nuno169
[Kernel] - Only tested with KK Stock Rom 1.64 !
Good afternoon!
After many time of running with me head against the wall, I am glad to be able to deliver the first real version of my modified kernel with F2FS.
After some help from @
paolothlw8 on the initial stage, and with study of multiple git's from other devices, specifically from Dorimanx to G2, AK-Kernel and UBER-N5, i was able to get our Nubia Z7 Max to work with F2FS.
At this stage, to get this to work, modded recovery (TWRP) and Kernel (with modules installed to system - thanks again @
paolothlw8) must be flashed.
I warn you all that this can be risky, i am not responsible if problems occur, but i will try to provide the safest procedure that i follow.
Needed:
- Stock TWRP recovery with EXT4 partitions;
- My 2 zip files on SDCard (Internal or External) - NX505J-NGIAKernelV1.0-F2FS-DC.zip and TWRPF2FS.zip .
The procedure:
1 - On your stock TWRP recovery make a full backup, then you will always be able to revert;
2 - After Backup, install my modded TWRP ("TWRPF2FS.zip");
3 - Reboot again to new Recovery;
4 - On new recovery can appear "can't mount /data" , no problem it's normal;
5 - Go to "Wipe", "Advanced Wipe", select "Data" and then press "FS Options";
6 - Then "Change FS", select "F2FS" and swipe to format partition;
7 - Repeat steps 5-6 but selecting "Cache";
8 - Go back to main menu of TWRP, and go to settings(right upper corner) and pick "Use rm -rf instead of formatting" - Make sure is picked! Otherwise on restore it will format back again to EXT4;
9 - Now, all set to restore Data - Go to "Restore" , select your last Backup (made on step 1), select ONLY "Data" (confirm with scroll), and proceed with restore;
10 - Done Restoring;
11 - Now time to flash "NX505J-NGIAKernelV1.0-F2FS-DC.zip" ;
12 - If all suceeded, you can now restart System and enjoy!
Find the necessary zip files here:
https://drive.google.com/open?id=0B1...R2s&authuser=0
Thank You All!
ITA Translate:
Buon pomeriggio!
Dopo molti tempo di correre con me testa contro il muro, sono felice di essere in grado di consegnare la prima versione reale del mio kernel modificato con F2FS.
Dopo un po 'di aiuto da @ paolothlw8 concernente la prima fase, e con lo studio di git più di altri dispositivi, in particolare da Dorimanx a G2, AK-kernel e UBER-N5, sono stato in grado di ottenere il nostro Nubia Z7 Max lavorare con F2FS.
A questo punto, per ottenere questo al lavoro, recupero modded (TWRP) e Kernel (con moduli installati al sistema - grazie ancora @ paolothlw8) deve essere balenato.
Vi avverto tutto ciò che questo può essere rischioso, io non sono responsabile in caso di problemi, ma cercherò di fornire la procedura più sicura che seguo.
Necessario:
- Recupero della TWRP con partizioni EXT4;
- I miei 2 file zip su SDCard (interno o esterno) - NX505J-NGIAKernelV1.0-F2FS-DC.zip e TWRPF2FS.zip.
La procedura:
1 - Sul recupero magazzino TWRP fare un backup completo, allora si sarà sempre in grado di tornare;
2 - dopo il backup, installare il mio TWRP modded ("TWRPF2FS.zip");
3 - Riavviare nuovo per nuovo recupero;
4 - Il nuovo recupero può apparire "non può montare / dati", nessun problema è normale;
5 - Vai su "Wipe", "Wipe Avanzate", selezionare "Data" e quindi premere "Opzioni FS";
6 - Allora "Change FS", selezionare "F2FS" e scorri per formattare la partizione;
7 - Ripetere i passaggi 5-6, ma selezionando "Cache";
8 - tornare al menu principale di TWRP, e andare alle impostazioni (in alto a destra) e raccogliere "Usa rm -rf invece di formattazione" - Accertarsi che viene raccolto! In caso contrario, il ripristino sarà formato di nuovo a EXT4;
9 - Ora, tutto pronto per il ripristino dei dati - Vai su "Ripristina", selezionate il vostro ultimo backup (fatta nel passaggio 1), selezionare solo "dati" (confermare con scorrimento), e procedere con il ripristino;
10 - Fatto Ripristino;
11 - Ora il tempo a lampeggiare "NX505J-NGIAKernelV1.0-F2FS-DC.zip";
12 - Se tutto suceeded, è ora possibile riavviare il sistema e buon divertimento!
Trovare i file zip necessari qui:
Grazie A Tutti!
