Pagina 1 di 21 12311 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 202
(18/11) Googy-Max2 Kernel 2.0.6 (Linux 3.0.101 / Linaro GCC 4.7.4)[GT-I9300]
    Androidiano VIP L'avatar di Volpe92
    Venezia
    S3, S6 edge 64gb, note 3
    Ringraziato 172 volte in 139 Posts
    Questo kernel è SOLO per le ROM SAMSUNG 4.3/CM11/OMNI/TEMASEK (r3p2)!!!
    Dualboot IS WORKING !!! reboot to desired rom via stweaks dualboot tab or via @Derteufel1980 recovery
    RICORDATE SEMPRE DI FARE UN NANDROID BACKUP PRIMA DI FLASHARE, O PER LO MENO AVERNE UNO DISPONIBILE
    Versione corrente: [ 2.1.7 ] - (05/03/2014) * * {Downloads} * {Changelog nel #2 post}
    Features :
    - Based on Samsung Update13 Sources & patched to latest sources drop
    - Updated to latest XXUGMK6 ramdisk
    - Patched to latest Linux 3.0.101 (EOL)
    - Compiled with linaro gcc 4.7.3 (optimized for cortex-a9) :good:
    - DUAL Sound-Engine : Audio enhancement and sound boosting for great headphone experience (Wolfson Sound Engine*AND ScoobyDoo Sound Engine 1.1*selectable via STweaks)
    - Touch-to-Wake support
    - Configurable LED behavior + LED fading support
    - MDNIE full control
    - Cpu OC support (up to 1600Mhz)
    - Cpu UV support
    - Gpu OC support (up to 700Mhz)
    - Gpu UV support
    - Governors : Pegasusq [default] / Zzmoove 0.7d / Lulzactiveq / SmartassV2 (Configurable via STweaks :good: )
    - I/O Schedulers : Deadline - cfq[default] - noop - row - sio - vr - fifo - bfq
    - Xpad support
    - TriangleAway support
    - USB OTG support
    - Network filesystems support (nfs, cifs, sunrpc)
    - Dynamic FSync 1.2 - Configurable via Stweaks (On by default)
    - init.d support
    - Custom bootanimation support (bootanimation.bin or bootanimation.zip to be placed in /data/local/)
    - Increased values for SD ReadAhead - Configurable via Stweaks
    - TCP congestion control (cubic[default]-wetswood-bic-hctp) configurable via STweaks
    - Auto-root (updated to latest su and supersu with daemon autorun)
    - NTFS automounting for USB sticks, mounted to /mnt/ntfs folder in Read Only mode
    - ExFAT support
    - Charge current for AC & USB raised (Configurable via STweaks) & ignore unstable power & ignore safety margin
    - CRT-OFF support (Early Suspend) [Adjustable]
    - Almost everything is configurable via simple and free STweaks (included in the kernel)
    - MORE TO COME ...
    INSTALLAZIONE:
    - Andare in recovery
    - wipe cache
    - wipe dalvik
    - (Consigliato) https://www.androidiani.com/forum/mo...-3-slim80.html
    - Flash kernel
    Enjoy
    - Gokhanmoral !!!
    - @Yank555
    - @DerTeufel1980
    - Samsung : For the code source
    - @arbi97, @davtse, @FadeFx, @habylab, @qtwrk, @rafaelpernil & my friend @romskii : my first and only beta testers (Beta team is now complete, no more additions)
    - @qrashers for the Googy-Max Kernel logo & user / betatester signatures
    Source (presto disponibili):
    https://github.com/googyanas/Googy-Max2-Kernel
    Firma d'utilizzo:
    Official Mirror kindly maintained by @romskii (Roman Kunkel)
    File Googy
    XDA:DevDB Information
    [DUAL-BOOT] (08/11) Googy-Max2 Kernel 2.0.7 (Linux 3.0.101 / Linaro GCC 4.7.4), a Kernel for the Samsung Galaxy S III I9300
    Contributors
    googy_anas, arbi97, davtse, FadeFx, habylab, qtwrk, rafaelpernil, romskii (Beta team is now complete, no more additions)
    Kernel Special Features:
    Info Versione
    Stato: Stabile
    Creato il 08/11/2013
    Ultimo Aggiornamento 05/03/2014
    NE IO NE ANDROIDIANI SIAMO RESPONSABILI DI QUELLO CHE FATE CON IL VOSTRO DISPOSITIVO
    Ultima modifica di Volpe92; 09-03-14 alle 11:31
  2. I seguenti 6 Utenti hanno ringraziato Volpe92 per il post:
    fuji97 (10-12-13),illuminato67 (09-11-13),kingalessandro (09-11-13),MrFrancesco961 (03-01-14),N1m0Y (09-11-13),pappo63 (10-04-14)
    Venezia
    Changelog :
    [05/03] Version 2.1.7 :
    - CM11: Updated ramdisk to latest build 04/03 (added telephony-msim to bootclasspath)
    - Some minor internal tweaks
    Ultima modifica di Volpe92; 09-03-14 alle 11:33
  5. #3
    Venezia
    COME UTILIZZARE IL DUALBOOT
    Allora:
    -Ho flashato la recovery DerTeufel1980 http://forum.xda-developers.com/atta...6&d=1385507108
    -Flashato il Googy 2.1.3
    -Poi dalla recovery DerTeufel1980>dualboot menu> create secondary system image (aspettate qualche secondo)
    -Dal menù principale della recovery> wipe data> **Secondary ROM** > Wipe data/factory reset
    -Dal menù principale della recovery>Backup and restore>Restore Secondary Rom from /storage/sdcard1
    -Reflash Googy 2.1.3
    Comunque nella bootanimation del googy, quando fa il countdown e ti chiede di premere il tasto HOME se vuoi andare nella 2nd rom non mi funziona :/
    Ultima modifica di Volpe92; 12-01-14 alle 20:37
  6. #4
    ......in riva al mare
    GalaxyS2-GalaxyS3-GalaxyS5
    ok, chiudo l'altro
  7. Il seguente Utente ha ringraziato dieguccio per il post:
    Volpe92 (09-11-13)
  8. #5
    Androidiano VIP L'avatar di kingalessandro
    Nocera Inferiore
    Samsung Galaxy SIII+SIV+LG G4
    Ringraziato 3,349 volte in 1,075 Posts
    Commento per restare aggiornato Buon lavoro
    Un thanks non fa male a nessuno
    DEVICE 1 : LG G4 Rooted
    DEVICE 2 : Samsung Galaxy I9505 ImperiumROM by Slim80
    SLIM80 IMPERIUM ADDICTED
  9. Il seguente Utente ha ringraziato kingalessandro per il post:
    Volpe92 (09-11-13)
  10. #6
    Senior Droid L'avatar di vSilenCe
    Ringraziato 37 volte in 33 Posts
    Diego ti rispondo qui. Ho la rom stock, ma davvero sta uscendo per s3 la 4.3??
  11. #7
    Venezia
    Quote Originariamente inviato da vSilenCe Visualizza il messaggio
    Il roll out è già iniziato della 4.3 e i sorgenti kernel già rilasciati! Questo appunto è un kernel per rom Samsung 4.3
  12. Il seguente Utente ha ringraziato Volpe92 per il post:
    vSilenCe (09-11-13)
  13. #8
    Ed era ora!!
  14. #9
    Baby Droid L'avatar di andrewspn
    Appena flashato questo kernel su una imperium 20.0 beta 2! Che settagi usate voi?
  15. #10
    Venezia
    Quote Originariamente inviato da andrewspn Visualizza il messaggio
    Io per il momento sto con i settagi di default...faccio due tre cicli e poi vedo se è il caso di cambiare qualcosa
