - MD5# a2f87da8446f8bd5d86f6da10f8738c3
Changelog:
•sbrissen - gs2-common: copy hwcomposer
•sbrissen - d710: fix using common props
•sbrissen - d710: make use off galaxys2-common
•chris41g - path change
•sbrissen - d710: fix headers
•sbrissen - d710: update props for jb
•chris41g - renamed to d710 as per other SGSII variants
•xoomdev - Support NT_MODE_LTE_CDMA_EVDO for LTE toggle (1/2)
•Naveen Kalla - Telephony: Initialize RIL with the correct CDMA subscription mode setting
•Mike Kasick - Poll for DATA_REGISTRATION_STATE on SVDO devices (3G icon fix).
•BMc08GT - Add ability to unlink notification volume from ringtone volume (1/2)
•Jonas Larsson - Configurable 0, 90, 180 and 270 degree rotation (framework part)
•xoomdev - Bring back down arrow (when IME is showing) in nav bar.
Project name: packages_apps_Settings
•Roman Birg - add ability to separate ringtone & notification volumes (2/2)
•Jonathan Steadman - RC: fix typo
•Prateek Srivastava - Custom Boot Animation
•BMc08GT - Allow 180 degree rotation (2/2)
Project name: packages_apps_Contacts
•Ricardo Cerqueira - Contacts: Fix broken export-to-storage function
Project name: packages_apps_Mms
•Mike Kasick - SmsReceiverService: Stop only if there's no outstanding SMSes being sent.
Project name: android_device_samsung_galaxys2-common
•codeworkx - enable samsung stk
JB-BUILD-1:
* Info:
http://aokp.co/site/index.php?/topic...ybean-build-1/
* Assicuratevi di essere sull'ultima CWM
* FATE UN NANDROID BACKUP
* wipe data/factory reset in recovery
* flash ROM
* flash Gapps
QUI o
QUI
* reboot
Tutte le build le trovate qui:
http://xfer.in/pier e qui
http://goo.im/devs/RootBox/AOKP-i9100
Pier e baje11 ringraziano:
- Pier - Gerrit, Support and much more!
- AOKP, CyanogenMod and Teamhacksung Crews
- Sixstringsg, Xplodwild, Snipa, Codeworkx
- Rodries and the "real" SGS2 developers
Qui le sources comuni su
Github e
Gerrit per le modifiche
Il modo migliore per aiutare il team o contattarlo è tramite IRC:
http://webchat.freenode.net/?channels=AOKP-SGS2
NE IO NE IL TEAM CI ASSUMIAMO RESPONSABILITA' IN CASO DI DANNI AI VOSTRI DEVICE
