hispanico
Uscita la 1.4
Changelog:
SuperMan-Rom V1.4:
- applock really fixed
- added choice in aroma to install IOS emoji
- updated all installed apps (shealth, voice recorder, samsung push, billing and so on)
- added samsung music as user app (can be uninstalled)
- Finally fixed adb AND sd card, now both working great!
- if you install busybox, you will also get the busybox user app now
- some more csc tweaks
- Updated xposed to V84
- Rounded recent panel view
- Remove gray statusbar when activated PowerSaveMode
- Rounded Notifications
- Bringing buttons "only once / always" to select when the task application "Open With."
- all apps in multiwindow
- USB Plug/Unplug disable wake up
- Remove high volume warning for headphones
- Emergency mode" in "Settings/Lock screen and security
- private mode fixed
- Enable Display Scaling in Settings
- Enable TouchKey light duration in settings
- Enable OutdoorMode
- special thanks to @
ervius for helping me out very much!!!
HISPANICO
